Well I have a FMIC and my noob question is, Would i be able to use the FMIC with my setup. Would the FMIC be more affective that other ic. My setup Walbro Pump, modded injectors 688cc, Intake, turbo inlet, BCS , Down pipe, up pipe, CBE, and VF39 turbo. if it matters i have 90k on my motor.
Yeah, you can use an FMIC for that. I ran a very similar setup before the current setup. Only difference was the VF34 vs. VF39. You should be fine.
I got a question to go along with this questions.... Will it be ok to use FMIC with stock TD04 and some other mods?
TD04 and LAG don't belong in the same sentence on anything over 1.6 Liters. There will be MORE lag than with a top mount, but that's on every FMIC. It would be pretty much pointless for the TD04 unless you're maxing out your topmount somehow.
Thats cool. How much were you boosting? what kind of numbers did you put out? Just wondering thats all
From all that I've read re VF39 swaps many folks get best results just running the STi TMIC vs. other aftermarket TM or FMICs. Difference in price might be best directed to a prot00n.
