My car eats calipers!
Discussion in 'Modifications And Maintenance' started by MGXRS#1, Jan 15, 2009.
  1. MGXRS#1
    MGXRS#1 Well-Known Member
    I dont know why but my car keeps breaking the front driverside caliper. I have now gone through three new calipers. Why is this happening?
  2. AWDimprezaL
    What exactly is breaking on them?
  3. MGXRS#1
    the sleeve around the piston
  4. AWDimprezaL
    What kind of calipers are you buying? NON oem remans are piles of ****.
  5. MGXRS#1
    bought them from Oreillys
  6. souy07
    souy07 Well-Known Member
    i had same problem with my car. might be the piston not biting right or bad pads... i just swapped the pads....
  7. MGXRS#1
    the problem is though that the sleeve is breaking open, then brake fluid leaks all over.
  8. TSTRBOY2004
    well I have never had issues on calipers NON dealership, but if this is the third one you would have saved yourself some $$ and gone original...m maybe it is time to try and if that goes bad you can say even the originals suck... if not..problem solved.. win win
  9. Iroc-Z
    Iroc-Z Well-Known Member
    If you have gotten three calipers that all do the same thing I would maybe rule that out. The odds of getting three bad calipers is not that high. How long do they last? Are you replacing the carrier with it?
  10. MGXRS#1
    They have each lasted a little over a month. I do a little spirited driving now and then when it snows but nothing too hard core.
  11. Iroc-Z
    Could you post pics of what cracks? It almost sounds the the knuckle or carrier is bent and causing the caliper to be at a bad angle.
