NEED HELP!!! Blown head gasket in a 99 legacy?? or something else?
Discussion in 'Modifications And Maintenance' started by SubieDave, Mar 7, 2008.
  1. SubieDave
    SubieDave Well-Known Member
    South Saint Paul
    So my little brother bought a 99 legacy SUS a couple months ago. I told his mom to have it looked at, but she just put the cash down and picked it up. I looked at it with them before they bought it and everything checked out. I looked for all the usual things you do when you buy a used car, but I'm no mechanic, I just know what to look for.
    Anyways, the story goes. They were driving it with full heat on and all the sudden the heat turned cold. The temp gauge was normal and then shot all the way up to the hottest. When they got home and popped the hood, there was coolant everywhere. I noticed that there was oil in the coolant overflow can and the radiator hose is suctioned together, if that makes sense.
    So is it in fact the head gasket or what else could it be? Why would there be oil in the coolant overflow? Is this an easy fix or is it going to be spendy? I just don't know where to go from here. If you can help me out with any info, we'd be much obliged.
  2. JeremyT
    JeremyT Well-Known Member
    Yikes bro, I'm no expert but it sounds like the dreaded head gasket.
    One of my 99's is in for the repair as we speak. As to the cost, I'm still waiting for what the official damage is going to be.
  3. manochromatic
    manochromatic Member
    Rochester
    yeah ive got a small leak...checked with the local car-x and they quoted me 1250...i think they said 900 or so was for the labor alone.:hsugh:
  4. AWDimprezaL
    Monticello.
    definatly head gasket!
  5. SubieDave
    South Saint Paul
    I've never dealt with a blown gasket before. Could other things be wrong from this or would it just be replacing the head gasket? How does a head gasket blow?
  6. illegal2.2
    illegal2.2 Well-Known Member
    definite HG as i'm one of the victims. i think i paid roughly 1.5k for it at a private shop :(
    chingchong
  7. dman
    dman New Member
    Its a HG, total bill will depend on how long it was driven with temp on the hottest.
  8. Jackstand
    Jackstand Well-Known Member
    St Louis Park
    Ask LegacyPGT he does good work for cheap that is where id go dave
  9. 99legacy
    99legacy New Member
    Delano, MN
    i have the same car, and mine went around 125xxx with no warning. took mine to St. Cloud suby and it was about 1200 bucks, but they do awsome work, and they don't over charge!
  10. JeremyT
    wtf? I'm getting quoted way off the charts for all this? How are you guys getting out so cheap? I haven't been told anything under $2500.
  11. 99legacy
    99legacy New Member
    Delano, MN
    i could be wrong, it was quite a while ago, so the 2500 could be right
  12. SubieDave
    South Saint Paul
    Thanks for the quotes guys.
    I'll PM LegacyPGT and see what he says.
    I still am interested in what makes a head gasket blow?
  13. phi11
    Action Valley
    terrible head gasket design?
  14. SubieDave
    South Saint Paul
    haha, besides that!
    I just feel bad for my bro. It's his first car and I dont want him to have a bad taste with Subies
  15. flstffxe
    flstffxe Well-Known Member
    Coon Rapids
    also not a bad idea to check the heads and make sure they are not warped. The heads should be within +/- .002" flatness, same with the block. If the surface/s are not flat it can be the source of repeated HG failures.
  16. BoBo82
    BoBo82 Member
    Minnetonka, MN
    head gasket for sure. same thing happened to be on my old 98 legacy.
    small leak most likely. it will often be misdiagnosed as radiator, radiator cap, thermostat....
  17. SubieDave
    South Saint Paul
    Got it. Thanks alot guys.
  18. subytek
    subytek Well-Known Member
    Further west than Ted.
    We have a winner!
