Official Craigslist Thread
Discussion in 'FS: Cars, Motorcycles, Boats' started by prezawagon, Jan 11, 2006.
  1. Navar Hren
    Navar Hren Active Member
  2. powdered toast man
    powdered toast man Member
    Krazylegz1485 likes this.
  3. drac77
    drac77 Well-Known Member
  4. derp
    Nice car but I'll keep mine.
  5. Mnelson
    Mnelson Well-Known Member
  6. curly2k3
  7. Mnelson
  8. curly2k3
    Tell her not to be a Nancy and do something different and fun.
  9. curly2k3
    It should be noted, she could also plow, salt/sand and make extra money all winter... Put her to work.
  10. tangledupinblu
  11. Mnelson
    I also found this: https://minneapolis.craigslist.org/hnp/cto/d/2005-subaru-outbackmiles/6719207362.html
    The guy is close to the girlfriends apartment so I thought we'd take a look tonight. He said the valve cover gasket is leaking (which ive replaced before) but there was oil in the spark plug gallery and it had a miss at one point. Im hoping its because the plug wire got soaked..
    He said he bought it to sell it so it seems like he got it for cheap and wants it gone.. too good to be true?
  12. Krazylegz1485
    "Half price" because valve cover gaskets "leak a little" seems a little weird. I'd say just give it a good look over and don't be afraid to pull the wire boots out while you're there.
  13. subie-roo
    subie-roo Well-Known Member
    Krazylegz1485 and Mnelson like this.
  14. Mnelson
    He implied that he was going to fix the seals and sell it for 3-3500 but didn't have the tools to do all of it himself so he wanted it gone for 2500. It also sounds like its had some body work done.
    Either way, ive heard the plug seals going bad can cause the missing and it being kind of common on N/A blocks. Might have to grab a compression tester and give it a spin anyways. I keep telling myself that if anything goes on the block, ill just swap in the forester block (80k), since the transmission seems to be going bad on it. I have to remind myself almost daily, that this kind of thinking doesn't solve my "having enough running cars" problem.
  15. Navar Hren
  16. Krazylegz1485
    Mnelson likes this.
  17. Mnelson
    Update on this for anyone who cares: https://minneapolis.craigslist.org/hnp/cto/d/2005-subaru-outbackmiles/6719207362.html
    '05 Outback (160k).
    Chassis -
    Front driver fender and driver door were repainted but not very well. The paint was recent but not brand new. I don't think the seller did the work but I've been wrong before. I did find a little surface rust on the bottom of the driver side door (front and back), and a little less on the driver (front only). Rust is only where the door skin wraps around the door frame at the bottom. Door jams/frames themselves are clean, a little orange tint by the plastic side skirt, probably from the door rust and not actual surface rust. Hatch doesn't have any rust, and closes nicely. A few dings around the car but looks good from 5 feet. Overall body 6.5/10?
    Underneath, I don't see much surface rust. Seller said the sway bars and (rear?) wheel bearing were recently done.
    Power train -
    Drives alright. No shakes in neutral coasting or on the brakes. Engine is missing (shuttering/hesitation) while on the throttle but feels like it has more torque than my 01 forester (80k). Steering feels tight, no whining at full lock. No strange noises that I heard on quick trip I took.
    Oil leaks are coming from the spark plug seals and filling the plug gallery. Outer valve covers seem fine and the leak isn't making it to the bottom of the heads... with that being said, the head gaskets are definitely bad. I wiped the oil away from the head/block gap and saw it start to pool up again. It looks like its just an external oil leak, though I didn't have my borescope to check the cylinder. Coolant is green so its still separated. I would guess the plug leak is the source of the misfire because of how wet it was on the outside. No matter what, this car needs HG's and seals.
    Honestly, I would buy it as a daily if I didn't NEED to find the GF a reliable car. I may do it anyways, especially if the STI sold... but timing is bad for me. Seller seems decent. Buys/sells from a body shop in maple plain.
    Navar Hren likes this.
  18. JaloP
    JaloP Well-Known Member
    His price seems a little steep for what all you're saying. If you do plan on dropping the Forester engine in there than maybe it's worth it, though I'd try to talk him down a little. HG kits are about $300 not to mention the time you have to put into it. That is if you're going to do it yourself. If not than depending on where you go, could be a $2k fix.
  19. Mnelson
    He asked me for an offer after I told him about the HG and I didn't have an answer for him. I did a set on an EJ251 before... it was about $300 not including the timing and other odds and ends. I don't have a problem doing it again but I still need a daily for the GF. I hate being a low-balling a-hole but I would have to scoop it up pretty cheap to make it work.
  20. JaloP
    Haha, yes I understand this all too well.
    Yeah true, another couple hundred for the timing kit.
  21. LASERBLUE135
    ryjacobs likes this.
  22. Navar Hren
  23. subie-roo
    Solid deal, but if I’m not mistaken this is Original Owner Autos who have a known bad reputation.
    @Navar Hren if you want one badly enough you can buy mine, and it’s a 5MT :p
  24. idget
    Dunno about him and dunno if srs, but I am!
  25. Navar Hren
    No, unfortunately I am all tied up with an e23 745i build. Assuming it is in fact Original Owner Autos, run like hell. Those guys are f*cking horrid.
  26. subie-roo
    I’m starting to realize that 4 Subaru’s may be too many for me to manage. And since the RS is my side-Subaru, and not my main squeeze she may need to go.
  27. idget
    lmk when that time comes! Looking for a smaller, year-round commuter to use when the 4runner is inconvenient/cumbersome. Fair warning... I might H6 swap it if/when the headgaskets blow.
  28. Krazylegz1485
    Judging by the pics (random parking ramp top), I'd say your assumption is probably correct.
  29. subie-roo
    Headgaskets are new so it would likely be awhile, but it would be a great commuter.
    mctenold likes this.
  30. derp
    Oh wow. I might also be interested lol
  31. Eazy_E_Rich
    Eazy_E_Rich Well-Known Member
    I've talked to this guy a bit, he's selling this WRX needing a transmission. Seems like a reasonable price and I have a transmission and diff to drop in. With the motor out of my build right now I don't want to scoop this up, but if someone else does I can work a deal on the transmission. I just swapped the trans in my car, took about 5-6 hours by myself. Probably less if you've got help.
    https://rmn.craigslist.org/cto/d/2003-subaru-wrx/6721704901.html
    https://rmn.craigslist.org/pts/d/subaru-forester-xt/6713139923.html
  32. Navar Hren
    I love that the ad is essentially 4 pictures of a tired CF hood.
    Mnelson, LASERBLUE135 and mctenold like this.
  33. mctenold
    mctenold Well-Known Member
    Price?
  34. LASERBLUE135
    He says the motor runs fine and its in decent shape. What does he say about the body/rust. Its got 200,000 on the odometer. Not worth much with that many miles unless it looks really good.
  35. tangledupinblu
    @idget
  36. pillboy
    You should see his Tinder account.
  37. subie-roo
    If I was serious about selling I’d probably look for $7k obo.
  38. housemusic1
    housemusic1 Well-Known Member
  39. tangledupinblu
  40. mctenold
  41. jubella2
    jubella2 GC8 FTW
  42. drac77
  43. drac77
  44. jubella2
    jubella2 GC8 FTW
  45. silver03
