My Next BIG Project
Discussion in 'Modifications And Maintenance' started by mlgez, Jan 15, 2010.
  1. mlgez
    mlgez Well-Known Member
    Well I have been thinking about this for a while and finally found a SOLID body. This thing, ignoring the surface rust, has only two very tiny holes in it that I have found so far. So here is the next big build. I am sure this is going to take a bit of time to finish.
    Edit: Forgot to mention car is a 1931 Olds. Nothing like 80 year old metal.
  2. carl
    matt, you gonna post the motor for it? :biggrin:
  3. mlgez
    Here are the other parts
    It had the original window and door mechanics, 2002 Ford 8.8" rear end from a Mustang (posi), original tail light/plate bracket, original horn (have not tried it yet), original pedals, seat springs, luggage rack, only one original trailing are but a new set of ones, new front drop axle, original fuel tank, and a bunch of parts for the brakes and suspension.
  4. mlgez
    Give me a few minutes :)
  5. mlgez
  6. mlgez
    And now the mock up. Keep in mind I am going to channel the body so it will sit much lower so the engine will be higher up in reference to the body. It will look much better at that point.
    I am going to go with either 6 downdraft carbs, 3 two barrel carbs, or what is looking the best right now is keeping the fuel injection and loosing the intake and putting 6 vertical throttle bodies on it. Will have to go stand alone but that is the plan for the ignition anyway. I will loose most of the wiring on the motor. Going to go very minimal on this car.
  7. carl
    long car is long
  8. mlgez
    LOL, yes I will need to shorten the frame some. It is a little long in the front with this setup.
  9. mlgez
    The 3.3L Subaru will be NA for now but the plan is in the future after it is on the road to add an old school belt drive blower to it.... just for something different and something that will fit the body style.
  10. petrakov08
    petrakov08 Well-Known Member
    Very nice, looks like a whole heap of work gl
  11. Kevin
    Kevin Well-Known Member
    Damn! this should be awesome!!!
  12. badbennyb
    What is it? Is it gonna be wrb? Brembos? BBS? Cool project, maybe this could be turned into a blog.
  13. mlgez
    I kinda did forget to mention that the car is a 1931 Olds. I am going old school with most of the build. IF it gets paint it will be flat something. Wire or steel wheels with big white walls.
  14. Motorhead
    Motorhead Well-Known Member
    Tons of potential with this find. Suicide doors is a nice touch.
    You using Independent or leaf springs?
  15. AWDimprezaL
    Olds FTW!!!!!!
  16. mlgez
    There is parts there to do rear coil over but I want to get it back to leaf springs. Right now the front is dual leaf but I would like to go to a single leaf in the front instead of one on each side. This car is not going to be about corning that is for sure. Going for something in between a rat rod and a hot rod. I am not into shiny bits and chrome (I would get too pissed off if it got scratched) but I am not sure I want to go rusty rod either.
  17. Chux
    EG33? should go EZ30DR....
    sweet project Matt! Should be an awesome build!
  18. TSTRBOY2004
    jealous.. although I would turbo Small block.... hmmmm
  19. AWDimprezaL
    Small block olds, I know a guy that has a ****load of them "in stock, and cheap!" ;)
  20. TSTRBOY2004
    yep my dream rod is some sort of rat rod with a turbo v8.. heck big block would be even better... ha ah ah
  21. thunderdan1313
    thunderdan1313 New Member
    nice look car.
  22. dmoo
    dmoo Well-Known Member
    way cool with the subaru motor plans.
    and a heck of a garage to accommodate the build
    keep this thread updated
  23. Zrxhooligan
    Zrxhooligan Member
    way cool project
    you don't come by that everyday, thats a hell of a clean tub!
    Please keep this updated!
  24. Dynapar
    My opinion exactly.
    This is awesome looking! It will be an great project. If it weren't for the suicide doors I would have said to chop it into a coupe.
