Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. ofspunk7
    Bump - checking to see if I should drop by after work today.
  2. AWDimprezaL
    We do not stock it. I could get one for tuesday.
    phi11 likes this.
  3. ofspunk7
    ok, do you know how much they run? If those square ones work i won't have to order anything.... Will someone be around for me to check out those square plastic nuts? I am guessing around 3:30 - 4:00 tonight.
  4. silver03
    front endlinks 05 LGT. thanks
  5. Mr. Bill
    Mr. Bill New Member
    Hey Brian, could you shoot me a price on the center plastic piece on the top of the dash that houses the clock? 04 WRX Wagon. Have an idea, trying to see what the price of entry is.
  6. flstffxe
    flstffxe Well-Known Member
    Can I get a PM with a price for a front bumper cover.
    '08 Forester X
  7. WRX1
    I am looking for the the price on wiper blades for my 09 fxt. I am looking for the original style 1 piece blade/holder. Also for ****s and giggles, what does a new hood cost and if it comes painted or not.
    Thanks
  8. G_2.5rs
    G_2.5rs Well-Known Member
    you guys have any extra s left? needing 4 qts
    need all the bolts that hold the headlight together.
    also need the rear sway bar mount for the passeger side, but just the metal piece though.
    this is all for a 99 impreza rs.
  9. Bielke55
    $24.80 each, In Stock
    $57.40 Not in stock
    $175.96 not in stock
    We dont stock the full blade assy, only refills.
    LH Blade = $21.56
    RH Blade = $15.96
    Hood = $311.96 Not painted
    Yes we have lots of Extra-S
    When you say bolts that hold them together? Like you sepreated the lens and the body and theres bolts somewhere within that process? Or bolts that hold the headlight the core support?
    $4.34 Each for the metal clamps. And I have 1 in stock.
  10. G_2.5rs
    ones that bolt the headlight to the core support... will stop in after work today for the extra s..how long you guys open til?
  11. Bielke55
    Until 7pm tonight.
  12. flstffxe
    What kind of lead time should I plan on to get one in.
    Price on the following:
    86532SA060
    86538TA010
  13. driftin240
    driftin240 Well-Known Member
    Wiper Arm $37.58 in stock.
    Arm Cap $1.52 in stock.
  14. flstffxe
    ^^ How long to get the front bumper in?
  15. Bielke55
    2 Days from the day we orderd. e.g. I order today and I see the bumper cover on Thursday
  16. flstffxe
    ^^ Sweet, thank you.
  17. G_2.5rs
    spark plugs and wires for 99 rs
  18. rsverv
    rsverv Well-Known Member
    Price and availability for plastic male clips that goes on the RS side skirts. #4 in the image below. I believer part# is 91167AA110 for MY01? Need enough for one side. Thanks.[​IMG]
  19. ofspunk7
    Can i get a price for the front and back emblem (Subaru Stars) for an 09 WRX hatch?
  20. Bielke55
    Spark Plugs are $1.86 each
    Spark Plug Wires are $42.36 for the kit
    Those clips are $1.01 each, I dont have any in stock. There is 7 per side.
    $33.86 Rear
    $46.42 Front
    I only have a front emblem in stock.
  21. rsverv
    Order please. Thanks
  22. blackozone
    Price and availability of PN 22659AA120 (IACV gasket) and I'm looking for the bracket in the attached image (22). It's a bracket for mounting the central air vents in the dash of an 05-07 Impreza.
    phi11 likes this.
  23. Bielke55
    Bracket is $2.16 No stock need to order.
    The gasket is $5.06 In stock
  24. G_2.5rs
    looking for the torque box seal. looks like this:
    for my 99 rs.
  25. rsverv
    ETA? Thanks.
  26. Bielke55
    They are here
  27. G_2.5rs
    also looking for an oil pressure switch for my 99 rs.
  28. RichWRX
    RichWRX Well-Known Member
    Need a key and a remote for a 2011 forester . Do you need the car there or can it be made off the vin?
  29. John16V
    John16V Well-Known Member
    Well be there today to pick up my (for the side skirt) bolts and clips.
    Also please order for Tony @ Hamline Auto Body (if they have not done so) on these:
    Protector Rear Arch
    -91131FA021 (R)
    -91131FA031 (L)
    Clip Protector (Please check but I believe is 2 per side?)
    -91132FA030 (R)
    -91132FA040 (L)
    Thanks!
  30. Bielke55
    $16.99 For the switch.
    I can seem to find that one part in our catalog.
  31. Bielke55
    Did you get my message back?
    Just to be safe, i'll wait till he gives us a call to order the parts.
  32. Peng09
    Peng09 Member
    I need two oem 09 wrx wheels. I already have two so I need two more to put my summer tires on them, thanks.
  33. G_2.5rs
    what about just the filter then?
  34. badbennyb
    We may be in the same situation with our 09 Forester. We've been searching but seem to be down to one set at the moment. What would it cost/take for a replacement?
  35. qstarin
    qstarin Well-Known Member
    Thanks for the key this morning, worked perfectly!
  36. TMF
    Bielke55...just sent you a PM
  37. Bielke55
    $287.97 each, Those are the darker silver wheels correct?
    With the newer Subaru Keys, We have to send in a request for subaru to cut and ship the keys to us. They charge $40.00 (per key) to do so, on top of the price of the key. The key and(or) remote needs to be programed to the vehicle, ALL keys and remotes need to present at the time of the reprogramming.
    To summerize:
    Key - $54.36 each (un cut)
    Remote - $103.96 each
    Cutting & Shipping - $40.00 (per key)
    Service Charge - $65.00
    Great!
    Replied
  38. PaulasaurusREX
    Quote on front rotors and pads for 2007 wrx wagon.
  39. Bielke55
    PADS $119.96
    ROTORS $79.96 EACH
    All in stock
  40. snwbdr94
    snwbdr94 Well-Known Member
    Prices for 08 wrx axle seals, pilot bearing, turbo stud. All I can think of currently thanks
  41. Bielke55
    LH & RH Axle Seals = $6.22 each In Stock
    Pilot Bearing = $9.78 In Stock
    Studs on the Downpipe side of the turbo = $6.86 each Not in stock
  42. snwbdr94
    What would the time frame look like if you ordered one?
    Also need the following gaskets turbo to dp along with up pipe to turbo
  43. Bielke55
    Two Days to order.
    $11.50 UP to turbo
    $18.18 turbo to DP
    Both in stock
  44. accord917
    accord917 Well-Known Member
    Please quote front and rear brake pads for a 2005 9-2x Linear (2005 WRX Wagon). Thanks
  45. bluegc
    bluegc Member
    price n availability for spt oil cap and spt battery tie down both silver
