No Engine...Ok to hook up battery?
Discussion in 'Modifications And Maintenance' started by WRXEcho, Oct 16, 2008.
  1. WRXEcho
    WRXEcho Well-Known Member
    New Hope - MN Bugeye Mafia #666
    This may be a stupid question, but I'm just wondering if anything crazy will happen if I hook up the battery to the car to check some electronics/wiring (gauges). The engine is out of the car.
    Thanks,
    - Justin K.
  2. Shibbs
    Just make sure your Oxygen sensors aren't touching anything. They're heated and melt thru wires in a HURRY!
    Unplug them and you should be fine.
  3. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    unplug the fuel pump controller or you will be primming the garage floor
  4. WRXEcho
    ^^^that's what I was thinking...Is that the little green connector under the passenger side carpet? Would that cut power to the pump?
  5. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    in the rear passenger side quarter panel in the trunk. its a box in there. un plug that first and you should be fine i would think
  6. WRXEcho
    So, in a wagon, behind the wheel-well carpet, I assume?
  7. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    i would think so? check it out
  8. WRXEcho
    haha...true. I found a picture of the controller, so I know what it looks like. I just like to know what I'm looking for before I go in there! :)
  9. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    its the onlk 4x4 or 5x5 box in that area. has a wide plug in it
  10. piddster
    Boostonia
    LOL!!
