Need help/guidance on a front brake job(96 Corsica)
Discussion in 'Modifications And Maintenance' started by Progression, Jun 30, 2008.
  1. Progression
    Progression Well-Known Member
    Hey all I need hep with a brake job and would feel more comfortable if someone with previous brake experience could stop by and give me some guidance. I'm located in Osseo and would like proceed with the work this coming Saturday as the brakes are grinding quite badly at the moment.
    Thanks in advance!
    Sean
  2. TSTRBOY2004
    replace the pads and rotors if its grinding... simple...
  3. Progression
    Yeah I keep hearing that but I also plan on bleeding the brakes and don't feel all that comfortable with the idea. I guess I feel a bit overwelmed with the project. If this is so simple then you should stop by and lend a helping hand;).
  4. TSTRBOY2004
    other end of the state from me... otherwise I would have you fixed in an hour
  5. Scuba Steve
    ditto, but I'd do it in 59 minutes:biggrin:
  6. TSTRBOY2004
    your woman says you are always quicker then everyone else ;)
  7. Progression
    Thanks guys for leaving comments but I'm looking for help. So Anyone please let me know if you can help, instead of leaving comments which are of no use to me. Thanks
  8. mars_volta
    mars_volta Well-Known Member
    for just pads and rotors dont bleed the brakes.
  9. Moleness
    Buy a Haynes manual and go to it. Don't be scared!
