Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. Bielke55
    Do you want a full one or empty one? Dont forget we sell extra-s by the Quart also.
    Drivers = $21.56
    Pass = $15.96
    We dont have a passenger blade in stock though.
    $11.96 each X2 for the rear blades. In stock
    I have cash thank you for bring my hat!
  2. snwbdr94
    snwbdr94 Well-Known Member
    How much is it for the full and how much for 5qts? One last thing is the super blue coolant.
    I'll more then likely swing out that way tonight. I'm slowly getting the 60k maintenance completed.
  3. Bielke55
    For a 20Liter Barrel of Extra-S its $169.00
    Its $8.07 per quart
    We have some in stock, Not enough for 4 quarts unfortantly.
    As for the Super Coolant (Smurf Juice) $18.36 per premix gallon, So you would need 2 gallons for a drain and fill.
  4. dingbang
    dingbang Member
    Wondering if I could get a price and shipping quote to Rochester (55904) for the following parts for a 2006 LGT 5MT...
    Transmission gasket and seal kit (as long as it has all the main transmission gaskets and the main shaft front oil seal).
    Main shaft needle bearing as well.
    if you have the time what would be the cost for just the few main transmission gaskets and main shaft front oil seal...was thinking it would probably just be better to get the full reseal kit.
    Thanks
  5. Bielke55
    $72.22 No stock, but since its Friday i'll ship for free to SEMN.
  6. dingbang
    dingbang Member
    Got a number I can call you at to confirm order/receive timeline and give you billing info? Thanks
  7. Bielke55
  8. dingbang
    dingbang Member
    sent u a pm about pricing out for some new flywheel bolts as well, thanks
  9. HYPERION-X
    HYPERION-X Well-Known Member
    How many quarts of Extra-S do you have in stock at the moment?
  10. ofspunk7
    I have a set of Dark Blue Subaru Injectors. Do you have these 3 O-rings in stock or how long would it take to get them? How much are they?
    Thanks
    (Sorry this is the only pic i could find with all the O-rings, i know these aren't the Dark Blue Ones)
  11. snwbdr94
    Bielke are you able to get 5 qts of the extra-s before Friday? I need to stop putting this off lol
  12. Bielke55
    Yes we have a full drum
    I dont know where the Dark Blue Ones came from... Any other info to be safe?
    Yea have plenty in stock now.
  13. Nuke
    06+ wrx
    07+ sti
  14. ofspunk7
    Thanks
    It's all good, I wasn't sure if you guys were going to get to this today and I need them Friday so I had WB order them. It turns out that all subaru injectors use the same size anyways, so it really doesn't matter what year or color (I didn't know that).
  15. Bielke55
    Thank you
    Referring back to the attached photo
    1. $2.14 No stock
    2. $8.42 1 In stock
    3. $8.74 1 In stock
  16. Bielke55
    Hmmmm okay... I dont believe that one bit. I hope that works for ya.
  17. ofspunk7
    Why do you say that?
    EDIT: had to go with WB because i needed the parts by Friday more than the discount.... didn't want to wait and miss my delivery window
  18. pattertj
    pattertj Member
    Price and availability for the exhaust hanger with the attached nut for an 05 RS A/T?
    Does that include the bolt as well?
  19. Bielke55
    The one off the back of the tranny? Or the ones in the rear for the muffler?
  20. pattertj
    pattertj Member
    Back of the Transmission.
  21. EBR15
    EBR15 Well-Known Member
    Left rear door card for 05 sti? I assume it's all one piece?
  22. Kevin
    Kevin Well-Known Member
    04 wrx wagon front bumper in PSM? and both inner fender liners?
  23. predavore
    predavore Well-Known Member
    Hey guys... I was in there last week to pick up some extra-s. I got home and realized you sent me ATF. I've been out all week (my little boy was born Monday). Anyways... I need to figure out a time to get back over there and swap it out.
  24. Bielke55
    $11.58 For the hanger
    $0.66 For the bolt that holds the exhaust
    $3.16 X2 For the bolts that attach the hanger to the trannsmission.
    No stock need to order on all the parts
    $270.94 No stock need to order.
    $199.96 For the bumper, They are all UNpainted.
    $30.00 each for the Fender liners
    Everything is in stock.
    Is it actually the RED Fluid ATF-HP? Cause we reuse those bottles for Extra-S
  25. predavore
    I think it's the red stuff. The caps don't look like the seal has been broken. The bottles are not dirty at all on the outside. I'd like to think that someone would re-label or X out the label when a different fluid is put into those bottles. (after they are thoroughly cleaned of course)
  26. WRXEcho
    WRXEcho Well-Known Member
    I need the ABS speed sensor, front pass., and both front inner fender liners. (02 wrx wagon)
    Thanks,
    Justin K.
  27. AWDimprezaL
    as of monday we have GOLD bottles that extra S comes in, so there will be no confusion. Derek, lemme know when you wanna do a swap for some right stuff.
    phi11 likes this.
  28. bobafett04wrx
    bobafett04wrx New Member
    Price and availablity on a front o2 sensor for 04 wrx.
  29. silver03
    pass side steering rack boot 03 wrx. thanks
  30. Kevin
    clutch fork for a 98 forester L?
  31. J.Rex
    J.Rex Well-Known Member
    How much for a passenger side fender for an 07 wrx sedan and can you get one by Wednesday?
    Also how much for a right rear door shell?
  32. Bielke55
    $130.82 For the ABS Sensor
    $32.00 Each for the Fender Liners
    Got both in stock
    $191.96 Got one in stock.
    $19.86 No stock.
    $19.42 One in stock
    $191.96 for the fender, and we have one in stock.
    $403.96 for the RR door, do not stock the shell.
  33. demong
    demong Well-Known Member
    How much would it cost for a ball joint for a 96 subaru impreza lx coupe?
    How much does it cost to actually dissassemble the ball joint assembly?
    How much would it cost for service to remove stripped bolts and replace them?
    How much would it cost to do a bolt and screw loosen up "service"?
  34. Bielke55
    $33.98 For just the ball joint.
    You would have to ask service for all of those other questions.
    952-797-1352
  35. HYPERION-X
    Looking for part #35047AC030 and hoping this will cure my side to side shifter wobble. Can you verify this is the correct joint for a 2003 WRX please?
  36. Bielke55
    That is the correct joint with bushings. Does not come with a roll pin though. We do have it in stock also
  37. HYPERION-X
    I planned to reuse my roll pin but just in case do you stock that too? How much is the joint?
  38. Bielke55
    Yes to the pin.
    $46.70 for the joint
    $2.08 for the pin.
  39. prezawagon
    prezawagon Well-Known Member
    I need a front axle for a 2003 wrx wagon. I'm assuming the I need the passenger side, but the axles are interchangeable left/right, correct? All the boots are still intact, but something is obviously clicking up there. Thank you.
  40. badbennyb
    Maybe it's normal out there but I saw 4 seperate super troopers on 394(E&W) while heading out to morries today. FYI for anyone heading to or from the area. Thanks for the filters! You know you guys are good when I ride my bike way outta my way on a hot humid day for oil filters.
  41. Topher
    Topher Well-Known Member
    Trying to track down a hitch:
    L101SAG000
  42. Bielke55
    PM replied
  43. Topher
    Thanks! That was easy. I'll pick it up Thursday.
  44. carl
    please pm me the rally team price on a front subframe for a 2004 impreza (whatever is cheapest between a rs, wrx, sti)
  45. silver03
    gallon of coolant and bottle of treatment please
