Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. zyklon
    zyklon Well-Known Member
    Can anyone tell me what kind of hoops I have to jump through / how much it will cost to get a couple of keys made for my (anti-theft key equipped) 2006 WRX? I only have one key, am installing a remote start, so I'll need one for the bypass module, and i will get another as well for a spare.
  2. RexNEffect
    Need a left front fender, got any in stock?
    Also, need the plastic bracket for the fender that is under the right headlight, and the airfoil? insert for the bumper (unsure which side at the moment).
    2007 WRX
  3. Bielke55
    The keys are $47.96 you have to call and ask our service dept for labor price on programming the keys for the vehicle
    Fender is in stock $191.96
    Bracket is in stock $32.42
    The insert for the bumper comes painted so its not in stock. 2 days to get $29.50 either side
  4. Bheims
    Bheims Member
    Hi Bielke, just sent you a pm as well, how much is that diffuser after the 20%?
  5. RexNEffect
    I'll be in today for at least the bracket, maybe fender as well.
  6. John16V
    John16V Well-Known Member
    06 Forester
    Looking for that long plastic string thing that prevent the gas cap falling on the ground?!
    I looked it up and this came up 57651fc000. Is that right?
    Thanks
  7. Bielke55
    Yea not a good number. BUT 42031FE000 is a good number $15.96 in stock
  8. John16V
    Thank you sir, I'll be there next week to pick it up.
  9. Kevin
    Kevin Well-Known Member
    Oil pump for a 92 legacy turbo? And for a 08 sti?
  10. Bielke55
    $127.96 For the 92 Legacy Turbo Oil Pump
    $111.96 For the 08 STI Oil Pump
    Both are in stock
  11. phi11
    PIPE, EXHAUST ASSEMBLY MIDPIPE
    w/gasket
    44200FE180
    44022AA062
    44011AE010
    SPRING BOLT SET
    44044AA010 X2
    902350004 X2
    44059AA010 X2
  12. Bielke55
    w/gasket
    PIPE - 44200FE180 = $173.58
    DONUT GASKET - 44022AA062 = $6.80
    FLANGE GASKET - 44011AE010 = $7.18
    SPRINGS - 44044AA010 = $3.72 X2
    NUTS - 902350004 = $.67 X2
    BOLTS - 44059AA010 = $2.37 X2
    EVERYTHING IS IN STOCK
    phi11 likes this.
  13. unhguy78
    unhguy78 Well-Known Member
    how much to convert key entry to keyless entry?
  14. Kevin
    Oil pan for a 92 Legacy turbo?
  15. Bielke55
    Well that depends on what type of vehicle.
    $111.38 for just the pan. And we have it in stock (it superceeds to a newer style oil pan. So its the same pan as the EJ251 n/a engines)
  16. unhguy78
    06 wrx?
  17. Bielke55
    That should have keyless entry installed from the factory. Do you not have the remotes for it?
  18. unhguy78
    no I bought it used and it only came with the key. any advice?
  19. Bielke55
    Well you'll need a new remote for sure. It needs to be programmed to the vehicle.
    The remote is $95.96 with the discount
    The reprogram charge is $61.00
    If you do get the remote programmed to your 06 WRX you need to have all the keys and such with you at the time of the service appt.
  20. Tekko
    Tekko Well-Known Member
    Asked about this a couple weeks back, looking to finally get this. Can you get D441SFG100 and the donut gasket in stock for this Friday?
  21. Bielke55
    Yea I can order it for thursday
  22. Tekko
    Great I will be out there Friday to pick it up. Need any payment up front seeing as its a larger priced item?
  23. Bielke55
    No i'll trust you, but maybe a first name and phone number just in case?
  24. Tekko
    Sent you a PM, thanks!
  25. rsverv
    rsverv Well-Known Member
    price and availability for a subaru (wheel) center cap on a my05 lgt.
  26. Bielke55
    One in stock $31.96
  27. unhguy78
    do you have the spt intake and heat sheild in stock for 06wrx?
  28. Bielke55
    No, but i can order them up and have them both here on Friday.
  29. unhguy78
    ok that would be great! i can pick them up on Tuesday so as long as they're there before then. thanks!
  30. Bielke55
    My bad again fella.
  31. StanmoXT
    StanmoXT Well-Known Member
    I got an 05 Outback XT.... got my drivers side mirror taken off last night.... mirror housing is fine, but the mounting plate broke off of the door. With out seeing it what options do I have for a replacement mounting bracket? Pics can be supplied if needed.
    thanks,
    Scotty
  32. Bielke55
    The VIN is gonna be the most helpful at this point. If you can get me the last eight digits I can send you a parts catalog picture and we can go from there.
  33. WRX1
    I am looking for the parts to change out a timing belt for a 05lgt.
    Water pump
    timing belt
    tstat
    tensioner
    all 4 of the idlers
  34. StanmoXT
    54321690... thanks
    send to [email protected]
  35. Bielke55
    Water Pump = $119.96
    Water Pump Gasket = $3.18
    T-stat w/ Gasket = $23.96
    Timing Belt = $119.96
    Tensioner = $119.96
    Smooth Idler Pulleys = $59.96each x2
    Cogged Idler Pulley = $65.46
    Small Idler Pulley = $63.10
  36. Bielke55
    As you can see the mirror comes apart into many pieces. If you only need the base portion that is $79.96 and not in stock.
  37. StanmoXT
    Looks like i need 91031O <LH>
  38. Bielke55
    Yea thats what i was thinking too. $79.96 2 days to order.
  39. WRX1
    Can I return the idlers if I don't need them?? I just want to make sure I have everything on hand, just in case. Also, do you have it in-stock or would you have to order this stuff?
    Thanks
  40. Bielke55
    You can return the idlers if you dont need them that is fine.
    Everything BUT the tstat is in stock. For some reason the the LGT's have a different t-stat then all other subarus.
  41. StanmoXT
    Sweet thanks!! Let me know and ill come get it
  42. burtonboy00
    burtonboy00 Well-Known Member
    Do you have or could you get an 09 STi spoiler?
    Thanks!
    -Nate
  43. Bielke55
    $292.74 need to order. It does NOT come painted
  44. burtonboy00
    Good to know, thanks!
    Sent from my Droid using Tapatalk
  45. Wingman
    Wingman Active Member
    73422FE031 Sti AC line.
    Does the above line include the high pressure, low pressure, and one that goes under the tmic up to the front of the car? Any in stock?
