N/As running on corn?
Discussion in 'Modifications And Maintenance' started by 02subbieRS, Aug 31, 2010.
  1. 02subbieRS
    02subbieRS Well-Known Member
    Hey guys. I was looking around and didn't find what i was looking for on the other forums. I was wondering if anyone knows about setting up a 2.5RS to run on ethanol/E85. I assume I would need the better flowing fuel pump and bigger injectora and to tune for the extra needed fuel. Does anyone know if this would work or cause me any problems? Mostly just curious
  2. Nuke
    you will first need engine management
  3. snwbdr94
    snwbdr94 Well-Known Member
    sounds like its time for a swap imo
  4. dmoo
    dmoo Well-Known Member
    turbo motor, get one. DD the crap out of that car when you are at school and save some money.
  5. 03subyR
    03subyR Well-Known Member
    E85 on NA car will not give you much more power anyways just stay with pump gas. There are a few posts about NA cars and e85 on NASOIC but you will not find them very usefull.
  6. piddster
    You would need to raise the compression to between 12:1 and14.5:1 to measure any appreciable gains from using E85 on an N/A engine. Even then, you might not even get to stock WRX power.
  7. idget
    I'm currently looking at running e85 in my RS.
    As mentioned, I'm looking at engine management and higher compression pistons (and cams and an intake manifold) before thinking about the fuel system. If yours is a daily driver, I'd suggest looking at other options to meet your goals... unless your goal is to experiment and tinker.
  8. 2.5SubieRS
    2.5SubieRS Well-Known Member
    im in the process of getting a bigger fuel pump and injectors for my car just to see what it will do ill be getting cams soon so i can let you know what happens if you'd like
  9. 2.5SubieRS
    and btw a rs with intake exhaust and an accessport and the right cams and fuel upgrades will keep up with a stock wrx there are many threads on nasioc about it and Ive seen it in person
  10. Nuke
    the ap is for 05 rs, 06+ 2.5i
    02-04 rs/ts, no go :(
  11. AWDimprezaL
    Keep up is an interesting phraze. Maybe for 60 feet or so.
  12. 2.5SubieRS
    no do some research and make sure you read STOCK
  13. AWDimprezaL
    Ive done plenty on the subject, thats what I was going to do to my Impreza, basicly you end up with an n/a 2.5 that accelerates ALMOST as fast as a wrx, (a stock wrx is still going to pull on top, its the nature of a turbo vehicle) but its harder to daily drive (see rumpity camshafts), gets **** gas mileage, and is unreliable (revving past stock limit, 2.5s are fragile in stock form) You are going to spend $$$$ for less than a 60 hp gain.
  14. piddster
    If you want 150 whp, by all means do cams, exhaust manifold, and tuning. If you want more, tear into the shortblock to replace pistons and do some headwork. Maybe you'll eek your way up to 200 hp on a good day.
    It's just not worth it in the long run.
    The only point to use E85 on a N/A engine is if you've raised your compression.
  15. ShortytheFirefighter
    Comparing acceleration times between a GC and a GD isn't a good comparison either, considering a GC can be 400lbs or more lighter than a GD. The other thing to consider is that after all the money you'd be putting into trying to get an RS to "Keep up" with a WRX, you could do an engine swap and be starting off with a better powerplant for trying to make power. All of the threads I've seen where a naturally aspirated RS was anywhere close to a WRX were on GCs.
    FYI, telling Erik to go research something Subaru related is like telling Einstein to go research addition and subtraction.
  16. sneefy
    sneefy Well-Known Member
    There is not a good reason to run an N/A on e85.
    BTW: "because I can" is not a good reason.
    You are better off selling the car and getting a WRX.
  17. 2.5SubieRS
    Because I can is a perfectly good reason Because I want to try it and I want to see what happens money is not an issue nor do i care if i keep up with and or beat a WRX if i had wanted a turbo car i would have bought one in the first place and BTW I do not race in straight lines I race on dirt and what car gets first almost every time in the rallyxs? oh that's right a N/A 2.5rs
  18. ShortytheFirefighter
    It's your money, you can do what you want with it. The rest of us are only trying to say that you'll be throwing a lot of money down for not much in return.
    Your reasoning is a bit flawed on the rallyx victories being due to N/A vs Turbocharging. The driver is the main component in that, not the engine. I've seen plenty of drivers in cars that on paper weren't that capable beat cars with a lot more power. I could be using Pastranas rally car and I'm sure Mark U would still hand me my ass while driving his Mustang.
  19. 02subbieRS
    hahaha whoa. thanks guys. I was just curious is all. Yeah i surfed NASIOC and other sites and nothing they had were much help. Dmoo: I'm pretty sure that's what I'm gonna do. Drive it nice until I graduate and get myself a WRX. Nuke: it makes me sad that they don't have any real good EMSs for the 02-04 N/As other than the Ralittek P6 ECU. :(
  20. AWDimprezaL
    and that P6 is crap, ask martin, lol.
  21. piddster
    Without RomRaider support for your ECU, a standalone is by far the best option for tuning these cars.
    Also, I was unaware that having a turbo car makes me purely a straight line racer.
  22. 02subbieRS
    thanks AWDimprezaL. I had heard mixed reviews about the P6 and was leaning against it.
  23. ShortytheFirefighter
    Yup. A turbo means you can no longer turn.
  24. AWDimprezaL
    As soon as I put the turbo on my car, the steering wheel dissapeared.
  25. sneefy
    Woah, settle down there, chief. Whatever floats your turn-filled, dirt-drivin' boat.
  26. zisson33
    zisson33 Well-Known Member
    poof! :)
