Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. AWDimprezaL
    You dont want that junk in your car (the conditioner) it was orginally made to seal up coolant leaks in na SOHC 2.5s (head gaskets) ive seen it plug passages in turbo banjo bolts.
    $18.10 for the coolant.
    Conditioner is 3 bucks or so, but we're out of it.
    phi11 likes this.
  2. thunderdan1313
    thunderdan1313 New Member
    had the car towed after avoiding a deer an nailed some rocks let me know what it needs thx
  3. 02subbieRS
    02subbieRS Well-Known Member
    I'll be up there around 10 to get the rear struts replaced. Is there a certain Service Tech I should ask for to get our discount or will anyone give it?
  4. AWDimprezaL
    Just mention mnsubaru, everyone will know.
    phi11 likes this.
  5. thunderdan1313
    does the discount work for autobody???
  6. Bielke55
    No it does not. Only really works if you buy the metal for a discount. And then pay full price for painting.
  7. 02subbieRS
    Thanks guys. The rear finally doesn't clunk! :) My wallet still hurts though :(
  8. MBOUTBACK
    MBOUTBACK Active Member
    You guys are doing a head gasket for me on my '00 OB. I love that car, take care of it for me!
  9. AWDimprezaL
    indeed!
    phi11 likes this.
  10. blackozone
    How much would a radio surround for an 06 WRX TR cost? (Mechanical HVAC)
    Also, I'm looking for a radio bracket for 05-07 Impreza.
    Thanks!
  11. Zap
    Zap New Member
    I need a head gasket set for a SOHC 99 Forester, and may or may not need replacement head bolts for one side (reuse em?) ... ?
  12. Bielke55
    For the surrond thats a tough one with out the VIN. Since the catalog doesnt tell me trim colors and/or auto or manual HVAC.
    The brakcets are $3.58 each, No stock though.
    For a good head gasket kit that we have in stock (Minus Fluids) its $159.50 before tax. As far as the head bolts its up to you. If its the first time doing the H/Gs then reuse the bolts. If its the second time then replace them.
  13. blackozone
    Trim color isn't important, I believe all TR's had manual HVAC (unless someone can correct me?)
    phi11 likes this.
  14. tangledupinblu
    Could i get a quick pricing from you guys?
    My 02
    -Outer Tierod ends+castle nutz
    -front swaybar endlinks
    -front swaybar bushings
    kthnx!
    phi11 likes this.
  15. Bielke55
    I believe this is the one. Not completly sure. But 61.52 for you, not in stock.
    Looks like we have it all in stock (Only one outer Tie Rod End). Assuming you havent changed the size of your front bar also.
    -Outer Tierod ends = $43.96 each
    -Castle nutz = .23 each (We also have bulk Cotter Pins)
    -Front swaybar endlinks = $24.80 each
    -Front swaybar bushings = $14.60 each
  16. tangledupinblu
    Thanks Brian!
    phi11 likes this.
  17. predavore
    predavore Well-Known Member
  18. kwikrs
    kwikrs New Member
    whats the price and availability on a 2011 legacy all weather floor mats and truck mat?
    THanks
  19. demong
    demong Well-Known Member
    how much would it cost for an Alignment on my 96 Subaru Impreza LX coupe?
  20. blackozone
    Also need pricing for a rear wheel bearing job on an 05 STI.
    I beileve these are the part numbers I need:
    - (2) Rear Wheel bearing - #28016PA010
    - (2) Oil Seal #1 - #28015AA080
    - (2) Oil Seal #2 - #28015AA070
    - (4) Rear Axle nut - #28044AA001
    - (2) Rear lateral link bolt - #20540AA000
    - (2) Washer - #900335056
    - (2) Nut - #20550AA010
    phi11 likes this.
  21. Bielke55
    I can only find that part in the 2011 Impreza Parts Catalog. $62.38 Not in stock
    For the legacy mats its $47.96, 1 Set in stock
    Contact the Service dept. I wont know there pricing on that. 952-797-1352
    - (2) Rear Wheel bearing - #28016PA010 = $77.68 each No Stock
    - (2) Oil Seal #1 - #28015AA080 = $8.56 each In Stock
    - (2) Oil Seal #2 - #28015AA070 = $7.06 each In Stock
    - (4) Rear Axle nut - #28044AA001 = $3.50 each Only 2 In Stock
    - (2) Rear lateral link bolt - #20540AA001 = $17.30 each In Stock
    - (2) Washer - #900335056 = $0.94 each In Stock
    - (2) Nut - #20550AA010 = $4.90 each In Stock
  22. blackozone
    Alright, I'll need to order some of this up tomorrow. Can you ship?
    phi11 likes this.
  23. Bielke55
    With tendering loving care
  24. blackozone
    Sounds like I need to call you. What's the number there, 1-900-HOT-NUTZ?
    phi11 likes this.
  25. predavore
    Can you post up a link of an image and what it includes?
