no fuel
Discussion in 'Modifications And Maintenance' started by rshoop2, May 30, 2016.
  1. rshoop2
    rshoop2 Well-Known Member
    2013 sti put in a new pump and fuel regulator and have no fuel pressure,first off should i have fuel shoot into a jar when i disconnect the main feed line and turn the key on after several cycles to prime? I don't have any fuel flowing from the main feed line,I shouldn't say none I have a trickle when first turn of the key. changed back to pump I know worked for sure and the same problem.fuel regular is set up fuel from main line to injectors return to fpr goes in the side then out the bottom to return line. aeromotive fpr. help please thanks
