MNSubaru Dyno Day @ MAP, OCT 25TH @ 11AM
Discussion in 'MNSubaru Event Center' started by Paul Revere, Sep 20, 2008.
  1. Bullwinkle
    Saint Paul
    18 PSI where in the powerband? With an 18g on a 2.5L, adding boost only typically yields more torque through the powerband, as your tune is typically limited by the turbo up top (which is where you make peak HP).
    If you want to add HP, you will likely have to add some e85, meth, racegas, or some better breathing parts.
    To be perfectly honest, your numbers sound very low for that type of set up. I would expect ~280 WHP on a mustang dyno and ~300-310 WHP on a dynojet. What size 18g are you running?
  2. 03subyR
    03subyR Well-Known Member
    South suburbs, Boston
    It's td06 turbo plus my boost was spiking all over the place. I am pretty sure I could get it to 270whp on dynojet with GM BCS.
    I do have catted Dp and SPT cat back.
  3. pbedroske
    pbedroske Well-Known Member
    Madisonville, TN (Tail of the Dragon)
    look at my crappy tune back in october (post 238) - 270whp - still put up pretty good numbers for a 2.0L vf39. I would think on the same day you would have had at least 15-20 whp more than me. you may have a boost or exhaust leak.
  4. 03subyR
    I don't think I have a leak, but my boost goes up and down during acceleration. I should have 10-15hp more if my boost was constant 18psi. I hope BCS will fix this problem. I think 08+ WRX are little harder to tune to run high boost.
  5. Paul Revere
    In the land of ice and snow.
    Bump! Is anyone interested in another dyno day this spring?
  6. RichWRX
    RichWRX Well-Known Member
    Orr,Mn
    im waiting for the Oct 25th dyno
  7. Paul Revere
    You mean the one that happened last year Rich?