  26. Bielke55
  27. predavore
    Cool, I'll pull the cover this weekend and see if I have the mounting points and plug for it. Are there any other required wires/connections/parts?
  28. Musashi
    Hi guys, I'm looking for a cam seal (driver side) for my 99 Forester. If you could provide me a part # and a price I'd really appreciate it. Many thanks!!!
  29. Bielke55
    806732150 = $6.42 In Stock
  30. Musashi
    I'll stopby next week. Many thanks!
  31. rsverv
    rsverv Well-Known Member
    Price and availability for all weather mats for MY05 LGT and weatherstrip on the cowl panel for MY01 RS. Thanks.
  32. Bielke55
    $39.96 For the All weather mats, In stock
    $6.00 For the seal on cowl panel. Not in stock two days out on a normal stock order.
  33. rsverv
    Please place an order for the seal and I'll be in next week to pick up both. Thanks!
  34. accord917
    accord917 Well-Known Member
    I am looking for P/N and cost for the following.
    1) AT Fluid for an 05 impreza (5 quarts)
    2) AT Fluid for an 08 forester (5 quarts)
    They are different for those two year correct? The forester uses the ATF-HP?
  35. Bielke55
    Ordered up
    05 Impreza - Dexron3 = We only have it bulk so we can really sell it
    08 Forester - Subaru ATF HP Fluid = $6.86 a quart
    Subaru used the ATF-HP fluid in all the 06+ models with a A/T and 5A/T
  36. Musashi
    Turn's out I found two new ones from my old Subaru stuff. I really appreciate you going thru the trouble of getting me this info. Many thanks.
  37. STiM
    STiM Well-Known Member
    Could i get a price on some stuff for my 04 FXT?
    1. 3 oil filters and washers.
    2. 4 P/N 803912040 (Looking to remove those filters from the banjo bolts and need new washers, TSB 02-97-05)
    3. Just the mirror part for the drivers side mirror.
    4. Rear wiper blade.
    Also, what shipping would be to 55963. Thank you!!
  38. rsverv
    I need the plastic black piece that holds the hood stand down for MY05 LGT and the top molding piece that goes above the windshield along w/the clips to hold it down for MY01 RS. If not in stock, please order. I'll be in to pickup the parts including mats and seal by the end of the week if ready. Thanks.
    [​IMG][​IMG]
  39. vanddelor
    vanddelor Well-Known Member
    I need a few parts for 02 wrx hybrid.
    Oil pump seal
    O-ring for oil pump
    O-ring for oil pan
    O-rings for crossover pipe
    STi headgasket
    valve cover kit
    4 cam seals
    Intake Mani-TGV gasket
    TGV-Heads gaskets
    Throttle Body gasket
    thanks.
  40. Bielke55
    1. Oil Filters = $5.27 each x3
    1a. DP Washers = $.67 each
    2. Banjo Bolt Washers = $1.23 each x4
    3. LH Side View Mirror Glass = $71.74 (Not In Stock)
    4. Rear Wiper Blade = $11.96
    Shipping is free for orders over $75.00. Orders under $75.00 is $4.00 for local speedee area.
    Hood Stay Clip = $3.40
    W/S Moulding = $23.04
    Clips = $1.94 each x5
    Need to order those parts for Wednesday. On order
    Oil pump seal = $6.86
    O-ring for oil pump = $1.62
    O-ring for oil pan = $12.10
    O-rings for crossover pipe = $3.14 each
    STi headgasket = $34.36 each
    valve cover kit = $89.36
    a. LH V/C = $10.36
    b. RH V/C = $10.36
    c. Spark Plug Seals = $6.36 each x4
    d. V/C Bolt Seals = $2.70 each x16
    4 cam seals = $4.76 each
    Intake Mani-TGV gasket = $8.42
    TGV-Heads gaskets = $4.46
    Throttle Body gasket = $5.78 (Not in stock)
    Everything is in stock minus the Throttle Body Gasket
  41. curly2k3
    I see the STI headgaskets are $34.36 each, what is the thickness of them again? its been a while. I'd be picking them up for my 20k/20g hybrid or a STI/20g hybrid for reference, so I know the stupid 20k pistons clear the deck a bit more.
  42. AWDimprezaL
    The 257 gaskets will not work on your 20g.
    phi11 likes this.
  43. ViktorVaughn
    ViktorVaughn Active Member
    For a 2008 STi:
    2 bulbs for headlights
    barrel of extra-s transmission/diff fluid
  44. accord917
    Great Thanks. So I cannot buy AT fluid for the 05 impreza through you guys at all? Cost to buy in bulk?
    I also need the AT filter for both vehicles (both are wagons BTW).
  45. Bielke55
    STI HID bulbs $143.96 each, No stock
    For a barrel of Extra-S = $159.06
    We do have some bottles of subaru's at/psf fluid $6.24 per quart. I only have 6 bottles in stock.
    AT filters are $25.26 each, I have 2 in stock.
