My Boost is playing with me
Discussion in 'Modifications And Maintenance' started by ej20, Nov 21, 2008.
  1. ej20
    ej20 Well-Known Member
    02 WRx w/82k, stage2.
    Say I'm going on the highway at 60mph on 5th gear and I want to past a car, kinda floor it on 5th gear (enought so that you could hear the spooling). During when I'm gasing I can feel my boost(psi) feels like its going up down, up down like when you're pressing the gas pedal and release a bit then press the gas pedal again(but speed do increase like normal). This is in 5th gear, havn't tried 4th but 3rd is fine since its close to redline. I dont have any gauges yet to tell the psi. Whats going on?
  2. AWDimprezaL
    You have a modded wrx without a boost gauge? thats basicly all I understood in your post.
  3. Bullwinkle
    What tune/who tuned it?
  4. AWDimprezaL
    also mods?
  5. Se7enrex
    Se7enrex Well-Known Member
    bad tune, maybe wastegate issues???:dunno:
  6. blackozone
    My car does the same on an off-the-shelf Stage 2 tune. You just need a better tune (read, you need a TUNE in general).
    And a boost gauge.
  7. Tim the Plumber
    sounds like wastegate to me as well... your gonna notice it more in 5th gear as it provides a higher load on the engine which = more boost. Sence you said your stage 2 im thinking it could be creeping, so my guess would be your wastegate duty cycle is struggling to maintain.
    Get your self a boost gauge, In my book guages should be the very very first mod (if you can really call it a mod).
  8. Nuke
    I tuned it :eek4:
    LOL, just a basic stage 2.
    Everything was fine when we were tuning and logging (with wb02)
    Though we did not log 5th gear -_-
  9. Bullwinkle
    Hehe, ok. My guess is that he's overboosting due to the cold weather and then getting some bounce. :)
  10. Tim the Plumber
    very true totaly forgot about the air tempatures changing this time of year now also helping with overboost. A simple fix might just be to throw in a boost controller inplace of retuning for every season
  11. Nuke
    well, he shouldn't be flooring it in 5th gears anyway, might black out again.
  12. wall of tvs
    It's the turbo dynamics kicking in.
    Flooring the car in 5th will produce enough load to easily overshoot boost targets (assuming wgdcs were set during 3rd or 4th gear pulls) and the ecu will react by pulling out wg cycles. However in this case, the car is pulling out too much wastegate and thus pulls out too much boost. Then the cycle repeats itself over and over....
  13. wall of tvs
    no, it's because he's flooring it in 5th gear....
  14. Scuba Steve
    wait one second here buddy......we're not supposed to do that? :eek4:
    I do that backing out of the garage;)
  15. ej20
    I dont mean "floor" it like pedal to the metal, No I"m not that dumb. Enought to pass somebody on the highway.
  16. ej20
    Boy, if I blackout in 5th gear I'll be "PassOut" on the other gears which = faster then you, right?
  17. wall of tvs
    Sounds like both the turbo dynamics are too aggressive and the wgdc at lower throttle openings are too high for the corresponding boost targets.
  18. Bullwinkle
    See below.
    Yes. If a tuner gets the turbo dynamics and WGDC tables correct, you can avoid this phenomenon. Without looking at the map, it's hard to say if this is caused by boost and wgdc targets that are to high in the low rpm high load areas, or caused by mistuned IAT WGDC corrections. Both could cause some boost bounce in the higher gears.
  19. Nuke
    stock bcs
    Yes, the stock values can be tuned to help it, but I left it alone, didn't know mister blackout was gonna be flooring it in 5th gear in cold weather :ugh:
  20. EggRoll
    EggRoll Well-Known Member
    :dunno: Why would you stay in fifth to pass someone? Unless you like to pass people slowly...
  21. Shibbs
    :laugh: This is very true. Especially with a 2 liter.
  22. TSTRBOY2004
    scared he may pass out
  23. Scuba Steve
    ha ha...unless you have a 16g:yumyum:
  24. Soupboy
    Soupboy Well-Known Member
    My car passes fine in 5th gear and I don't have to floor it either.
  25. Lee
    Lee New Member
    :laugh:....done that before, didn't really black out but did end up melting some pistons:(
  26. ej20
    Yes its a slow pass. What I'm saying is that you press the gas pedal enought to "hear" the spool.
  27. Ronnie@RSmotors
    sounds like you're over shooting the boost target. Not a big deal. Should take a little time to correct.
  28. ej20
    So a retune?
  29. aspiringRexer
    aspiringRexer Member
    true dat. Your 16g stay right with my 2.5L VF39. This is unacceptable!
