MNSubaru CB Radio Discussion
Discussion in 'MNSubaru Event Center' started by readymix, Jan 25, 2006.
  1. readymix
    Eloh, El
    Fixed
  2. readymix
    Eloh, El
    Also, I wont be able to deliver them on Friday night next week because I will be out getting myself completely sh1tfaced for St. Patty's day. Saturday night FTW. I will be out Saturday at Firestone. Chux, I don't know what your plans are, let me know how you wanna recieve yours.
    -Jason
  3. Chux
    Independence, MN
    I'll be in montana on friday, and probably back in duluth by saturday night. just give 'em to martin the next week or something. Or, I'll see if anyone else will be in town on saturday to come get them.
  4. readymix
    Eloh, El
    Edited First Post. General gist of the update: Wont be there on Friday to distribute these things...St. Patty's Day, so I'll be getting drunk instead. Saturday night I'll be at the Firestone. You can pick them up then if you want to. I will have them in my trunk until they are all distributed.
  5. Chux
    Independence, MN
    Well, if you see a guy show up in a loud ass red mustang (good weather) or a lifted blue wrangler named nate, give my 3 to him. otherwise, give them to martin whenever you see him. or.....I'll stop in myself before I head off to duluth.
  6. readymix
    Eloh, El
    Sounds good man.
    THEY SHOULD BE HERE TODAY!!!1
  7. asiandude
    asiandude Well-Known Member
    sweet
  8. Dynapar
    Orono, MN
    kinda OT, but i found my dads old CB radio from his plow truck. now i need to get an antenna. w00t free radioz for me.
  9. readymix
    Eloh, El
    Box was just delivered :D
  10. 02blubru
    Norwood Young America
    w000t!!
  11. phi11
    Action Valley
    So what channel is it going to be?
  12. AWDimprezaL
    Monticello.
    we'll all decide on one soon enough.
  13. subaru4
    subaru4 New Member
    prison camp
    i have been listening to the channels on my cb radio for the last 2 months and there is almost nobody on there
  14. Chux
    Independence, MN
    did you ever get it tuned? or are you still getting 23 feet of range?
    I've heard alot of people on a number of channels.
  15. subaru4
    subaru4 New Member
    prison camp
    i must need to get it tuned
  16. AWDimprezaL
    Monticello.
    how in the hell do you "tune" it?
  17. readymix
    Eloh, El
    How to Tune a CB Antenna
    Version 1.2
    Install the CB. Make sure the ground is a good one (some recommend running a wire from the vehicle's chassis) & that you are using the same power line as runs to your car stereo (for noise filteration) or perhaps a direct line from the noise suppression unit in the engine. Inspect the coax cable for damage. On the end that attaches to the antenna base, you may want to use pliers to (gently) tighten the coax connector to the base. Be sure the coax is hand tight on the back of the CB radio (put some effort into it! You don't want it falling off.). Attach the microphone.
    INSTALL the antenna. Be sure the antenna is insulated from ground. Recall that coax cable has a sheathed internal wire and a surrounding, but separate "hollow cable" which provides ground running around the sheathed internal wire. (The ground "hollow cable" is not visible because it, too, is shielded). Remember that the sheathed internal wire must only share conductivity with the female part of the coax hookup on the back of the CB and, on the other end, the antenna itself. So, be absolutely certain there is a non-conductive buffer between the base attachment for the antenna (which looks like a cylindrical nut, and will be grounded) and the antenna itself. (With a magnetic mount this is not an issue, since the company supplies an appropriate base.) On a do-it-yourself-permanent installation, be aware that the modified cylindrical "nut" that accepts the "bolt" part of the bottom of the antenna (or the "bolt" part of the spring on the base of the antenna) must sit on a teflon disk that allows the cylindrical "nut" to have no conductivity with the base attachment of the antenna; that is, the vehicle's ground. In order from top to bottom you should see: antenna, possibly a spring, a bolt with threads, a cylindrical nut that accepts the "bolt" part of the antenna, then a non-cunductive buffer, then the vehicle's sheet metal. Under the sheet metal, you'll have a lock nut, an attachment for the end of the coax to screw into, then finally the coax cable end. In summary, the inside center of the cylindrical "nut" that accepts the base of the antenna should have conductivity ONLY to the center wire of the coax cable, which has conductivity ONLY to the inside coax fitting on the back of the CB. If you get this wrong, your SWR meter will let you know immediately.
