Need help Fog lights on a Bugeye
Discussion in 'Modifications And Maintenance' started by Rexwagon, Mar 20, 2008.
  1. Rexwagon
    Rexwagon Well-Known Member
    Fargo, ND
    I need some help here. My Foglights will not turn on. I Removed my HID's, Installed new Bulbs.
    The bulbs work fine. My foglight switch lights up when I push it into the on position but the fog lights dont work. I checked the fuses and the wiring behind the dash. Everything is good with the wiring behind the dash with the switch.
    I dont know where else to look.
  2. Bookem
    Bookem Well-Known Member
    Moorhead, Mn
    What kind of ground do they run? I could bring my meter by and check it out for ya.
  3. driftin240
    driftin240 Well-Known Member
    Out West
    If your switch lights up, they should work. Maybe your bulbs are bad.
  4. Rexwagon
    Fargo, ND
    I am not sure what kind of ground they run. but if you want to stop buy you can
  5. Rexwagon
    Fargo, ND
    Also they did work when I had the HID's in for the whole time untill about 2 weeks ago and then they stopped working, So what are the chances that both bulbs burnt out at the same time?
  6. Bookem
    Moorhead, Mn
    You still live right by the mall right?
  7. driftin240
    Out West
    Not very good. You didn't mess with the High Beam relay did you? Do your normal high beams work right now?
  8. Rexwagon
    Fargo, ND
    yeah the normal beams work fine and I didnt mess with the relay. I was one of the lucky ones that my fogs worked with the HID's installed. I just installed the HID's and then bam foglights stayed on. but now they dont work at all.
  9. SubieDave
    SubieDave Well-Known Member
    South Saint Paul
    Could just be as easy as a loose connection. Did you check all the wiring?
  10. driftin240
    Out West
    What???
    You have something messed up then. Could be an issue with the HIGH BEAM relay, not just the low beam relay. Check your operation of the High beams and make sure they work.
  11. Rexwagon
    Fargo, ND
    Yep highs work. I checked the fuse in the main box under the hood and everything was good there.
  12. Rexwagon
    Fargo, ND
    wiring was all good. i checked the back of the fogs too.
  13. Rexwagon
    Fargo, ND
    well bookem is coming over so going out to work on it some more. I will keep you posted
  14. SubieDave
    South Saint Paul
    I forgot to do this once, so I'll mention it. Did you put in and connect the bulbs the right way?
  15. SubieDave
    South Saint Paul
    Yea, I'm interested in knowing what the issue is here.
  16. Rexwagon
    Fargo, ND
    I assume that the headlights are in correctly because they look like they only go in one way.
  17. Rexwagon
    Fargo, ND
    well during this we found out that one was burnt out so I replaced them both, but they still didnt work. we tested the wiring with a voltage tester. still couldnt figure it out. so we gave up for the night
  18. silver03
    MN Bugeye Mafia #300
    ^^So, are they getting voltage at the bulb?
  19. Rexwagon
    Fargo, ND
    yes they were. the wires were tested at the bulb and they were getting power
  20. driftin240
    Out West
    That doesn't mean that the circuit is complete.
  21. SubieDave
    South Saint Paul
    relay has power too?
  22. Rexwagon
    Fargo, ND
    I think we checked the relay, I know we pulled it out and stuff. After a while the wiring got all confusing to me, so for now i am giving up for while.
  23. NMDAYTIME
    NMDAYTIME Well-Known Member
    make sure to check your grounds. also does your dimmer switch work? wierd question but one of your fogs share the same ground.
  24. NMDAYTIME
    if i'm not mistaken
  25. Rexwagon
    Fargo, ND
    yep dimmer works
  26. piddster
    Boostonia
    You need to check the voltage under load. You could have a lame relay that still gives 12v with no load, but as soon as you turn it on, bam it goes to .5v.
