My Late Spring Plans
Discussion in 'Modifications And Maintenance' started by 95lwrx, May 14, 2007.
  1. 95lwrx
    95lwrx Well-Known Member
    so i have been thinking about making the dive for my next mod for quite some time now and i have finally decided to take the jump. so heres the plan.
    i am purchasing power fc and the datalogit tuning software, along with some 550cc injectors. with my engine being older i will need to modify some fuel rails to work with the injectors.
    so i just need to round up the last of the items i need and get the car to the cities to do a little work to it, and get it to whoever i find for tuning it.
    i will be taking pics of the fuel rail mods and so on, and updating on what i end up with for power after tuning. so i want to thank in advance anyone who will be helping me out in the near future with my project
  2. Dynapar
    SWEET! finally doing stuff to the white car again. that car is awesome! if you need a hand let me know.
  3. Dream
    omg your still alive! im gonna be up in your area next weekend, we should hook up y0
  4. 95lwrx
    well i am tenatively bringing the car down to the cities on memorial weekend to get the fuel rails modded up and other stuff installed before i take it to get tuned
  5. Deride
    OMG are you gonna finally be able to run something other than race gas? =)
  6. 95lwrx
    lol, yeah that was actually the last straw, the gas station where i get gas stopped carrying my 98 octane, and i don't feel like mixing $6/gal 110 all the time :biggrin: and yes i am getting tuned on pump gas so no more turning the boost down when i go somewhere that doesn't have my normal gas :biggrin:
  7. 95lwrx
    ok i have everything more or less lined up, just recieved my tuning software today and i will be getting my laptop tomm, and the plan is to head down to the cities on memorial weekend. :biggrin: :biggrin:
  8. Deride
    Awesome!
  9. 95lwrx
    well i just dropped my car off at LSE yesturday for tuning, and i will be picking it up later next week. hopefully everything goes smooth for Josh and hopefully my tune turns out good :biggrin: i can't wait to get it back!!!!:biggrin:
  10. Justin
    Justin Well-Known Member
    have any 5 speeds up at your shop that you could bring down next week??:)
  11. 95lwrx
    nope no manual's, just an auto and rear diff and a 2.2, i still have everything else for the manual swap though(shift linkage, pedals, driveshaft, and everything else but a tranny.)
  12. 95lwrx
    Well!!!!!!!!!!!!!!! it wasn't a very good day for my car. first off my clutch started to slip at 12lbs. of boost while josh was tuning the car yesturday, no big deal really i just need to pick up a stronger disc. BUT i went to pick the car up today and it was running fine they pulled it outside and josh went to pull it back inside and Nothing!!!! the car wont run the ecu doesn't seem to have any power, neither the pfc or the stock ecu will make anything work.
    So i have no idea what the hell happened and now the problem has to be traced out which will definitely be a pain in the ass. so i have no idea how long it will take to fix the problem :emo:
  13. piddster
    Bummer man. Wiring gremlins can make you pull your hair out, then resort to heavy doses of alcohol.
  14. 95lwrx
    ok i did a little trouble shooting with one of my other cars today to see if i could replicate what my car is doing and i got one thing to match up identically with my problem.
    there is one of the green 30amp fuse the square kind (sbf2) i believe that i pulled out and the same symptoms, no check engine light, no ecu power, no start, no spark etc. i think i looked at all of the fuses but those are harder to tell if they are blown or not.
    now i took out every relay i could find one at a time and checked the symptoms and that one fuse was the only one that i could get to match up.
    i also looked at some of my wiring diagrams just now and it looks like the fuse is directly tied in with the main relay and other items that are very important in getting the car to start.
