Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. badbennyb
    Hey brian, when you get a chance can you double check my price on the ipod kit for the forester (H621SSC200). I think I was charged full price today but didn't notice it until I got home. Its showing 192.24 and I thought you may have said 140ish. Thanks and be sure to thank Ben for the work done today.
  2. Dynapar
    Looking for price and availability for the STi rear lateral links (all 4) for a GC Impreza 93-01. I believe these are available through the SPT catalog. Thanks
    Also I will need to grab a new Turbo/DP gasket when I am in on Monday.
  3. Frogy
    Frogy Well-Known Member
    I think the part numbers should be good for the buckets that I need, I will get in tomorrow to pay for these and get them ordered. Please make sure that they get ordered Monday if possible at all.
    13228 AB331 4.91 (0.1933)
    13228 AB231 4.81 (0.1894)
    13228 AB251 4.83 (0.1902)
    13228 AB341 4.92 (0.1937)
    13228 AB371 4.95 (0.1949)
    Thanks in advance
    Frogy
  4. Bielke55
    Yea that was my fault. I forgot to change the price level. If you PM or Call morries, or just stop by i'll get it taken care of.
    $520.00 for the set
    Gaskets are in stock for ya.
    Ordered up we'll see them wednesday
  5. Frogy
    Just in case I did come by and talked with AWDimprezaL, this didn't cause two sets to be ordered did it?
    Sorry for the confusion
    Frogy
  6. AWDimprezaL
    Dont worry man, we've got it handled.
    phi11 likes this.
  7. badbennyb
    Is it too late if I stop in when my floormats show up at lexus at the end of next week(hopefully)? or should I call and talk to ya sooner? I'm not hurting for the money at the moment.
  8. Frogy
    Good morning,
    I was wondering if the 3 small coolant hoses near the water pump are available? I am refering to the 3 that attach to the water pump and the other between the hard line and the oil cooler. as always for an 03 WRX
    Thanks in advance
    Frogy
  9. Bielke55
    Whenever its convenient for ya man.
  10. Bielke55
    1. Small hose to hard line for oil cooler - 807611031 = $8.74 Not In Stock But can get one for tomorrow.
    2. Small Hose #1 from Water pump to hard lines - 807612011 = $5.78 In stock
    3. Small Hose #2 from Water pump to hard lines - 807615182 = $5.18 In stock
  11. Frogy
    if you could order the first part for tomorrow that would be great, also can you get the larger hose from the water pump to the lines above?
  12. Kevin
    Kevin Well-Known Member
    I know i checked a few weeks ago, but is a front o2 sensor in stock? 04 wrx
    also... the hardware that attaches the strut mount to the strut? i know there is a nut, nut sure if any washers or anything?
  13. Shibbs
    07 WRX
    How much for the little -< in the washer fluid line? The one with the clip that attaches to the hood. In stock by chance?
  14. Frogy
    Hey guys, I just wanted to thank you for your help, I finally completed my valve clerance/timing belt project. All of the parts were correct, fit great and worked the first time. Subaru parts rock!
    Thanks again
    Frogy
  15. Dynapar
    I am looking for a woodruff key for a 98 LGT. The Key is the little guy which goes onto the crankshaft which keeps the crank pulley and timing belt pulley from rotating freely on the crank.
    Thanks
    Edit: also need these parts:
    Cap for shift fork thingy on 04 STi 6spd (holds the rod that the shift fork is on in the tranny)
    95 Impreza LXrear pass lateral link bolt (alignment one)
    95 impreza LX rear pass trailing arm bolt and nut (where it connects to the knuckle)
    04 STi inner and out axle boot kits for rear pass axle
    Also do you do alignments at the dealership?
  16. Frogy
    I'm looking for a H6210FG000, should be an aux input for a 08-10 WRX, thanks!
  17. Bielke55
    $59.60 And its in stock
  18. thunderdan1313
    thunderdan1313 New Member
    05lgt wagon i need one rim and what snowtires do u have in stock??
  19. mlgez
    mlgez Well-Known Member
    Ok more parts needed for the same '99 Impreza 2.2L Auto as before (let me know if you need the VIN).
