Need guidance for rad coolant change
Discussion in 'DIY Instructables' started by Sanjay raval, Sep 13, 2015.
  1. Sanjay raval
    Sanjay raval Member
    I need a little bit of help in the sense of what rad coolant i should put into my 07 forester. A shop said oem subie coolant and i got a bottle of 50 50 from autozone? Will the 50 50 work?
  2. sneefy
    sneefy Well-Known Member
    Subaru didn't start using the Blue "super-coolant" in the Forester until 2009. So your 2007 will just need traditional green coolant. Off the shelf is fine and should be mixed 50/50. So what you bought should be fine. Check your owner's manual for the capacity you'll need. Optionally, you could also get a bottle of the official Subaru stop-leak additive.
  3. Sanjay raval
    Sanjay raval Member
    Thanks sneefy, now just to change when i have time. Should i use any coolant system cleaning additive at all?
  4. sneefy
    That, I couldn't tell you. Perhaps someone else might chime in on that.
  5. Fatboy Walrus
    Fatboy Walrus Well-Known Member
    From what I have heard/read When you bring you Subaru in for cooling service they do add conditioner SOA635071. Someone may have the absolute answer for that. I've only ever used green Subaru coolant mixed 50/50 in my Wagons. When I did the timing in my Saabaru I had a bottle of conditioner but was reluctant to use it thinking it would clog up and something scary would happen :eek:
    If you have the $$$ buy a genuine Subaru thermostat too!
  6. thealtaholic
    thealtaholic Well-Known Member
    you really only need the "conditioner" which is likely water wetter, if you have a turbo. Otherwise green stuff diluted 50/50 with distilled water is fine. None of that limey, fluoride laced stuff from your tap though.
  7. sneefy
    The Subaru conditioner is not water wetter. It's a stop-leak type product. There is some evidence that it's rebranded Holt's Radweld. It's intended by Subaru primarily to help prevent minor head gasket leaks.
    EricS likes this.
  8. Sanjay raval
    Sanjay raval Member
    the last time i was in for an oil change, the dealership said i do infact need to watch the oil levels because of minor (not threatening) leak
  9. sneefy
    Was that external oil seepage? The conditioner will do nothing for that as it's only for the coolant.
  10. Sanjay raval
    Sanjay raval Member
    thats probably what it was. what would you suggest for that?
  11. sneefy
    New gaskets.
    phi11 likes this.
  12. retreif
    Buy a Honda.
    Sanjay raval likes this.
  13. derp
    Big turbo 50 psi swap.
