Need Help, All 4 cylinders misfiring!
Discussion in 'Modifications And Maintenance' started by moerocca, Dec 26, 2009.
  1. moerocca
    moerocca New Member
    I pulled codes from Autozone and found all 4 cylinders are misfiring. Car feels very sluggish with a lopey idle. I tried replacing spark plug wires, but it did not help. It is a 97 outback legacy w/ 2.5 motor. Can anyone please help me? I have been reading for hours and it looks like it could be anything from the intake gasket to the headgasket. Thank you very much for the help
  2. john
    john Well-Known Member
    Was any work done to the car prior to the issues?
  3. moerocca
    moerocca New Member
    Not that I am aware of, however I purchased the car with this problem thinking it was an easy fix. :(
  4. john
    Good luck.
  5. flstffxe
    flstffxe Well-Known Member
    Any history with the car?
  6. 9blackmax6
    Maybe a coilpack or your spark plugs. Try the easiest things first and work from there.
  7. moerocca
    moerocca New Member
    tried plugs and wires... no help maybe have small exhaust leak...wonder if that affects it
  8. AWDimprezaL
    Did you try a coil?
  9. Impreza 2.2 T AWD
    Impreza 2.2 T AWD New Member
    fuel trim....
  10. moerocca
    moerocca New Member
    did the coil... no help
  11. driftin240
    driftin240 Well-Known Member
    Fuel trim could have alot to do with it, but it should have set a system too lean/rich code by now. I know sometimes that takes quite a bit of time, but it should have set within 3 drive cycles.