    Don't use the CB without the antenna attached! Moving the antenna changes its tune, so once you install it, leave it (or at least the base) where it is. The best place is center of the vehicle, as high as you can get it. For a pickup, that's in the middle of the top of the cab. If you mount the antenna elsewhere, you will broadcast toward the area of the most metal. Ie, if you mount the antenna on the rear right bumper (worst place), you will broadcast in a conical pattern in the direction of the left front fender, which is the direction of the most metal in your vehicle.
    Ask yourself, what channels will I be using the most? Remember:
    More people frequent 1-20
    (never use 9 except in an emergency!)
    Busiest (trucker's) channel: 19
    SSB use is usually 30-40, especially 35-40.
    Tuning the antenna (below) is an issue only for broadcasting, not receiving.
    Turn the engine on and idle (don't just turn the accessories on--you have 13.8 volts when you idle, but only 12 when you turn on accessories only.) Choose the channel in the middle of the range you'll use (say ch 20 if you want to compromise and tune for all 40 channels). Switch the CB's meter to the SWR position, and "key up" briefly (ie, transmit for a second or so). Watch the needle & the scale that says SWR--Standing Wave Ratio (ignore RF scale and the CAL scale for now). The needle should stay low, somewhere between 1 and 1.5 on the SWR scale. If it gets up to 2, you need to do some tuning. If it gets much higher than 2, beware, you could harm the CB: broadcast in less than one second intervals.
    Tuning entails adjusting your antenna so the SWR meter reads as low as possible for the channel you've selected. To tune your antenna, you may slide a cuff along the shaft, turn a bolt at the tip, or in the case of a steel whip, trim the whip at the bottom till you get the lowest reading you can. You must tune the antenna so the SWR is as low as possible for the channel you select in the condition the antenna will actually be used. For instance, a bolt-top tuning antenna has a plastic cap over the bolt. You must tune the antenna for the lowest SWR reading with the cap on. (Yes! this entails a lot of trial and error!) The SWR reading should be between 1 (the lowest it gets) and 1.5 for any given channel.
    Now calibrate your SWR meter. Switch the CB's meter to CAL, key up briefly (a second or two), and rotate the CAL dial to where it says CALIBRATE (perhaps just a red dot) on the dial. Now check the tune of your antenna again. You may wish to repeat the tuning process with a calibrated meter (not an option with a wire whip antenna! With a wire whip, it may be best to calibrate first and risk a high SWR reading if you think you can calibrate very quickly.) Tuning is now done.
    Now switch the CB's meter back to RF, which is where you will leave it most of the time. RF is the way you measure someone else's power and your own output power. Often, the RF scale is labeled S. Transmitting power uses a metric called "S". It's common to ask another CB-er how high you are registering on the S meter (they may reply in slang: you're coming in at 20 pounds--means you're about as high as it gets, around the 20 mark on the S meter. The red part of the dial is sometimes referred to as the cherry orchard, which is where you want other people's S meters to be when you broadcast--meaning your antenna is well-tuned and you're broadcasting at maximum power.) To get someone to tell you how far you are broadcasting, ask for a "radio check." They'll tell you where they are and how many S units you're sending.
    You may want to check your broadcasting power (RF & the S-scale) on different channels. You will notice you have more power when the engine is on and you are in a certain channel range (hopefully, the channels you tuned for!) For maximum range, use a channel upon which you output best. You will also notice that the SWR readings will mirror the RF/S readings. Ie, channels you are weak on will probably show a higher SWR reading.
    Now to set the dials. If you see a RF GAIN dial, set it at about 75% strength. This helps you hear others better, but degrades the sound as it gets really high. If you're talking close to someone, turn it down; you don't need the "receiving power" or the concomitant noise it brings. Find a station where no one is broadcasting, and turn up the SQUELCH just until the background noise is silent. (You can squelch out louder stuff too; use more squelch if you are in close caravan so you won't be bothered by other people on the channel). If you see switches labeled NB (noise blocker) or ANL (automatic noise limiter), turn them on to cut electrical engine noise. Of course, if the CB is switched to PA, it won't transmit or receive at all, that's "public address," which you won't ever use. If you have a fine-tuning knob, set it at 50% and experiment from there. If the other radio is broadcasting somewhat off frequency, you can improve the reception a little by using the fine-tuner.
    You may have a RX (receive) or TX (transmit) light. They simply flash when either is occurring. If you have an SWR light (or SWR ALERT light), it will light up if the antenna is unattached, or badly tuned. I think it simply gives the same info as the SWR meter, only in an idiot light form. If you have a MOD (modulation) light, you should speak into the microphone so that it flashes in accordance with your voice. When it is not flashing, you are not speaking loudly enough or closely enough.
