MNSubaru Dyno Day @ MAP, OCT 25TH @ 11AM
Discussion in 'MNSubaru Event Center' started by Paul Revere, Sep 20, 2008.
  1. AWDimprezaL
    i heard you maxed the dyno out.
  2. GrimmSpeed
    GrimmSpeed Vendor
    Thank you again to MAPerformance for hosting this event. Your new shop is amazing, keep up the good work!
    mine..
  3. SubieDave
    SubieDave Well-Known Member
    I haven't gotten mine yet either, so don't feel bad. I was told I would get mine on Monday.
    Nice numbers by the way guys!
    I know they are just numbers, but how would a 07 wrx get the same torque as mine? Just curious and maybe a little jealous too! ;)
  4. AWDimprezaL
    ^^^^ the quick spool of the td04 :) you made a few more hp though.
  5. Bullwinkle
    Torque is inversely related to RPM. The same amount of power at a lower RPM will generate more torque. Due to their quick spool, TD04's are torque monsters on the 2.5L.
    Interesting graphs, guys. Looks like MAP's dynojet isn't reading as high as some other dynojet's I've seen (which is good!). Also looks like there were some issues with heatsoak on the later runs.
  6. wrexinator03
    wrexinator03 Banana Cream
    i needs a new tune tinkle!!!!!! mine seemed really jerky....
  7. SubieDave
    Ah yea, I suppose that makes sense. I wish my first pull was acurate! 370tq ftw!
    It would be nice if MAP picked up an tmic fan for those of us with tops. Heat soak wouldn't be so much of an issue then.
  8. wall of tvs
    That is awesome, Justin. That's gotta be from the beemer, right? :eek3:
    Race gas? Those AFRs look a bit lean....
  9. Justin
    Justin Well-Known Member
    yeah its the 335..pump gas
  10. SubieDave
    I wish I would have been there to see your bimmer on the rollers
  11. carl
  12. SubieDave
    Sh1t's sick son!! Thanks Carl
  13. Impreziv
    Impreziv Well-Known Member
    might need just a little more fuel on the low end!! but its a tune in progress. thanks to Matt @ 555 Motorsports in getting it this far and to MAP for the dyno use!!! You guys rock!! I need to get rid of those stock injectors very badly!
  14. putz
    putz Well-Known Member
    hey, it was real nice meeting some of you guys.
    Ohh, and thanks 2 the MAP guys for just letting me chill and spectate!
    and who would have thought a corgie and an akita would get along?
  15. maperformance
    maperformance Vendor
    All dyno sheets were sent out on Saturday, but it's definitely possible there were some misread email addresses lol. If you guys did not receive your graph please send an email to [email protected] requesting it and we will get you set up, thanks again!
  16. blackozone
    What were the numbers on this one?
  17. putz
    loads of torque!
  18. AWDimprezaL
    I lied, 201 whp 213 wtq
    so moaaar tq then before
  19. Dream
    Not bad for a turbo'd n/a car. I need to get my car on the rollers again...
  20. badbennyb
    05 STi Invidia v3 divorced catless dp, Invidia N1 race cb, cobb ots stg2 tune,k&n drop in,walbro 255. Happy with the hp but want in on the tq some of these punks are making.
  21. badbennyb
    ^^^Oh and as a reference on the LSE dynodynamics dyno this same set up made 285hp 290tq with the same sorta weather. *disclaimer dyno numbers blah blah blah we all know the deal.;)
  22. Moleness
    zomg, am I the torque winner? (if you don't count beemers)
  23. Bullwinkle
    The numbers Subiedave sent me beat yours :). Only if he doesn't hit the rev-limiter, though. ;):biggrin::laugh:
  24. Moleness
    I want graphs!!1!!:eek4:
  25. SomethingsWrong
    heres mine
  26. SubieDave
    Finally my graph.
  27. Moleness
    ^^^Wow, nice :). How did the 50 more ft/lbs on that first pull happen?
