need help. coil pack has no spark.
Discussion in 'Modifications And Maintenance' started by lukas, Nov 2, 2009.
  1. lukas
    lukas Well-Known Member
    i just got done swaping in my ej20k into my 00 impreza rs. The car crank but it wont turn over. i check the coil and i have no spark. i try using 4 different coil pack, still no spark. i check the plug from the engine harness with a volt meter and i got 11.49v. i just change my crank sensor today still nothin change. i need help!!! can someone help me?!??!?!?
  2. AWDimprezaL
    Cam sensor?
  3. lukas
    can that cause my coil not to spark?
  4. Bielke55
    Yea if your not getting a reading from your cam sensor its not gonna spark
  5. lukas
    i took the cam sensor out and looks clean and good
  6. lukas
    i also tested the fuel injector plug with a 12v light bulb while cranking to see if ill blink and it didn't.
  7. Bielke55
    Check all your grounds?
  8. lukas
    i did already.
  9. AWDimprezaL
    cam sensor LOOKS okay? You cant see inside it....
  10. lukas
    i'll go get a brand new one in a bit. For now does anyone else have any more idea why my coil doesn't spark.
  11. Bielke55
    Which coil packs have you tried? Isnt this a JDM motor swap?
  12. petrakov08
    petrakov08 Well-Known Member
    doublecheck ftw
  13. Bielke55
    Yes what he said!
  14. lukas
    first one i tried was a brand new 1994 legacy coil pack. the legacy and the jdm coil pack looks the same and have same wires and plugs. The rest i got from upull, from a legacy and impreza both OBd1 . yes this is a jdm motor
  15. xlur8ed
    xlur8ed New Member
    I'm assuming you followed the instructions from here:
    http://forums.nasioc.com/forums/showthread.php?t=1192028
    If you followed those instructions, and have a good 12v reading, then either the ground or signal wire is failing. If you have cleaned each coil from rust/corrosion (in the spot where you put the ring terminal for the ground), then you are left with either a poor signal wire or bad coil. I would recommend the following:
    1) look over your wiring from the merge at the ignitor. If those wires are well soldered (if not soldered, I would redo them and solder), then you can eliminate that part of the equation, then I would move to the coil pack itself. Did you solder onto the pins inside the coil? Use a spade terminal? Or did you have the coils OEM plug that you used? If you didn't have the OEM plug for the coils and tried soldering onto the pins, I would assume the wiring is touching inside that particular coil. If you HAVE the OEM plug, then I would assume you have a bad coil. You should have no problem tracking down a set of 02+ WRX/STi coils for under $100. I would use those vs. something that is already 15+ years old (from what I understood, you used older Leggy coils...I may have misread).
    I just did this conversion last week, with nothing but amazing results. I'd be happy to further help you if you haven't resolved this over the next week (I will be in Vegas from tonight to next Monday)...If you need further help, PM me.
    - Jason
  16. Ronnie@RSmotors
    Did you plug the ecu in?
    J/k
    If you're not getting injector pulse then you're cam sensor/crank sensor and ecu has a communication break somewhere.
    Double check your grounds, sensor grounds on the engine attached to the intake manifold usually.
  17. lukas
    i just tried a brand new cam sensor. still wont start.
  18. lukas
    nope i didnt follow those step. the wires are well soldered and im using the oem plugs.
  19. lukas
    the ground that was on the intake manifold was kinda loose, i tighten it. still no spark.
  20. Ronnie@RSmotors
    Power
    Have you verified if you're getting power to the ecu? Power to one of the wires on each injector? One wire is on at ignition the other one gets pulse from ecu via cam signal.
    Is this a married harness instead of complete harness swap?
    Was the timing belt replaced?
  21. lukas
    dont know how to do that. so far i only check 1 injector. For the harness i had my rs merge with ej20k. Timing belt was not replace.
  22. lukas
    is there someone else in mn that have a ej20k i could take a look at??????
  23. Shibbs
    Well, I would now say bring it to RS and have them look at it.
  24. lukas
    i was thinking about that today.
  25. lukas
    i found out why i was not getting spark. All because of 4 wires, they were in the wrong spot. anyways here is a link showing my engine running.
  26. FuJi K
    congrats! now we can do some driving!!!
  27. Ronnie@RSmotors
    Let me guess. Igniter wires?
  28. lukas
    wrong. It was one of the main plug that plug with the engine harness. 4 wires wasn't in their right spot.
  29. Ronnie@RSmotors
    Who did the wires? I hope you got some refund for the headache. What wires were they for? Might as well finish this thread with "the fix" so it can become useful to others.
  30. lukas
    Zephyr from rs25. i haven't ask for any refund yet . i have a feeling even if i ask, im not going to get anything.
  31. lukas
    Problem is fix!
