need help on transmission problem!!
Discussion in 'Modifications And Maintenance' started by immakhang, Nov 17, 2009.
  1. immakhang
    immakhang Well-Known Member
    i bought a used transmission it was working properly where the gears shift in good not hooking to the engine but when i had it bolt on to the engine it wont go in any gears at all. do anybody might know whats wrong or have a simular problem please help!!
    Car: Subaru Impreza 2.5rs 2000
  2. ofspunk7
    What type of car do you have?
  3. immakhang
    2000 impreza 2.5rs
  4. strangefamous
    Was the tranny you bought from the same model/year car?
  5. immakhang
    yes it is
  6. curly2k3
    nothing is obstructed or jammed, fork and everything is gravy?
  7. FuJi K
    Oh my goodness... another tranny issue.
    It won't go into any gear while the car is ON??? Or it won't go into any gear while the car is OFF???
  8. immakhang
    wont go in gears at all even car on or off
  9. immakhang
    the only thing i can think maybe the input shaft not align and putting load on the input shaft. to no be able to shift in gears.
  10. kzoomatt
    kzoomatt New Member
    Mis-aligned clutch fork, or bent input shaft.
  11. turbo_turtle
    If the clutch is working (feels normal) while it is attached to the motor, I would say you have a bent input shaft. The input shaft can get bent if it is not aligned correctly when bolting it to a motor. Sometimes people use the bolts to pull the motor and tranny together because they can't get it aligned properly while under the car. If aligned correctly, the tranny will just slide into the motor with little effort.
    ~Dan
  12. FuJi K
    gonna have to look over the shift linkage again... if that is good. gotta take off the tranny again to inspect the clutch stuff. It should at least shift into gear fine with the engine off. a little bit of slack in the driveline makes it possible; you can see the driveshaft turn a little when you shift into different gears.
    Did you also change out the shifter? Short throw shifters can also affect this because the linkage is bolted HIGHER, and the shifter arm where the boot goes over can come in contact with the chassis or the metal plate that holds that rubber boot on the bottom of the shifter. Re-check your work.
  13. immakhang
    i got it fix guys thankx though....
  14. Tim the Plumber
    what was the solution?
  15. FuJi K
    what did you find out? You have to teach me!!!
  16. immakhang
    lol when i put the two sensor on the transmission i sort of put them in the wrong place so yeah lol...........cause my old one was taken a part from some transmission shop and they gave it back to me in pieces and the new one i have to guess and check lol......