  28. Bullwinkle
    Cold car, likely. Looks like some heatsoak on the dyno there a bit.
  29. wall of tvs
    That's a pretty bad boost spike, imho. It's like a 50wtq swing, lol.
  30. badbennyb
    Any of you tuner types have a suggestion for more tq (graph is a few posts up) I'm guessing it must be in the tune as I was the only STi with an ots tune.(?) Just curious even though I am happy with the way car feels and it appears to be strong in the hp area.
  31. wall of tvs
    Crank up y0 boost, sir.
  32. badbennyb
    OK, sounds good:biggthumpup:
  33. Bullwinkle
    It's not a boost spike, it's a boost bounce back down after the car hits targets. If I was at home, I'd post up the boost curve on the last run. IIRC, it's about a .5 PSI swing, although the car was showing a flat load curve and was quite smooth. I guess this was after a bunch of runs when the car was warm, though. However, the WGDC's could use a little more TLC, but Dave and I were already long on tuning time after fixing all his BCS routing issues :eek3:.
  34. bigSTIck
    bigSTIck New Member
    My dyno...09 FXT
    I am doing some beta testing for Cobb. I went to MAP on Monday night and got a couple dyno pulls in. This is a Stage 1 93 octane map from Christian compared to stock;
    Jon
  35. 03subyR
    03subyR Well-Known Member
    Is it kind of low for dynojet numbers? What's stock WRX reading on that dyno, anybody know?
  36. AWDimprezaL
    ALL 09 fxts are autos, that would be the reason for the low #ss
  37. Bullwinkle
    Wow, do I see stoich AFR's up until almost 5k RPM? Stock mapping makes mommie cry. :eek3::eek3::eek3::emo:
  38. wall of tvs
  39. bigSTIck
    bigSTIck New Member
    you are correct sir.....almost.
    All US 09 FXT's are auto's, however, you can get 09 FXT's with the 5mt in other countries. Here is a dyno plot of one from OZ;
    http://www.subaruforester.org/vbulletin/496468-post108.html
    Notice the different powerbands, the tranny has a huge impact not only on total power output, but the curve also.
    I was out this weekend with my friend in his STI, we did some hilly & curvy roads south of EC. We lined up 3 times also....it was a good time.
    What are stock 08 STI's putting down on a dynojet?
    Jon
  40. TSTRBOY2004
    sir... I am envious.... Fozzies are my new drug
  41. bigSTIck
    bigSTIck New Member
    DB tuning
    hey, back in 2006, I took my 05 STI to DB for a tune. I went in with a Cobb catless downpipe necking down to a 2-1/2" "Choke"Master(flowmaster) catback. After 20 dyno pulls and a boat-load of fruststration caused from an inability to control boost, we ditched the factory EBC and tuned it with a MBC. Then we cut off the muffler, made 6 more pulls and finished fine tuning. They were able to extract about 18hp and 25ftlbs on top of the Cobb Stage 2 OTS map.
    Before custom tuning:
    Final Tune HP & Boost:
    Final Tune HP & Torqe:
    I then drove home and went to my buddies shop. We trimmed off the end of the Cobb downpipe and built a full 3" Magnaflow catback. I never got it re-tuned or dyno'd, but it made a ton more power. It hauled my bigAZZ down rock-falls in the high 12's.
    Jon
  42. wall of tvs
    ^^^ DB didn't tune my car....
  43. readymix
    WOTV's inside
  44. bigSTIck
    bigSTIck New Member
    ^^^^^^^thanks for telling me, I feel enlightened.
    Jon
  45. 03subyR
    Went to MAP today to baseline my 08 and compare to DB dyno. I got 261whp and 266lbtq on MAP dyno and only 240/250 on DB. Was hoping for 270+ whp but came up a little short. I am running 18G with 650cc injectors and AVO TMIC with Shane tuned Cobb AP map. The numbers are at 18psi, but planning to go 20-21 when I get my GMBCS put in. Hoping for 280+ at 21psi in the spring.
