Opinions on aftermarket radiator cooling fans...
Discussion in 'Modifications And Maintenance' started by WRXEcho, Mar 24, 2009.
  1. WRXEcho
    WRXEcho Well-Known Member
    Just wondering what a good upgrade from stock would be. One of my fans is toast on the 4EAT, and I might as well just upgrade. Any opinions or ideas on some new ones? Or should I just stick with stock fans?
    I saw the Mishimoto radiator/fan shroud, but didn't really find any other options in my limited search.
    I have a koyo radiator...
    Thanks,
    - Justin K.
  2. Iroc-Z
    Iroc-Z Well-Known Member
    I would just run stock fans. In my experience all the aftermarket fans I have installed on other cars don't get the job done. Especially if you haven't had a cooling problem with the stock fans except for them failing.
  3. WRXEcho
    That's what I was thinking... Thanks :)
  4. slowrex53
    slowrex53 Well-Known Member
    Well im running some FAL slim fans on my car and i must say that when they turn on and ive got my hood open, you can feel the huge amounts of air they're moving. Im very happy with them!
  5. dipp
    dipp Well-Known Member
    im in the process of putting dual 12" flex-a-lites on my car I will snap some pics when im done.
  6. slowrex53
    Hey DIPP are your FAL fans two separate unites or are they both in one big housing. If they are in one housing those sound like the same ones i have. Let me know if you have any questions on wiring them up.
  7. piddster
    Don't do what I did and run both on one factory relay. The relay will cook itself eventually, and then the same thing will happen to the plug.
