Need help with timing belt issue--or maybe something else
Discussion in 'Modifications And Maintenance' started by carbonfiber, Aug 31, 2008.
  1. carbonfiber
    carbonfiber New Member
    While I was driving on the highway my timing belt disfunctioned on me. What I thought was the problem, I fixed and adjusted the timing belt but now my car won't start. I cannot figure out what the problem is.
    If anyone willing to give me a free hand and come out to take a look at it & HELP ME FIX IT :)) , You'll be rewarded a nice package...Please email me at this address for details [email protected].
  2. Dynapar
    Can we get some more details on what happened while you were driving and what exactly you did to adjust the timing belt?
    did you re-align all of the cam gears and align the belt with those?
  3. Kevin
    Kevin Well-Known Member
    where are you located? i just had to do my timing belt last night...
  4. subytek
    subytek Well-Known Member
    x2, I've never heard the term, "adjust the timing belt".
  5. driftin240
    driftin240 Well-Known Member
    If your timing belt broke while you were driving, you are probably screwed. Sorry to be a downer, but with an interference motor, valves/pistons will occupy the same space if the belt brakes.
  6. carbonfiber
    Sorry guys, i been so busy and all that my wife thought she be nice and help. anyways my idle pully seized and the idle pully bolt broke from the seized pully, got new belt in and alined everything acorrdingly, but nothing it sounds like theres no compression??? what do you guys think?.oh this happen while on the hiway.
  7. AWDimprezaL
    yeah, its because you bent valves!!!!!!
  8. carbonfiber
    I was hoping it wasn't that,how bad is it to do or how much?
  9. driftin240
    It's removing the engine, heads, and replacing the bent/broken valves.
    Not cheap!
  10. gimmefuel
    gimmefuel New Member
    Might as well do the clutch too
  11. Shibbs
    Probably pistons as those are what bent the valves.
    Basically a complete rebuild.
  12. AWDimprezaL
    meh, lots of times the pistons are still OK...but it does depend on what RPM it happend
  13. carbonfiber
    it happend at around 3k rpm.
  14. carbonfiber
    would it be less expensive to get a new motor or head?
  15. vanddelor
    vanddelor Well-Known Member
    a brand spanking new ej257 block can be has for $1700...
  16. driftin240
    You could always go the EJ257 route, but I doubt you'll need a block. Won't know until you pull the engine apart though.
