obsolete's 2008 WRX maintenance & mods
Discussion in 'Modifications And Maintenance' started by obsolete, Jan 7, 2026.
  1. tangledupinblu
    Yeah! I was out at JM the other day and mentioned what sounded like clutch chatter, but was likely a front heat shield. Tony discovered the noisy heat shield and tried to kind of bend it so that it wouldn’t rattle. Essentially, it rattles worse now! Haha. Time to tear that mofo out
    Krazylegz1485 likes this.
  2. obsolete
    obsolete Well-Known Member
    Shedding unnecessary parts over time...it's what makes a Subaru a Subaru.
  3. Krazylegz1485
    Right? Like I know they're put there for a reason to begin with but at some point they're just gonna get removed because a guy can only re-engineer them so many times before it's just a waste of time and effort. Haha.
    The pic above is the wife's car and my god was it a pain in the ass getting those ones off the headers. Actually had to drop the exhaust down off the heads because they have the o2 sensor going through a hole in the shield... :banghead:
  4. tangledupinblu
    Oooof!
  5. obsolete
    What are we doing for faded paint/clear coat on the hood scoop? I've been seeing ads for Eastwood 2k color-matched spray cans--too good to be true?
  6. predavore
    predavore Well-Known Member
    Carbon fiber wrap it. Honestly, I thought about the same thing. Sand and respray. Test on something else and compare.
  7. tangledupinblu
    The scoop and tha spoilah. On mine anyways.
  8. Superglue
    Superglue Well-Known Member
    Overtake and Grimmspeed both have color matched sprays
    obsolete likes this.
  9. obsolete
    Overdue for an update. Got the A/C fixed. I guessed the leak was in the condenser and it looks like I was right. There was barely any refrigerant in the system when I opened it up, now it holds vacuum for days. I also replaced the expansion valve and all the o-rings in the engine bay while I was in there.
    I couldn't get any R134a out of the self-sealing valve in the Chemours can so I had to use the scary side piercing can tapper:
    The valve in the Shop Pro R134a can from AutoZone did work properly, so I was able to get 15.7 oz. of refrigerant into the system, pretty close to the 16-19 oz. the sticker under the hood calls for:
    I knew the system had lost some oil from the bright green spots on the driveway when it failed, so I put 2.5 oz. of new PAG 100 in the condenser before I sealed it up. Total guess, but the worst case is that the extra oil just displaces a little refrigerant. Better than not having enough. The pressures seem high: 55 psi on the low side, 225psi on the high side at around 80F. Maybe more like 85F in the engine bay? Might be slightly overcharged but we'll see how it goes. Just nice to have cool air coming out the vents again.
  10. predavore
    So good to see that car get some love. It did sit around more than I wanted it to.
  11. obsolete
    Thanks man! I've driven it every day this week and the A/C is working awesome, so I think I'm ready to call that fixed.
    Now something in the steering or suspension is creaking/groaning at high steering angles. Sounds like a dry ball joint or tie rod end...maybe strut mount? It's always something.
    Hopefully I can win the game of whack-a-mole with this car by September or October and have it ready to sell again.
  12. obsolete
    Lately I've been noticing a little stutter/hesitation around 2,500 RPM when accelerating at part throttle. Not bad, but it just didn't feel smooth, and it was pretty repeatable, so I decided to try to see if I could fix it. @predavore installed new plugs and coils within the last few thousand miles before I bought the car, so I knew it wasn't that.
    Yesterday I decided to pull the intercooler and clean the throttle body. It was a little dirty, but nothing crazy. I cleaned it up with B-12 Chemtool. I disconnected the battery like a good boy before unplugging the throttle body. I also hit the TB connector with some contact cleaner before I plugged it back in. Got the expected high idle on the next start after reconnecting the battery, and the car ran sort of weird on the first drive, but good enough to get me to work. I've driven it a couple more times since and it seems to have settled down, drivability everywhere is good except for one thing--it now idles low and lumpy like a cammed V8. You can see the engine shake and feel it shake the car.
    Did I screw something up, or do I just need to wait a little longer for the computer to figure itself out?
