need help deciding...
Discussion in 'Modifications And Maintenance' started by TheSnowman, Dec 3, 2009.
  1. TheSnowman
    TheSnowman Well-Known Member
    so i have a 05 wrx and the clutch is going out and im debating weather to go with an exedy oem clutch replacement kit or something more aftermarket. its a daily driven car and i really dont drive it that hard. the mods it has are a vf39, tbe, FMIC, 565 injectors, intake and a bigger fuel pump. so would it be worth it to go with a more performance clutch (but not to performance because i dont want to hurt my transmission) or would the exedy oem replacement get the job done...?
  2. LASERBLUE135
    I was just in the same predicament as you and went with OEM. You have slightly more power than I do tho (you have turbo upgrade), so if I were in your shoes I would definetly consider the exedy stage1. Do you know what kind of power you're putting down?
  3. TheSnowman
    yeah it was at 260 whp and it was slipping so then it was tunned down to just a more driveable tune until i fixed the clutch. (im not sure about how much torque i have) and like you said im debating between exedy oem and the exedy stage one organic clutch.
  4. Kevin
    Kevin Well-Known Member
    IIRC...the exedy stage one and the oem are the same disc... the stage one just has a stiffer preasure plate.....
    I wouldnt worry about your power levels on either kit... i am running a stage 1 kit.... was on 330 whp for 17k miles and it held great
  5. TheSnowman
    ^ very good to know thanks. and flatline i talked you awhile back about helping me with the install, i was just wondering if you still could do that for me durring the winter cause im going to be ordering a clutch here within a week or two.
  6. LASERBLUE135
    flatline did my install. THANKS AGAIN!
  7. TheSnowman
    would you recommend him.
  8. LASERBLUE135
    huge!
  9. TheSnowman
    ^alright thanks. anyone else have a opinion on this OEM replacement vs. aftermarket?
  10. Kevin
    yeah snowman! just hi9t me up when you are ready!
    And thanks for the props laserblue
  11. TheSnowman
    alright sounds good flatline. thanks
