Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. Bielke55
    That line is only from the compressor to the evaporator (low oressure line under the I/C) $184.36 for the one, Not in stock need to order.
  2. Bielke55
    Maybe this can help show the A/C line i'm taking about. Its the one label 73422
  3. Wingman
    Wingman Active Member
    I just need the 73176*C.
  4. Bielke55
    Those are the o-rings. Do you need just one?
  5. badbennyb
    Can I get a price check on a trailer hitch for an 09 Forester. Whenever you get a chance, no rush.
  6. Bielke55
    Stop Rushing me !!!
    $311.96 Got a whole bunch in stock.
  7. badbennyb
    Thanks for rushing! thats almost as much as the boat I wanna buy :) I'll let ya know if I go through with it.
  8. Bielke55
    Gotta have something to tow a boat with!
  9. Wingman
    I'll give you guys a call before the weekend.
  10. Scoobaru
    Scoobaru Member
    Brian,
    I am looking for the rear wiper motor relay for my 97 OBS. would you happen to have it in stock?
  11. Bielke55
    $15.14 No stock, i would have to order it
  12. roryk
    roryk Member
    I am going to need a clutch hose. The one numbered 37251 in the diagram that you had posted in the thread.
  13. Bielke55
    Hose is $18.30 no stock
    Gaskets are $.74 each
  14. vanddelor
    vanddelor Well-Known Member
    I'm looking for stock sti piston rings, how much for a set?
  15. Bielke55
    For the standard sized piston rings (Non Oversized) its $106.20 for the set. No stock need to order
  16. the_webers_inc
    the_webers_inc Well-Known Member
    Any Extra S Gear Oil on hand? Looking for 5 qts.
  17. Bielke55
    Plenty in stock
  18. the_webers_inc
    Cool. I'll be in tomorrow to pick some up.
  19. LilRed
    LilRed Well-Known Member
    How much is it for the emblem that covers up the two holes in the 07 sti trunks?
  20. J.Rex
    J.Rex Well-Known Member
    for an 07 wrx, 4/2 pots, i need the thin metal peice that pushes the pads in towards the rotors and sits on top of the caliper, held in by the two pins, both front and back, 1 each. Thanks
  21. RexNEffect
    '95 Impreza rear rotors/pads. Right front CV axle.
    EDIT: Also, 2007 WRX clutch.
  22. qstarin
    qstarin Well-Known Member
    Hey guys, just a heads up here.
    I've got a hood and under-hood insulator that's been sitting there with you for a couple weeks.
    Today my GF is going to swing in and drop a bumper back off.
    I'll be bringing my car to Long Lake body shop in the morning and they'll have a runner bring the hood, bumper, etc. from Mtka to LL.
    Just letting ya'll know so you're not like "why the heck is this gal bringing us a bumper." ;-)
    Thanks!!
  23. carl
    Did the headlight and axle boots arrive?
    thanks,
    carl
  24. idget
    Can I get a price check on a 1992 svx purge control solenoid.
    It mounts under the intake manifold and is connected between the fuel purge can and the intake manifold.
    thanks!
  25. accord917
    accord917 Well-Known Member
    Can I get a price on a set of front pads for a 08 forester (sport)? Also, price for the rear cup holder (grey interior).
    thanks,
    Jay
  26. glen
    glen Well-Known Member
    Need a pair of 02 WRX head gaskets, got em in stock? I'm sure I need more stuff too, but those are top of the list for now. Thanks.
  27. John16V
    John16V Well-Known Member
    Need a 00's RS Auto transmission filer w/ washer.
    6-8 qts of ATF.
    Thanks
  28. Bielke55
    Lets see if I cant get this caught back up now that i'm back from Vacation.
    $35.06 In Stock
    Front $12.92 In stock
    Rear $2.08 In stock
    Think I got you taken care of already.
    You are done and gone
    The pictures suck. But I think this is the one you want. $30.32 No stock
    Front Pads $75.96 In stock
    Rear Cupholder $39.46 In Stock
    $34.46 And In stock
    $25.26 For the Filter. We only have 5spd gear oil in quarts (extraS) so as for ATF/Dexron You'd have to find some locally.
  29. carl
    hey guys can you order me in some stuff? It's basically all the stuff you'd replace when doing a front diff.
    I attached the pages from the manual and circled the stuff - let me know if you have questions or if any of it will take longer than a week to get.
    2004 STI
    front input oil seal (#12 on pg 3)
    roller bearing x2 (#3 on pg 12)
    oil seal x2 (#5 on pg 12)
    o-ring x2 (#7 on pg 12)
    circlip x2 (#10 on pg 12)
    thanks,
    carl
  30. badbennyb
    Can I get a price check on an OBP(or whatever the 05 sti black is) passenger side fog light bezel thing, the one with the hole not the sti cover one. Thanks.
  31. Bielke55
    I will order them up for you now.
  32. Bielke55
    $63.14 Painted and not in stock. Need to order
  33. piddster
    It is possible to get a new hood release cable? Or does it come as an assembly? Throw me a price either way.
    1993 Legacy.
  34. burtonboy00
    burtonboy00 Well-Known Member
    Hey I'm looking for a CV boot for an 09 Impreza, I need one asap, much thanks!
    Sent from my Droid using Tapatalk
  35. rsverv
    rsverv Well-Known Member
    price and availability on ball joints, inner and outter tie rods for MY01 RS.
  36. accord917
    Thanks. I'll be coming by during the lunch hours to pikc these up :)
  37. J.Rex
    Can you get just the metal band that holds a cv boot on, the larger band, on a front right axle, on the tranny end, 07 wrx? Or one that will fit that I can put myselft on since the one I cut off needs some tool/machine to put on. Also, do you have the nasty green goo to put in there in stock? One CV cup's worth?
  38. Bielke55
    We have the bands in stock. As for grease we just use bulk
  39. predavore
    predavore Well-Known Member
    Pulled from www.getmoregs.com... are these bushings available for purchase and will they fit the 08-10?
  40. AWDimprezaL
    We do not have 2011 catalogs for the impreza yet.
    phi11 likes this.
  41. Bielke55
    We dont have a catalog yet for the 2011's But as soon as we do i'll let ya know.
  42. WRX1
    Looking for the drive door window switch assembly for a 05 lgt.
  43. AWDimprezaL
    If you make it out tonight, $112.46, IN STOCK.
    phi11 likes this.
  44. snwbdr94
    snwbdr94 Well-Known Member
    How much for a drum of extra S?
  45. WRX1
    And one last thing.
    Front wiper blades (both side) and 2 rear blades for my 09 fxt.
    Also, I will bring Brian's hat with me tonight.
    Thanks guys.
