Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. thunderdan1313
    thunderdan1313 New Member
    i talk to eric earlyer and want to make sure we were talking about same part. the part i need is #7(rear link)
  2. AWDimprezaL
    That diagram is for an earlier legacy, 2000-2004.
    phi11 likes this.
  3. AWDimprezaL
    HOWEVER! upon closer inspection of what you are looking for, we have it. $56.21
    phi11 likes this.
  4. thunderdan1313
    if that was bent would it bring(tilt) the bottom of the wheel inward(under the car)?
  5. AWDimprezaL
    It might, then again it might just need an alignment
    phi11 likes this.
  6. mlgez
    mlgez Well-Known Member
    Need a few more parts for the '99 Impreza 2.2L
    1. Shifter cable bushing,washer, clip that attached the end of the shifter cable to the trans. #15 points to the clip.
    2. Lower radiator hose.
    3. Power steering rack rubber boot on the passenger side and clamps for it.
    I need pricing for a 2002 Outback Sport drivers side fog light lens. The front glass is smashed.
    Also looking for: On the '02 the glove box has two stop pins on the sides that have a rubber bushing over them. I need the rubber bushings.
  7. Bielke55
    I cant find anywhere about a Bushing... but the washer is $0.54 no stock and the snap pin is $2.22 no stock.
    $11.96 no stock
    Boot is $19.86 in stock, the clamps are $1.14 and $0.90 no stock on clamps
    1.I need pricing for a 2002 Outback Sport drivers side fog light lens. The front glass is smashed.
    Can not get just the lens. Its only the whole assembly (minus the metal bracket) $131.96 In Stock
    2.On the '02 the glove box has two stop pins on the sides that have a rubber bushing over them. I need the rubber bushings.
    Rubber Bushings are $1.46 each no stock.
    If i order parts today we see them on Wednesday.
  8. mlgez
    I will take these parts. I will wait on the fog light housing.
    I wonder if the bushing suppose to be part of the cable assembly. How much would that run me? Would kinda suck to have to buy that for a $5 part.
  9. Bielke55
    $40.10 for a new cable.
  10. mlgez
    Go ahead and order as longs as you can send it back if it does not contain the bushing. We can look at it when it comes in and if it is there I will take it. Does that work for you?
  11. driftin240
    driftin240 Well-Known Member
    Matt, the cables that we have in stock have the little bushings in them, so I am sure this one has one in it as well.
  12. mlgez
    Hate to spend 40 for it but I want that piece so I will take it.
  13. Frogy
    Frogy Well-Known Member
    I'm looking for a idler pulley for the air conditioning belt on an 03 WRX
  14. driftin240
    73131FC000 $27.86 + Tax. Shows we have 1 here right now.
  15. gran0393
    gran0393 Well-Known Member
    drivers side bugeye fender? if possible painted aspen white. oh and the side marker light
  16. Frogy
    Thanks!
  17. Bielke55
    Fender is $179.95 in stock. Can NOT get it painted from Subaru. But i can ask my body shop
    Marker Lamp is $31.06 in stock
  18. gran0393
    if you could ask the body shop that would be sweet, i'm going to have to wait till next friday to get the fender so i'll let you know next week if i still want you to get me one
  19. Daveo
    Daveo Well-Known Member
    Any chance that you have the all weather mats for a Bugeye in stock?
  20. Bielke55
    $39.96 In stock
  21. mlgez
    Well I got the car started and no strange noises so that is a good start but now I am throwing a idle solenoid code.
    '99 Subaru Impreza again:
    I need #3 and #4 on the image for this weekend if possible.
    How much for a rear O2?
    Also I do want to order those bushing for the glove box stops on the wife's '02 Outback Sport.
  22. Bielke55
    #3 - Gasket = $5.06
    #4 - Valve = $148.86
    Both are in stock
    Rear O2 = 119.96 No stock Can see it here on Wednesday
    And I will order up those bushingss now.
  23. mlgez
    Sounds good. I will take the O2 also.
  24. gran0393
    will i have to order that fender or do you have it in stock? the soonest i could pick it up would be on monday
  25. Bielke55
    Yea still in stock.
  26. mlgez
    I just want to thank both of you guys for getting the parts I needed as quick as you could. It was an interesting 2-3 month project. Here's hoping it stays together. I just drove the first 20 miles on my engine rebuild and swapped trans.
    Thanks again.
  27. AWDimprezaL
    I'll be crossin' my fingers for you Matt! good luck dude.
    phi11 likes this.
  28. gran0393
    sweet bielke i'll prob be up early on monday if i can pull myself out of bed on my day off
  29. jubella2
    jubella2 GC8 FTW
    Bielke I'm not sure what I need but my oil drain plug is no longer sealing and I have a pretty good leak.
    My guess is I'll need the washer/gasket thing for sure but do you suggest a new plug as well? For a 99 2.5rs.
    I should be able to swing by on tuesday
    Thanks!
  30. gran0393
    i got called in to work tomorrow so i'll have to get that fender later this week...i'm thinking early thurs or sometime fri
  31. J.Rex
    J.Rex Well-Known Member
    I need a black driver's side view mirror assembly for an 07 wrx tr, do you have one in stock and how much?
  32. AWDimprezaL
    Showing close to 15 different part numbers for mirrors for your car, Need the last 8 of the vin if you would be so kind :)
    phi11 likes this.
  33. Bielke55
    Oil drain plug is $3.44
    Crush Washer is $ 0.67
    Both are in stock
  34. J.Rex
    I don't have the car right now so I don't have the vin. I think the different part numbers are just different color skins, mine is just black (not black pearl) cause it's the TR. Really if you have any color in stock, that would work, i just need a side mirror since mine broke off. Thanks
  35. Bielke55
    No we ask for VIN because its either: heated/Remote control, Non Heater/Remote control. And since the parts dont say what they are in the catalog, The vin number weeds it out.
    edit: Hamline Called got it taken care of.
  36. thunderdan1313
    05lgt
    exhaust gaskets for the Down pipe both sides and the UP pipe Both side
  37. jubella2
    jubella2 GC8 FTW
    Thank you sir!
    Will see you on tuesday or wednesday
  38. Bielke55
    Down Pipe Gasket @ Turbo = $18.18 In stock
    Stock DP Catted Flange Gasket = $11.50 In stock
    Stock DP Catted Donut Gasket = $16.00 No stock
    Up Pipe @ Turbo = $11.50 In stock
    Up-Pipe @ Manifold = $11.50 In stock
  39. tangledupinblu
    Hey fellas!
    1) Do you carry the fog light bulbs for the 08/09 STi/WRX?
    2) Do you have to buy the new fogs in sets, or can you buy just one?(cracked the passenger side lens at the ice races)
    3) Do you have any passenger side fender liners in stock for the 08 STi?
    Prices and availability plz?
    phi11 likes this.
  40. Bielke55
    The bulb is a 9006, we have them at 10.36 each
    No, you can get just one if need be. RH Fog lens and body assembly is $97.60
    Yes, $48.48
  41. tangledupinblu
    You're the best Brian! I'll be stopping in tomorrow to see you.:)
    phi11 likes this.
  42. JasonoJordan
    price for a set of hood dampers for a 02 wrx?
  43. predavore
    predavore Well-Known Member
    Guys, I have a friend with an 08 Forester. Has a bent strut (not sure which). What does each corner cost with discount?
  44. predavore
    More of a question for Grimmspeed? ...since there isn't a stock part for that year (that I know of).
  45. Bielke55
    Fronts are $119.96 each AND Rears are $135.96 each. Depending on the VIN we may or may not have it in stock.