  18. subaru4
    subaru4 New Member
    prison camp
    thank you jason
  19. readymix
    Eloh, El
    I still have Chux and Fong's radios.
  20. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    I totally forgot to come to pick it up because I was shopping for groceries. If you're not going to be in town, then I'll pick it up next Friday. :)
  21. readymix
    Eloh, El
    I'll be around, no rush I'm sure.
  22. kickin_81
    St. Paul
    Anyone able to get a hold of another member over the radio yet?
  23. AWDimprezaL
    Monticello.
    im going to try to install mine today...but getting ahold of another member??? yeah right, the closest member to me is legacypgt in buffalo, and thats a good 10-12 miles :shock:
  24. 02blubru
    antenna
    I am going to be getting this antenna in black 2 feet long. It is 16.95 for one or 14.95 a piece for 2!
    2 would be 29.90 for the antenna 11.75 for shipping bringing the total to 41.65, divide that by 2 makes it 20.82 for the antenna shipped giving a savings of 7.64.
    I was thinking if someone else wanted one I would order two and save us both a little money on the cost of the entanna and on shipping. Let me know if anyone wants to go in on this deal with me. I plan on ordering late this evening or early tomorrow.
    http://www.claysradioshop.com/citizensband_firestick antennas FS.htm
    Bill
  25. 02blubru
    let us know how it works. What antenna are you using? Where did you get it?
  26. AWDimprezaL
    Monticello.
    its installed, it works, but i have yet to hear anything, as for the antenna, it is some walmart special 9.99 POS, magnet type, it already scratched my roof :x as soon as they get more of the window kind in, im all over it!
  27. readymix
    Eloh, El
    antenna
  28. readymix
    Eloh, El
    Apparently threeRik was absent from the discussion about magnetic mounts and paint. Get a piece of 3M seal, or some clear vinyl from phi11 and put it where you plan on mounting the antenna.
  29. AWDimprezaL
    Monticello.
    it already had a plastic thing to prevent scratching, well that was before my dog knocked it on the ground, where it picked up fragments of steel and rust. oh well! i actually heard some people chit chatting on channel 31 a little while ago.
  30. 02blubru
    antenna
    Thanks for the info readymix. I will be ordering amount as well but there is only a deal on the antennas not on the mounts so that is why I did not mention it though. Still good info for the other intersted. The ground wire on the unit is sufficiant as long as I ground it to the fram right?
  31. AWDimprezaL
    Monticello.
    i just used my stereo ground, to prevent noise!
  32. readymix
    Eloh, El
    That is also a good plan. Any ground wire that is used for noise cancelling is also a good choice...such as the Stereo Ground wire.
  33. 02blubru
    Well no hits for a dual antenna buy so I am going to purchase mine in a hour, so last chance
  34. readymix
    Eloh, El
    I unfortunately have to wait as I am broke right now.
  35. 02blubru
    ^^^you have PM
  36. subaru4
    subaru4 New Member
    prison camp
    what wires do u use to hardwire the radio in?
  37. AWDimprezaL
    Monticello.
    a 12v postive and a ground. :!:
  38. subaru4
    subaru4 New Member
    prison camp
    what wires did u put yours on
  39. readymix
    Eloh, El
    Go get a manual for your car. You want to attach the black wire either to the frame of the car or to the ground wire for your stereo. And the 12v should go on accessory 12v. That is usually a yellow wire I believe, but don't take that as law. I'd go find a manual for your car and see what it says.
  40. subaru4
    subaru4 New Member
    prison camp
    i got a manual for my car but i might need your help if you dont mind
  41. subaru4
    subaru4 New Member
    prison camp
    is it a lot clearer when it is hardwired in?
  42. Chux
    Independence, MN
    the next time I'm in town, I'll try to borrow my uncle's SWR meter, and we can tune CB's @ firestone.
  43. kickin_81
    St. Paul
    I keep forgetting to ask Readymix for my unit.
  44. Todd
    Todd The Originator Staff Member
    I have SWR meter.
    Who wants to use it and how will we hook up?
    I'm thinking I'll bring it down to Firestone Friday (not the 14th, got dinner plans, but the 21st).
    If you want to use it before then, PM me. You know where I work. It shouldn’t take but a couple of minutes to do.
  45. readymix
    Eloh, El
    Yes, Fong, you need to get yours.
    I still need to get my antenna in. But I'm sure I can have it in before the 21st. Sounds like a good plan.
