Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. carl
  2. phi11
    28313ae030 ???????
    front drivers side knuckle
  3. piddster
    I need a picture of all the plastic clips that hold the brake lines in the engine bay of a first gen Legacy, which is probably the same as the GC Impreza. I can use that to let you guys know what part numbers I need.
  4. Bielke55
    Only the RH one in stock. $48.48 each I can have the LH one here on Wednesday
    As cool as those are... No we can not get
    You probably talked to 3rik already but just in case...
    $199.96 and in stock
    Looks like the number is 26535AA000, and they are $2.94 each... None in stock would need to order
    phi11 likes this.
  5. PaulasaurusREX
    2004 Outback 4cyl front brake pads. Price/Part #
    Thanks
  6. piddster
    Are they all the same?
  7. Bielke55
    It is hard to say. But those are the clips for most of the line
    EDIT: The clips i posted about are the ones with the Number 1 by it.
  8. piddster
    ^ Cool. I'll take a look thursday night and figure out which ones I need.
  9. strangefamous
    Kinda of a wierd question. Have any 02 WRX trunks in stock? I need a full trunk. Price too if you have them plz. :)
  10. PaulasaurusREX
    Bump, availability? Need this coming week.
  11. Lowrider
    Lowrider Well-Known Member
    How much is a clutch for a 97 Impreza 5 speed?
    thx
  12. John16V
    John16V Well-Known Member
    Is it still possible to get a gold center wheel cap for the 98RS? If so, (dare to ask) how much?
    Thanks
  13. Bielke55
    Not in stock. $335.96 for either predrilled for a spoiler or not pre drilled.
    $75.96 / 26296FG010
    2.2 OR 2.5?
    Still avaliable. Need to order it though. Only $17.30
  14. idget
    Can I get prices and availability on:
    Front outer tie rod (x1)
    Front wheel bearing (x2)
    and possibly:
    front knuckle assembly (x2)
    This is for an '00 RS
    Stank you!
  15. Bielke55
    Front Outer Tie Rod End - 34161SA000 = $43.96
    Front Wheel Bearing - 28016AA011NT = $59.60 each
    Front Wheel Bearing Inner Seal - 28015AA070 = $7.06
    Front Wheel Bearing Outer Seal - 28015AA080 = $8.56
    Front Knuckle RH - 28313AE020 = $199.96
    Front Knuckle LH - 28313AE030 = $199.96
    Everything is in Stock.
  16. idget
    sweet! Thanks Brian!
    I think I'll pass on those knuckles until I break one. I'll plan to swing by tomorrow or Wednesday.
  17. Lowrider
    2.2 ....Brian
  18. Bielke55
    Clutch Disc = $103.96
    Clutch Pressure Plate = $139.96
    Throw-Out Bearing = $35.94
    Pilot Bearing = $9.78
    All in stock
  19. carl
    brian did you see the email I sent yesterday?
  20. Bielke55
    Replied!
  21. blackozone
    What is pricing for rear knuckle assemblies on an 04 STI? Looking for left and right.
  22. Lowrider
    How much is a set of a brembo piston seals (Front Calipers)?
    Plus the brembo Nipple (one) front caliper?
    Thanks!
  23. Bielke55
    The seal kit is $70.00
    The nipple is $5.76
    Neither are in stock. Becareful with those brembo pistons... they are NOT replaceable.
  24. Bielke55
    $133.32 each and not in stock.
  25. Lowrider
    Would it be safe to replace the seals at the dealership just in case they screw up the dealer is liable?
    Thanks
  26. Bielke55
    I would do it at the dealership so that it can be done right. The liablitiy factor is up to the dealership you go to.
  27. Lowrider
    Non of them is leaking so far but one side is getting warn out..But thx for the heads up!
  28. unhguy78
    unhguy78 Well-Known Member
    sorry if this is an obvious question, but do you (Bielke55) work at the minnetonka subaru?
  29. Bielke55
    sure do
  30. unhguy78
    that's great! much appreciated i'm sure for your help with pricing and everything
  31. Bielke55
    Your welcome!
  32. unhguy78
    do the metal pedals available for the 06 wrx w/ clutch pedal come with the floor plate?
  33. Wingman
    Wingman Active Member
    Do you guys have
    oil return hard line for a vf39 + the gasket
    and the rubber oil return hose with the clamps for an 04 FXT
  34. Shibbs
    Bielke, have you seen my headlight yet?
  35. unhguy78
    any update on this stuff?
  36. predavore
    predavore Well-Known Member
    Mtka Subaru Parts Guys Rule!!!!
  37. badbennyb
    Yep! And before driving out there for nothing I just wanna double check that my parts came in on moday, lemme know.
  38. Bielke55
    No sorry not sure what your looking for. Are you asking about the bolt on pedal sets?
    Oil Return Tube = $26.60
    Oil Gasket = $.86
    Oil Return Hose = $8.74
    Oil Return Hose Clamps = $2.36 each
    Shipped out yesterday!
    Thank you sir!
    Bumped!
    I have forgot you ordered... By your tshirt is here
  39. idget
    price for coilpacks for a 92 svx?
    phi11 likes this.
  40. Bielke55
    $79.98 Each None in stock
  41. unhguy78
    yeah the medal performance pedals that replace the plastic stock pedals
  42. Bielke55
    They do NOT come with the dead pedal. Just Accel, Brake, and Clutch.
    $78.40 for this set
    $140.57 for this set
  43. predavore
    mmmm.... ooooo..... do you have the dead pedal option for these?
  44. Bielke55
    Nope do not...
  45. Wingman
    Oil Gasket = $.86
    In stock or no?
