Official Craigslist Thread
Discussion in 'FS: Cars, Motorcycles, Boats' started by prezawagon, Jan 11, 2006.
  1. Krazylegz1485
    GrawvyRobber and tangledupinblu like this.
  2. JaloP
    JaloP Well-Known Member
  3. pcwerk
    pcwerk Well-Known Member
  4. Vector
    Vector Rally Organizer
    I'd say given that it clearly needs a water pump and almost certainly a timing belt and associated pulleys, it's not really any kind of deal. Oil leaks could be hg, rear main seal or a dozen other things ranging from trivial to terminal. That said, it could be a fun beater and rallyx car with the 5mt. If I had space I'd offer $500 for it.
  5. tangledupinblu
    He did say “someone with mechanic skills”. That’s still like another what, $500-800 in parts? But $500 would be what I’d offer as well
    Krazylegz1485 and pcwerk like this.
  6. 06LGT
    06LGT Member
  7. pcwerk
  8. iamsam
    iamsam Active Member
  9. 06LGT
    06LGT Member
  10. Krazylegz1485
  11. GrawvyRobber
    GrawvyRobber Active Member
    It was the Yee to someones Haw
    Krazylegz1485 likes this.
  12. pillboy
    I'm guessing it is just a picturesque backdrop for the ad's photo shoot.
  13. Krazylegz1485
    Could also be the Yee to someone's Yee. Haha.
  14. 06LGT
    06LGT Member
    silver03 and Krazylegz1485 like this.
  15. Stormtrooper1
    Stormtrooper1 Well-Known Member
  16. drac77
    drac77 Well-Known Member
    silver03 likes this.
  17. derp
    while excellent, that price tag puts it out of reasonable reach.
  18. drac77
  19. Krazylegz1485
  20. LASERBLUE135
  21. tangledupinblu
  22. drac77
  23. ryjacobs
    ryjacobs Well-Known Member
    You’d think they’d at least replace the fog light before listing it on BaT.
  24. derp
    No i wouldn't, people are idiots.
    euro likes this.
  25. pillboy
    This is proven every day in oh so many ways.
    euro likes this.
  26. silver03
    It’s ironic that this is posted on “bring a trailer“. It should also be on the sister website “keep a trailer“...handy.
  27. GrawvyRobber
  28. euro
    euro Well-Known Member
  29. Krazylegz1485
  30. GrawvyRobber
    I get it, my standards are low
  31. Krazylegz1485
    Quite the contrary, my friend. I love finding the quirky stuff on there. Makes up for striking out over and over looking for Subaru parts/projects.
    GrawvyRobber likes this.
  32. silver03
    I sent the owner an email to find out exactly what it would need. If I get a response, I will update everyone.
  33. silver03
    Since we've had her, we have done the following.
    2010 - replaced the starter
    2014 - replaced head gasket, and the thermostat as well since I was in there.
    - replaced distributor cap/rotor/wires/spark plugs trying to track down a stalling problem when idle.
    - replaced the fuel injection pressure regulator and it finally solved the idle issue.
    2015-ish - replaced the tires. They have less than 5000 miles on them, as we started using her less and less.
    - replaced the front/rear brake shoes/pads around the same time.
    2019 - replaced the battery
    Her current problems are as follows. I just don't have the time or desire to look into them further.
    - Some kind of gas tank leak when filling the tank. Not sure if it's a gasket on the top of the tank, or an actual tank leak. Seems to not leak when only filling 1/2 tank, which has been the solution for the last 5 years.
    - Re-occurring check engine light, which throws 4, 15 and 17 codes. This manifests itself as sluggishness above 40 MPH which eventually clears up and goes away and then comes back again at some point.
    - Starting in the last few weeks, there's a vibration that starts at around 35 MPH and then gets worse as speed increases.
    - Broke something on the speedometer cable during the head gasket work. It's a 2 part cable, and I can't seem to source the 2nd cable to replace it. We use a Garmin to check speed.
    - Windshield wiper fluid container leaks from a crack on the tank mold joint.
    - Oil pan gasket needs replacing
    - Passenger side door lock is different than driver's, ignition and hatchback locks, so therefore doesn't work.
    - Heater fan controller only works on high. From what I understand, this is a known issue. It REALLY heats well in the winter.
    minnesotanice likes this.
  34. Krazylegz1485
    I have a feeling that in a car like that the speedometer isn't all that critical...
    And the ad is deleted now. Which one of you snaked me!?
  35. GrawvyRobber
    I've been hunting for something to mash on at the track. 5sp, older than 2000ish, little to no rust. Might end up being a Miata bro
  36. Krazylegz1485
    Please give my condolences to your man card. Haha.
  37. tangledupinblu
    Sheata!? Bwahahaha. But seriously though, it’s a good track car and you can find them cheap so you can buy a good helmet!:D
  38. Krazylegz1485
    I know. I'll just never say it out loud.
    And no, I wouldn't drive one even if I could fit on one. Haha.
    Okay, maybe I'd try driving it once but would definitely not own one.
  39. 06LGT
    06LGT Member
  40. minnesotanice
  41. drac77
  42. Mnelson
    Mnelson Well-Known Member
    Honestly, I'm not suprised a 08+ ej257 nuked itself between 45-60k, regardless of the amount of mods.
  43. silver03
  44. drac77
  45. drac77
