Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. accord917
    accord917 Well-Known Member
    I'll come by tomorrow to pick up 5 quarts of the Subaru ATF HP Fluid and the 2 AT Filters.
    thanks
  2. WRX1
    So are you guys doing another winter tire GB or have any deals currently going on winters??
  3. AWDimprezaL
    For mn subaru its $5 over cost, year-round.
    phi11 likes this.
  4. WRX1
    What brands are you carrying this winter? I am kinda looking for the generals but I am open to other brands.
    Thanks
  5. AWDimprezaL
    goodyear
    Michelin
    uniroyal
    continental.
    general
    dunlop
    kumho
    phi11 likes this.
  6. Bielke55
    Fixed for clarity
    Goodyear - Ultra Grip's , GW2's , GW3's , Eagle Ultra Grips
    Michelin - X Ice Xi2's
    Uniroyal - No Snow/Winter's
    Continental - Extreme Winter Contact's
    General - Altimax Artic's
    Dunlop - Graspic DS3's , Winter Sport 3D's
    Kumho - No Snow/Winter's
    Bridgestone - Blizzak's (upon special request with time to order)
    Firestone - Winterforce's (upon special request with time to order)
  7. John16V
    John16V Well-Known Member
    Any Extra-S in stock? How much a quart and I need them for my tranny and for rear diff.
    Thx
  8. Bielke55
    Just cracked a new barrel yesterday, plenty in stock $8.07 a quart
  9. Tekko
    Tekko Well-Known Member
    Looking for a set of 4 Continental ExtremeWinterContacts 205/55R16 and a set of wheels (if possible) to mount these on. What price would I be looking at?
  10. Bielke55
    Those tires would be $104 each, Need to order, Not avaiable until 11/10/10
    As for wheels... your better off checking the forum for some used WRX wheels
  11. JasonoJordan
    price on carrier bearings in the final drive of a 05 sti tranny. or do u need the serial # to pull up
  12. eterenity11
    eterenity11 Well-Known Member
  13. Bielke55
    If you have a vin or even a general picture of what your looking for it would help.
    Carrier pigeon resent
  14. Jackstand
    Jackstand Well-Known Member
    How much for both front driveshafts on a 02 WRX wagon? 5speed
  15. Bielke55
    $143.96 each with a $80 dollar cores charge ($40 each) in stock
  16. Jackstand
    I keep finding more ****... How about a tranny dipstick
  17. Bielke55
    $8.14 Not in stock, need to order
  18. Jackstand
    Please order that for me
  19. 02WRXwagon
    02WRXwagon Well-Known Member
    May I get a price on the following for my '07 Impreza 2.5i:
    Front Pads
    Front Rotors
    Rear Pads
    Rear Rotors
    Hardware kits
  20. predavore
    predavore Well-Known Member
  21. KRYPTO
    KRYPTO New Member
    Price for gasket set and timing belt kit for 98 Legacy Gt 2.5 DOHC
    Also price on labor if I drop the motor off to do the head gaskets and engine overhaul along with timing belt.
    Thanks
  22. Kevin
    Kevin Well-Known Member
    price and avail. for a rear brake hose... 95 impreza 2.2L
  23. Bielke55
    what side?
  24. Bielke55
    On order for Thursday
    Front Pads = $75.96
    Front Rotors = $78.36
    Rear Pads = $63.96
    Rear Rotors = $75.96
    Hardware kits = Pad Kits come as full hardware kits
    We cant take back electronic parts... which of those did you want? The media hub or the ipod interface?
    $253.60 for the engine gasket kit
    $378.30 for the Timing belt, Tensioner, and three idler pulleys
    $107.14 for the water pump and its gasket
    As for labor you will have to call service and ask them about labor prices
    952-797-1352
  25. Kevin
    driver side
  26. Bielke55
    ABS or Non ABS
  27. Kevin
    non abs
  28. Bielke55
    $16.42 not in stock need to order two days out
  29. Kevin
    can you order for me please
  30. KRYPTO
    KRYPTO New Member
    I plan on going Turbo with the motor, will the head gaskets in the set work? Also do I need new head bolts?
  31. pattertj
    pattertj Member
    What does the new Subaru 5w-30 Motor Oil run? I'm due for an oil change in 200miles... Does it only come in synthetic?
  32. Kevin
    hoping this got ordered.... aslo a rear O2 sensor for 95 impreza 2.2
  33. predavore
    The media hub. I have the ipod interface now. How much is that?
    Also, what was the price on the phone controls?
  34. KRYPTO
    KRYPTO New Member
    Do you sell an overhaul kit?
  35. Bielke55
    Part is on order and will be there wednesday. The O2 sensor is $111.96 and in stock.
    I dont think the 2.5 DOHC n/a head gaskets will work. Maybe the STi gaskets
    $5.80 per quart
    $21.56 per gallon
    And yes only synthetic
    Phone Controls = $62.38 no stock
    Media Hub = $239.96 no stock
    Media Hub with streaming bluetooth = $279.96 no stock
    Just an engine gasket kit
  36. idget
    Can I get price and availability of the 3 camshaft/crankshaft position sensors for a 1992 svx?
    I don't have the part numbers off hand but 2 of them have a straight bracket and the third one has an l-shaped mounting bracket if that helps.
    thanks!
  37. idget
    dunno if this picture helps but it's #4 and both of the #5's (the #5 next to #4 and the other #5 on the driver's side). thanks!
  38. AWDimprezaL
    The STI Gasket WILL NOT WORK ON THE N/A DOHC. Unless you are running different pistons.
    phi11 likes this.
  39. Bielke55
    One crank sensor and two Cam sensors = $182.94 each, no stock
  40. idget
    Thanks Brian! I'm going to try a working set tonight or tomorrow then let you know which ones (if any) I end up needing.
  41. RichWRX
    RichWRX Well-Known Member
    need 5 wrx valve cover bolts with the rubber grommets. Or just the grommets if they are available seperatly.
  42. pksublime
    pksublime Well-Known Member
    i think brian told me that we needed a knock sensor for our 2002 2.5rs - how much?
  43. idget
    Scratch that... might be something else... need to do more tinkering :rolleyes:
  44. pattertj
    pattertj Member
    Can I get the exhaust hanger off the back off the transmission for a 2005 RS with Automatic Tranny? Any chance I can grab it tomorrow at the Rally Party?
    Thanks!
  45. pattertj
    pattertj Member
