Oil not priming.
Discussion in 'Modifications And Maintenance' started by Fozzy25xt, Feb 21, 2013.
  1. Fozzy25xt
    Fozzy25xt New Member
    so after the first turbo i figured id put in as much precaution as i could. So this time i got everything hooked up pulled the banjo bolt filters and all. got her all put back together now. Now Im priming.
    I put the oil feed line onto the turbo and pulled the IGN fuse and cranked like i was supposed to. just in case I unscrewed the bolt after a few trys to check if its getting oil and im seeing non. what can be causing it to not come up?
  2. Fozzy25xt
    Also Turbo is just Stock TD04
  3. AWDimprezaL
    Try starting it for a split second, the turbo will likely not spin much at that point. If you're scared, dump some oil into the turbo. Unless you have an oil pressure problem, oil will prime into it eventually.
  4. Fozzy25xt
    ohh i see no i was just trying to be cautious is all lols
  5. Terry Ammerman
    Check the oil line all the way back to the beginning and make sure it is not kinked or blocked some how. I think this lessen has cost you enough.
  6. Fozzy25xt
    well after everything the car is running well now. oil seems to be running through a lot better than when i had the banjobolt filters in. iv taken them out and turbo seems good to go
    Terry Ammerman likes this.