  13. Krazylegz1485
    I don't know if this is applicable, but on my wife's 09 Outback every time I'd clear the CEL (which is quite frequently...) it's like it would go into stupid mode and forget how to idle. It would idle really low and sometimes even die on her. I did the full idle relearn procedure (after cleaning the TB) and it seemed to help, although the CEL's just stay on now because she's less bothered by the lights flashing and lack of cruise control then she is the sh!tty idle situations.
    So long story short, maybe try the idle relearn thing? I looked it up online and couldn't tell you the specifics off the top of my head.
  14. obsolete
    Thanks. Turns out I screwed something up. Left the hose for the BPV disconnected from the intake manifold, underneath the intercooler. Oops, big ol' vacuum/boost leak. I had a buddy over hanging out in the garage and was trying to wrench and talk at the same time, and my brain doesn't multi-task too well...
    I'm used to a vacuum leak leading to a high idle, but I guess the computer was trying to compensate, maybe pulling timing to try to keep the RPMs down? Anyway, I fixed it tonight and took it for a quick test drive. Idles fine now.
    The 2,500 RPM stutter still seems to be there. I think I can rule out the plugs, coils, and throttle body now. What's next? Clean the MAF?
  15. obsolete
    What are we doing for manual transmission fluid these days? The 5MT has Subaru stuff in it as far as I know, and it shifts great. Keeping good shift quality while cold is definitely a priority.
    The Subaru 75W-80 "Extra MT" can't be bought in less than a 5 gallon bucket, which ain't happening. Motul and Redline both have multiple options. I've used Redline in other cars with good results, but never in a Subaru. I would lean toward the MTL 75W-80 to match the factory spec, but Redline appears to recommend their 75W-90NS.
  16. blackozone
    I've used motul in and STI transmission with good results. The 5MTs are a different animal of course, but the fluid quality was good. Redline has always been good in race cars I've ran in the past too. Amsoil makes good options as well, so basically any quality fluid should suit you just fine. Just stay away from the Scotty Cocktail.
  17. obsolete
    Thanks. I assume the Motul fluid you're referring to is Gear 300? Lol, Uncle Scotty's Cocktail, that takes me back...
  18. blackozone
    Yeah, I used Gear 300 in the past.
  19. obsolete
    Well shiat:
    I need some rear springs.
  20. Krazylegz1485
    As much as that sucks I'd take that task over a lot of other things, tho. At least it's pretty straightforward and relatively easy.
  21. obsolete
    Yeah, here's hoping I can get the lower bolts out without breaking them.
    So here's what I've been able to figure out. The RCE black rear springs are 250 lb/in. They are no longer available anywhere and I can't find any used sets. The best option I can find is the STI pink springs, ST20380ZR020. They are 224 lb/in and have a similar drop in ride height to the RCE springs (10-15mm). I wouldn't mind a little less rear stiffness. I can get a pair for about $240 shipped from Japan. Not thrilled about it, but unless anybody has a better idea (or a pair of springs sitting around) that's probably what I'm going to do.
  22. Krazylegz1485
    You'd think with all the Subie bros we have around the metro that immediately swap everything to cheap coil overs that there'd be a plethora of used stock stuff around. Haha.
  23. obsolete
    I could just go back to stock suspension, there's a guy on Marketplace with a full set of 2014 takeoffs for $200...
    I suspect it would make @predavore sad but it wouldn't be a bad move for the car at this point. Gotta think about it.
  24. predavore
    Dude, I'm sad you are having this problem. Stock ride wouldn't be so bad with winter coming up.
  25. obsolete
    Thanks. I compromised and ordered a pair of '08 STi rear struts + springs from eBay for $100 shipped. That way they show up at my door instead of having to spend time driving to meet up with somebody from Marketplace.
    These should be the 194 lb/in rear springs, same as '09+ WRX, and the correct length for WRX rear struts. I'll try them on the Bilsteins, assuming they're salvageable. If they lift the rear of the car noticeably, I'll cut like half a coil out of them.
    predavore and tangledupinblu like this.
  26. predavore
    Obviously the car came with 08 suspension which I upgraded to 09 WRX gear. I did a write up on it on here somewhere. Then eventually went with the RCE Blacks on Bilsteins. I can't remember if I had SPT spring in there or not. I did the sway bars at the same time, maybe?
  27. predavore
    Yeah, the pinks were in there.
