Not much left, 92 SVX partout
Discussion in 'For Sale : Group Buy/Bulk Lot/Part Outs' started by Chux, Oct 4, 2018.
  1. Chux
    On the off chance someone needs something.
    2018-07-31_08-28-28
    by Numbchux, on Flickr
    Definitely not available/usable:
    -Engine/accessories gone
    -Rear diff seized
    -exhaust broken
    -most body panels are wrecked
    -curved upper glass sections
    -obvious resellable parts were pulled long ago, lights, gauge cluster, radio, spoiler
    -RH control arm bent
    -LH tie rod bent (makes me question condition of the rack)
    -radiator/evaporator
    -glass has been busted out for about 10 years, so most upholstery is pretty ratty (although surprisingly not too bad, might have been covered for awhile)
    Definitely good:
    -Fuel door
    -trunk lid
    -I'll be using the RH door on the '97 due to rust, so I'll have an extra door card, window regulator etc.
    -ABS pump, probably other under-hood stuff, though I might keep the big-bore master
    -some interior plastics
    -maybe wiper motors (if someone needs one, I'll pull it and put some power to it before shipping)
    -fuel tank, AFAIK pump and sending unit are there, again I can bench test if there's interest
    -rear bumper?
    -rear glass, but I'm not pulling it (come pull it yourself, or I'd have a glass service come pull it).
    lmk if you need anything. Probably won't scrap it until the spring at the earliest.
  2. Todd
    Todd The Originator Staff Member
    Brakes? It has the same bolt pattern as BUTUGLY the Truck.
    If the rotors/calipers and brackets are good enough for mocking up, I'm interested.
  3. Chux
    Rear brakes are all gone.
    Front brakes are all present and in tact. Has fancy drilled rotors on it, although pretty rusty from sitting for 10 years.
  4. Todd
    Cool. I just want to mock-up to see if that would work. What do you need for them?
  5. thomas franz
    Do you have the spare tire?
  6. Chux
    It's probably there.
    Although, I noticed your post in the WTB section. FYI, SVXs are 5x114.3.
  7. Todd
    I did not hear back about the front brakes... If you still have the calipers/mounting brackets/rotors, how much $?
  8. Chux
    messaged
