No Boost on 02 wrx
Discussion in 'Modifications And Maintenance' started by project/driven, Feb 5, 2007.
  1. Bullwinkle
    What do you mean? For your Prodrive ECU?
    I really don't know much about that system. Is it a standalone ECU (IE, hardware that you can remove from the car)?
    The open source ECU tools won't work with anything other then a number of the stock subaru ECU's.
  2. Taras
    Taras BANNED
    Josh, honestly get yourself a stock ecu, they are not too expensive and before you have all the parts for stage 2 just flash generic stage one map. Sell your intake, bov(btw, i love that sound) and prodrive ecu. Go with Cobb AP or OpenECU.
  3. Hallywood
    Hallywood Well-Known Member
    opecu is the way to go, fawk cobb
  4. wall of tvs
    It's nothing more than an Ecutek reflash. The Prodrive ECUs are like the old Cobb ones that you could get before things like the AP came out.
  5. Taras
    Taras BANNED
    Not to steal Josh's thread, but i got a little problem too. The problem is quite the opposite though. I just notices that when i wot the car on 4th gear the boost goes all the way to like 20psi. And when it hits 20psi it bounces down and the car slows down a little. Could it be because i tightened the wastegate arm to much?
  6. Shibbs
    Yes. Very likely.
  7. Mike Wagner
    Mike Wagner New Member
    ^^My dog just had a seizor looking at your avatar.
  8. Hallywood
    that, and or your wgdc is too high now that you tightened the wg arm
    Idk what your wgdc are, but I tightened my wg arm and I am only needing a MAX of 44%wgdc now to reach 17psi for peak boost...werd
  9. Taras
    Taras BANNED
    I was using a different map and the car would not hit target boost, so i tightened it and it did. Now i flashed the old one back and its hitting way to much boost.
  10. Hallywood
    Lower your wgdc in the areas your overboosting, start low and work your way up.
  11. Taras
    Taras BANNED
    You mean using the Enginuity or just the arm? I was thinking i just need to loosen the arm a turn or so.
  12. tangledupinblu
    So it's not the bcs. Shibbs swapped it out with another stock bcs and same crap, half boost. Then he swapped the restrictor pill around and we tried again...fail. Unplugged the battery to reset the ecu. Checked out the actuator arm, looked normal. All hoses are good.
    Anyone else have any ideas as to why my car is boosting half way since it was introduced to Enginuity? Wanted to do a simple log and see what's going on, and now I have this issue, wtf!?
  13. Scuba Steve
    I'm no expert on this....but I'd run a log see if you can determine anything is out of the norm
  14. tangledupinblu
    That seems to be what caused this problem.
  15. Scuba Steve
    yeah, bummer. good luck. maybe WGDC?
  16. tangledupinblu
    Dunno, going to have it re-logged to see if it is something in the ecu. I may be bugged.:laugh:
  17. Hallywood
    Hmm valet mode?
    Didn't you say it was a EcuTek reflash??
    "Some EcuTek reflashed ECUs will reset to 'valet' mode after a battery disconnect. Turn the ignition key to the 'on' position (no need to start engine), press and hold throttle pedal to the floor, depress dashboard rear window defroster button. Release throttle and turn off rear window defroster. You may start the engine normally. Not all EcuTek reflashes will default to this mode. Some custom reflashes will toggle a slightly different tuning map instead of valet mode.
    This may not be your problem anyway since the valet mode does not cause a car to run that lean under boost, it mainly limits boost to about 7 or 8 lbs.
    Disconnecting battery power for several weeks does not cause the ECU to lose an EcuTek tune. The reflash is flashed to non-volatile memory meaning it is not power-dependent to retain the tune.
    You might consult with the tuner that supplied your EcuTek reflash or reflashed ECU. You might have to send the unit back to them
  18. Taras
    Taras BANNED
    The log could not cause this situation that for sure. Just get a stock ecu and see how the car runs with the stock one.
  19. wall of tvs
    Yup, try this.
    Simply plugging a cable into the car to log it will not cause any problems. :)
  20. Paul Revere
    LOL Hallywood your avatar is the best!
    Your friend is dead.
    Well when he wakes up make him drink.
  21. Bullwinkle
    Josh -- did you try this? I have a sneaking suspicion this might fix your problem.
  22. tangledupinblu
    Running out to the car to try it now.
  23. tangledupinblu
    Meh.
    I tried it twice, nothing.:emo: Second time I tried holding the gas down for a few more seconds...nothing, 1/2 boost. I fail at life.
  24. AWDimprezaL
    is your turbo shot?
  25. tangledupinblu
    It's not making any noises or leaking.:dunno:
    But it do has 137,600 miles on it.:eek:
  26. AWDimprezaL
    HMMMMMMMMMMMM you could use my MBC that is set at 10psi to see
  27. tangledupinblu
    Tonight at the st0nzez?
  28. AWDimprezaL
    indeed sir
  29. tangledupinblu
    3rik with a k is my most favorite 3rik of all.
  30. AWDimprezaL
    WEEEEEEEEEE!
  31. wall of tvs
    Check the line going from the BCS to the "T" near the turbo/WG actuator.
  32. tangledupinblu
    We checked and swapped...still nothing.
