Need opinions on what oil to run on my bugeye wagon
Discussion in 'Modifications And Maintenance' started by Zer0, Jul 14, 2011.
  1. Zer0
    Zer0 Active Member
    Whats up guys i drive a 2002 bugeye wagon and am trying to choose what oil to run in my car. I have tried a few different types like castrol synthetic and also penzoil synthetic. The castol worked well and my car seems to eat the penzoil synthetic. What is everyone else running and what oil should i stay away from? Right now the car has roughly 84000.
  2. xveganxcowboyx
    Shell Rotella T6 Synthetic = Happy engine.
    Let the great debate begin.
  3. carl
    the german made castrol syntec is very good as is rotella t
  4. AWDimprezaL
    Rotella, castrol, subaru synthetic, just about anything that isn't mobil1.
  5. WREX
    WREX Member
    Not to start a war among oils, but why is Mobil 1 so bad?
  6. Mr.Tran
    Mr.Tran Well-Known Member
    It's tends to get thinner at operating temp. I use Amsoil and love it.
  7. Zer0
    Zer0 Active Member
    i would like to run rotella t6 but what weight should i run 5w-30 10w-30 10w-40?
  8. Bielke55
    Mobil1 Full Houdini Motor Oil
  9. 2barsti
    2barsti Well-Known Member
    5w-40
  10. WREX
    WREX Member
    Is that fine for all seasons?
  11. AWDimprezaL
    I see what you did there. *dissapears*
  12. RexNEffect
    I've been running it for the last few years, all year long, with no issues. Even use it on my FZ-6.
  13. TheHoboMan
    Rotella 5w40
  14. WREX
    WREX Member
    I'm changing over to T6 from Mobil 1. How many miles should I run before changing again to help flush out the rest of the Mobil?
  15. readymix
    It should be fine. They are both 5w oils. Just change your oil at 3000 miles and it should be pretty clear of M1 at that point. At operating temp, it'll just mix with the other oil. Next oil fill up there might be trace, but it shouldn't matter if the bulk of the oil is the same. Just proceed with your oil changes as normal
    phi11 likes this.
  16. slacker-wrx
    slacker-wrx Member
    I used Amsoil on my 02 wrx, I loved it :) I've change it every 3,000 mile and it treat me right!!
  17. Zer0
    Zer0 Active Member
    chose to run rotella but i came from the vw game and used amsoil my opinion was it was a good oil but my gti went through it pretty quick
