P0420 :(
Discussion in 'Modifications And Maintenance' started by Wrx Snatch, Jan 12, 2014.
  1. Wrx Snatch
    Wrx Snatch Member
    What do you recommend I do to fix should I do the downpipe and can't delete and then get a tune
    my car is all stock 2004 wrx wagon
    i've cleared the code keeps coming back
    I did an snow x event last sat day and it popped on
    I've called Subaru dealerships and I gave them the code they told my cat is bad
  2. thomas franz
    Found this in the Nebraska Subaru community,
    -99.9% of the time P0420 and P0430 CEL Error Codes Are Associated Only With The Post (rear) O2 Sensor in modified exhaust systems (in or after the cat).
    This sensor is also known as the 'Heated Sensor Circuit' or 'Bank 1 sensor 2'.
    If it is the cat that is bad i would just replace the DP with a new catless DP. I dont think you would need a tune to run a new DP either. If I were you I would get in touch with NF and see what their parts prices are, grimmspeed makes a very nice downpipe.
  3. thomas franz
    not sure if the censor info will be relevant to you but if its not the cat going bad that would be your next spot to look
  4. Wrx Snatch
    Wrx Snatch Member
    They have I website
  5. Cotts612
    Cotts612 Well-Known Member
    Pretty sure you would need a tune for a catless dp. Get in touch with Nuke at NF.
    On another note, do you still have that catted up pipe on the car? Better get that off as well. No tune needed for a catless up pipe.
  6. john
    john Well-Known Member
    Are you running a catless downpipe?
  7. Bryan621
    Bryan621 Well-Known Member
    Pick up a downpipe, get ahold of NF (search in the top right of site) and have them install it at the shop and tune it right after. You do need a tune if you run a downpipe. That's what I would do.
  8. thomas franz
  9. idget
    Before you go throwing away money, at least inspect the sensor. Its possible that you damaged or disconnected the wiring to the rear O2 sensor at the snow-x. Wouldnt be the first time something like that happened.
    ryjacobs likes this.
  10. Medic_538
    Medic_538 Well-Known Member
    the sensor is maybe a hundred $. A dp and install and tune.... more that that!!
  11. Bryan621
    Ya but its so much better
    Medic_538 and Cotts612 like this.
  12. Wrx Snatch
    Wrx Snatch Member
    All OEM exhaust and yes it would be better
  13. Wrx Snatch
    Wrx Snatch Member
    I'm taking it into a Scooby dealer on Friday and narrow it down to what it is figured I'd start there it could be the cheaper option
  14. Nuke
    not surprise if the cat is dying
    spudd likes this.
  15. GiMp
    GiMp Well-Known Member
    The dog too
    Wrx Snatch and Ryan FailRad like this.
