Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. predavore
    predavore Well-Known Member
    Do these replace the stock ones or bolt on top?
  2. Bielke55
    Bolt right on top.
  3. predavore
    Do they hold up well? Something that bolts on top seems cheezy like ebay stuff. Are they any good?
  4. unhguy78
    unhguy78 Well-Known Member
    will both fit the 06 wrx? because I was reading and in 06 and after they use a wire throttle instead and a lot of pedals only fit the 05 and older models
  5. PaulasaurusREX
    '04 Outback cabin air filter. Price/Availability?
    Tanks
  6. Bielke55
    They will fit all years and models.
  7. Bielke55
    $31.96 and in stock
  8. Dynapar
    Can I get price and availability on:
    Axle back gasket for an 04 STi?
    Passenger side valve cover gasket 2002 WRX?
  9. unhguy78
    how much is the heat shield for the 02-07 spt intake?
  10. John16V
    John16V Well-Known Member
    Hi guys,
    Wondering if my BRP touch up paint and the 98RS gold center wheel cap (is it the right one?) here yet?
    Thanks
  11. John16V
    Double post...sorry
  12. Bielke55
    Axle back gasket for an 04 STi = $7.38 In stock
    Passenger side valve cover gasket 02 WRX = $10.36 Not in stock at the moment, more coming in Wed.
    $71.96 In stock
    Yes they are still here!
  13. Shibbs
    Brian, did my headlight come in yet? If so has it shipped yet as well?
  14. Bielke55
    Yes that has shipped out. Shipped out last week i believe
  15. Shibbs
    Excellent. I haven't heard jack from them yet, so I'm assuming no news is good news.
  16. idget
    When you get a chance, can I get price and availability on:
    cam seal
    oil pan seal
    valve cover gaskets
    intake manifold gaskets
    exhaust manifold gaskets
    all for a 92 svx
    thanks!
  17. Dynapar
    whoops. Meant drivers side valve cover gasket. Also the little gaskets/seals for the coil on plug holes?
    Otherwise I will be in towards the end of the week to get the axle back gasket for sure.
  18. 96zj
    96zj New Member
    Price and avalibility on: gas cap, 03 WRX
  19. Bielke55
    cam seals = $6.42 each x2
    oil pan seal (No oil pan seal. Just one oring for the pan = $12.10, one oring for the pick tube = $1.42, and two orings for the dipstick tube = $.74 each)
    valve cover gaskets:
    RH valve cover = $15.16
    LH valve cover = $15.16
    Spark plug tube seals = $6.36 each x 4
    Valve cover bolt seals = $2.14 each x 16
    intake manifold gaskets = 10.90 each x 2
    exhaust manifold gaskets = $8.40 each x 2
    Nothing in stock for the SVX...
    Yea there the same price per side. And $6.36 for the spark plug tube seals and all in stock.
    $15.96 for the cap and in case it breaks $1.22 for the clip that holds the strap to the door. Both are in stock
  20. 125cc
    125cc Well-Known Member
    Can you please provide a price for Subaru Part Number 82501AE03A. It is a relay. Quantity one (1).
    Thanks.
  21. Bielke55
    $8.14 One in stock
  22. Shibbs
    Can I get a price for a driver's power window switch for a 1982 El Camino Conquista please? 229 V6, 2bbl.
  23. thunderdan1313
    thunderdan1313 New Member
    o5lgt wagon
    so im look for the clip thing that hold the pass. headlight to the body.
    on the headlight u have the pole witha round tip that stick out the side its by the turn signal im looking for the clip that goes around the round tip.
  24. Bielke55
    About $5.00 for the clip.
    Not sure what your saying about the round tip... Theres a grommet clip that goes there... around $1.00 all are in stock.
  25. Frogy
    Frogy Well-Known Member
    I'm looking for the front and rear bumpstops for the struts, cousl you please order them in and I will pay for them when I pick them up, I tried to come in today but was just a little late. Car is 03 WRX sedan
  26. Tekko
    Tekko Well-Known Member
    Looking for price and availability on the SPT exhaust for 2010 sedan. Part number should be: D441SFG100
    Thanks
  27. Bielke55
    On order, they will be in on thursday.
    $703.99 For the exhaust and you'll need this new $16.00 donut gasket.
  28. thunderdan1313
    i will those also im look for the rear knuckle/arm for driver rear.
    o5lgt wagon
  29. Bielke55
    $193.88 In stock
  30. thunderdan1313
    could i get the part number/ pic of the part?
  31. Frogy
  32. thunderdan1313
    also looking for a rear wiper blade
  33. Bielke55
    20252AG00A = $193.88 In stock
    $11.96 In stock
  34. unhguy78
    how long does it take you guys to get parts when ordered?
  35. Bielke55
    we are on a daily stock order now. So its a 2 day turn around on normal order.
  36. thunderdan1313
    i will take the head light clip and the arm/knuckle thing. can i pick them up on friday?
    that knuckle is for the driver rear?
  37. Bielke55
    I'll make sure eveything is here friday. I thought you need the RH side. I gotta order the LH side.
  38. thunderdan1313
    ya i need driver side(leftside) thx for getting everything order u need my vin at all?
  39. Bielke55
    Last 8 if you have would be helpful
  40. thunderdan1313
    PM!!
    thanks again
  41. predavore
    What is a bluetooth adapter running these days? (08 wrx with navi)
  42. John16V
    Totally forgot about this.........be there Monday to pick it up. Thanks guys!
  43. badbennyb
    Any chance that a set of all 4 outside door handles for an 09+ forester(the black cheap model ones) are affordable? I'd like to get rid of the chrome.
  44. Bielke55
    Black Handles are $13.82 each x4
    The back protion of the handle in black is $5.36 each x4
    Total with tax would be $82.30
    Would need to order them all. 2 days for ordering
  45. badbennyb
    ^^^Actually thats not bad. I'll take a look at the car when my wife gets home and let ya know if I decide to go for it.