    If not in stock go ahead and order.
    For the Auto trans I need:
    Front and rear main oil seals (service manual 3-2-1 #15 and 3-2-10 #19)
    The transmission stub axle shaft seals *2 (3-2-9 #7)
    Circlip for stub axle shafts *2 (3-2-9 #10)
    Oil pump shaft seal (3-2-1 #6)
    Oil pump shaft clip (3-2-1 #8)
    AT filter
  20. Bielke55
    I need your VIN number man, just the last 8 digits.
  21. mlgez
    Not sure if you really meant me so you have PM just in case.
  22. Dynapar
    Ok,
    Can I get prices and availability on:
    Shift knobs for the STi 6 speed. OEM leather one, Titanium piston one, and the duracon plastic one. If you could let me know it would be awesome.
  23. bhiku
    bhiku Well-Known Member
    Just wanted to say, "Thanks!" for the help last week. We're picking up the block tomorrow so we'll let ya know about the piston rings as soon as we can. And Happy New Year!
  24. John16V
    John16V Well-Known Member
    A/C tensioner pulley for a 00 RS? Does that long adjustment screw are also come with the part?
    Thanks
  25. Bielke55
    Pulley is $27.86
    Bolt is $2.10
    We have both in stock
  26. John16V
    I'll be in around lunch to pick them up.
    Thanks
    BTW, cool Domo!!
  27. mlgez
    Not sure if you saw this. Need for this weekend if possible.
  28. 02blubru
    can I get a price on a black center counsle arm rest extension for my 2005 2.5i please???
    kthxbye
  29. jubella2
    jubella2 GC8 FTW
    Can I please get the price for a front drivers side wheel bearing 99 2.5rs and is this something I could replace myself?
    Thanks! Let me know if you need any other info
  30. Bielke55
    $59.60 for the bearing
    and theres two seals are $8.56 and $7.06
    This is a pressed in bearing... So i dont think you'll be able to do it on your own?
  31. webcrawlr
    webcrawlr Well-Known Member
    What model Interstate do you guys sell? I'm looking for the Mega-Tron Plus (black top)
  32. Bielke55
    We dont have Interstate battery four to say... They are Subaru Batteries Produce by Interstate. So theres no model number, no product name. Just a Subaru Part number and CCA (550).
  33. jubella2
    jubella2 GC8 FTW
    Thank you Bielke. Looks like I'll be calling around today
  34. AWDimprezaL
    Teste
    phi11 likes this.
  35. RexNEffect
    Unpainted side-view mirror housing, passenger side.
    Painted front bumper (Garnett Red).
    '07 WRX.
    Also, can't remember if the prices you give us are before or after our discount...
  36. RexNEffect
    Bump for my last post ^. Not planning on replacing them until the spring though.
  37. G_2.5rs
    G_2.5rs Well-Known Member
    how much is the 142,500 mile maintenance
  38. MORRIESTONKASUBARU
    MORRIESTONKASUBARU Vendor
    $151.96 Un painted with the discount
    phi11 likes this.
  39. RexNEffect
    I'm guessing that's for the side view mirror housing. How about the front bumper?
  40. Bielke55
    Sorry that is just the Mirror, and its not in stock
    Bumpers do NOT come painted. $199.96 in stock
  41. thunderdan1313
    looking for an update on the strut. i do belive it was coming in today i hope.
    also looking for torque specs i found these online are the correct?
    wheel hub attaching bolts= 48ft lb
    upper strut mount= 23 ft lb
    lower strut bolt= 188 ft lb (or is it 118)
    center strut top nut= 40 ft lb
  42. AWDimprezaL
    I have zero torque specs dude.
    The strut is here though!!!
    phi11 likes this.
  43. pattertj
    pattertj Member
    ThunderDan. I have a Factory Service Manual in front of me... have any more specifics on what torque specs you need?
  44. thunderdan1313
    i found out my libary has alldata so i got everything i needed. but that you for the offer
    thanks to the guys up at morries parts.
  45. RexNEffect
    Ouch. OK, thanks Bielke. Definitely gonna wait until the spring then.
