Official Craigslist Thread
Discussion in 'FS: Cars, Motorcycles, Boats' started by prezawagon, Jan 11, 2006.
  1. TSTRBOY2004
    and
    DO NOT LOOK LIKE THE SAME ONE!!!!
    both pics linked from their respective posts...
    your point????
    although they may very well be the same seller, I dont know.. if its you then KUDOS.. pat on your back.. hoorah
  2. RexNEffect
  3. retreif
    I just thought I'd give the guy a free bump if it is the same guy. I knew I had read about one of these in the St. Cloud area before. If it's not then kudos to you?
  4. SubiDG
    SubiDG Member
  5. yarpirate
    yarpirate BANNED
  6. jamusix
    jamusix Well-Known Member
    Yeah I was wondering about that... :rolleyes:
  7. Warthog
    Warthog Member
    I think it's that green sticker on the bumper = +500hp. I need to find one of those so I can add $37000 to the value of my girlfriends '97 wagon.:rolleyes:
  8. qstarin
    qstarin Well-Known Member
    It's not like its an obvious typo where the guy accidentally hit an extra 0 or anything.
    :cool:
  9. KSAL
    KSAL Well-Known Member
  10. olegrad
    olegrad Well-Known Member
  11. jdm4you
    jdm4you New Member
    ^ WOW is right! That wont last long!
  12. Paul Revere
  13. qstarin
    wow. That's a pretty insane deal.
  14. dman
    dman New Member
    Just looked at it. Looks very clean (even has those OEM CF trim bits). Drives okay, haven't driven RS in a looong while and it seemed kinda gutless relative to a beaten-down SS, where I expected it to be on par.
    I didn't feel like buying it without having a look at it on the lift, and the guy said that he thinks he'll sell it as is over the weekend and if I want mechanic to check it out I should call on monday....
    Still in the coffee shop nearby thinking whether I should go back and buy it anyway. If I had a garage I would've bought it already :)
    Good luck getting it guys
  15. John16V
    John16V Well-Known Member
    Anything else? Timing belt? Headgasket? How's the clutch?
    I'll let my friend know if he interested in this..... I don't know.
  16. dman
    dman New Member
    Ok, here's what I know:
    -Allegedly was owned by a mechanic who traded it for a Jeep.
    -Claims to have done brakes recently (but rear rotors are pretty worn, so I'm guessing pads only).
    -Owner thinks that the previous owner didn't have any problems with headgaskets, meaning they weren't done probably.
    -Tires looked decent but I did not check if the matched/size
    -Couple of curb-rash spots on the wheels.
    -No engine codes were stored in the ECU,
    -Some mild darkish residue on the walls of a coolant tank, no idea what it was.
    -Couple of fluids need changing.
    -Suspension seemed original, and a bit worn in the back, also some metallic noises from rocking the back corners, but somewhere from the middle of the car =) I guess some heat shield.
    -Valve covers looked dry and clean from the top, didn't have a good look from the bottom since my flashlight died while there.
    -Timing cover looked clean, but when engine was idling there were some minor chirps seemingly from the timing area so no idea if the belts were done. Owner called the 'mechanic' but said couldn't get him and only left a message so no info on that right now.
    -Jacking plate is covered in oil, so I'm guessing rear main leak and the clutch is original.
    -Clutch pedal felt weird, slow to return and I didn't feel the clutch grab at all, seemed to grab at random spots =) (SS also has hydraulic clutch and I works fine, this one seems to need attention).
    -Given that I did not feel where the clutch was grabbing I can't tell how did feel engaging. But I did try pulling the clutch pedal in while in 5th gear at 50mph letting the RPMs drop to idle, and sidestepping the clutch and looking at tachometer and feeling the car. I was pretty fast to get to original RPMs so I think clutch disk still has some life left.
    -Some weird minor noises when you floor the engine. I didn't like those, but I'm too picky.
    -It braked in straight line, brake booster tests (like pressing the pedal when engine is off etc) went fine.
    -Its missing the intake breather. Didn't ask why...
    -And like I said, it felt somewhat sluggish but that might be because I didn't drive RS in a while and didn't feel the clutch.
    -Guy says he has a clean MN title in hand, I didn't check carfax though.
    -Body looked straight, and nothing looked bent/signs of being bent in the past when you look under the front/rear bumper.
    -Shifted decently, no grids it seems.
    -Shifter bushings were either new or upgraded, felt very tight.
    Thats about all I checked
    Make sure your friend checks it out quick though.
  17. John16V
    Thanks for the great info, Dman. I'm sure others here would like to know too.
  18. Ctracey218
    Ctracey218 Playpen Wrangler
  19. dman
    dman New Member
  20. predavore
    predavore Well-Known Member
  21. Shibbs
  22. bobafett04wrx
    bobafett04wrx New Member
  23. bobafett04wrx
  24. predavore
  25. qstarin
    Saves me hella work finding some prices for my part-out, though. haha. (not that I'd use their prices, but at least it lets me know what's probably too high).
  26. rsverv
    rsverv Well-Known Member
  27. souy07
    souy07 Well-Known Member
  28. silver03
  29. mctenold
    mctenold Well-Known Member
  30. John16V
  31. RexNEffect
  32. KSAL
  33. qstarin
    That's a good deal!!11! :laugh:
  34. ortho004
    ortho004 Well-Known Member
    His keywords are longer than the actual ad and include everything from Lincoln to Edelbrock... I bet that will help his cause, oh and the fact that he replaced every mechanical part front and rear...
  35. mctenold
  36. silver03
  37. jamusix
    From what I've read 225's are a little wide for the stockers... and wider is not better when it comes to snow. Just my .02
  38. mctenold
    http://minneapolis.craigslist.org/pts/1133347550.html
    Seems like a good deal...not an expensive wheel by any means, but might be a good winter setup?
    Anyone heard of these? I did some research and got some NASIOC threads with people rockin' these. Doesn't seem to be any really bad reviews.
  39. Shibbs
    That's a very decent snow tire package. We put Kazera wheels on people looking for lower cost winter wheel/tire packages at Lexus. They seem to hold up well.
  40. RichWRX
    RichWRX Well-Known Member
  41. fondune
  42. idget
    There are some very important details missing from that posting. Assuming the wheels are dual bolt pattern like in the picture, I'd want to know the wheel width and offset as well as the tire depth. Assuming the width and offset work for your application and the tires have 6/32 or more, I would consider it a good deal.
  43. Gridlocked
  44. gran0393
    gran0393 Well-Known Member
    wow flagged already
  45. qstarin
