New Tune + Launch Control = Fun
Discussion in 'Modifications And Maintenance' started by Andrew, Apr 3, 2008.
  1. Andrew
    Andrew New Member
    I got a new tune and the car is running better than ever. I had a few nagging issues that were driving me and my tuner, and probably the forum, crazy. Data Log Lab dyno software puts me at about 300 whp and 300 torque.
    1) Charcoal solenoid was not working - fixed.
    2) Purge valve was broken - fixed by Ray's automotive. +1 for those two for finding the problem.
    3) Safe Injection module, the failsafe that cuts the boost solenoid in case of injection failure, was interfering with the boost curve. Whenever injection first starts, boost would drop by a couple PSI then start building again. After a few months of trying to tune around it and lots of frustration, I had a eureka moment. The delay on the Safe Injection was set to zero and was sending a false alarm to the BCS, so I set to about .3 seconds. Problem solved.
    So I've got Launch control set at 5k rpm and 3 mph or less. How does my 2.0WRX clutch and tranny feel about LC? Will I just burn through my clutch faster or am I in for more trouble?
  2. Iroc-Z
    Iroc-Z Well-Known Member
    I am voting clutch problems then big trouble.
  3. webcrawlr
    webcrawlr Well-Known Member
    Are you heading to DB? I'd be interested in what your reading there would be compared to the software. Yeah, I know it can be fairly accurate.. more curiosity.
    What mods other then Alky?
  4. Andrew
    Andrew New Member
    20G + support. Yeah I will be headed to the 4-door dyno day if they can pick a day.
  5. AWDimprezaL
    start the PPG fund
  6. Dream
    Or the STi tanny fund :biggrin:
  7. Andrew
    Andrew New Member
    what does a 6 sp tranny swap cost?
  8. Bullwinkle
  9. fobiawrx
    fobiawrx Fabiola
    you can go on nasioc and find people selling whole swaps in packages with red bows on them!
  10. matt_wong
    matt_wong Well-Known Member
    need video :)
  11. curly2k3
    yeah you might want to start thinking about the tranny now...preemptive right
  12. Kevin
    Kevin Well-Known Member
    not too bring this too far off topic but... are the 04/05 trannys the same as the 02/03, hence haveing the same problems?
  13. speedyham
    speedyham Well-Known Member
    The 04/05's are a little better, but not all that much. If you want a better tranny get an STI 6 spd or PPG's.
  14. Dynapar
    Video!
    Sorry to say but with LC I think your tranny will tap out very soon. It probably wont go quietly though. 6spd swaps are going for around 5k or so depending on year/mileage ect... theres alot more to it than just the tranny. you need an shorter (automatic/6spd) driveshaft and the matching R180 rear end. Also the axles might be different so you may need hubs/brakes/wheels/ect...
  15. Dream
    07 STi tranny's pretty much sway right into the 06+ WRX's, just need the drive shaft, shifter linkage and a DCCD controller :biggrin:
  16. Soupboy
    Soupboy Well-Known Member
    You already got one coming?
