parking brake light on even with lever all the way down
Discussion in 'Modifications And Maintenance' started by JasonoJordan, Sep 10, 2010.
  1. JasonoJordan
    Model: WRX
    Year:2002
    Mods: Relevant mods to the issue would be turbo-timer.
    It started out as a intermittent issue only when taking sharp corners at high speed it would kinda flicker on and off. it has now since stayed on and will not go off. Anyone have a idea what would cause this issue?
  2. AWDimprezaL
    Low brake fluid.
  3. JasonoJordan
    it has been toped off when i bled my brakes i will check it when i go out to the car later today to make sure its still full. any other suggestions?
  4. Bielke55
    brake pads are LOW causing the brake fluid to drop, causing the sensor to trip, causing the brake light to come on
  5. JasonoJordan
    would that be caused by low parking brake shoes or low brake pads. both front and back are over 85% pad not sure on the parking brake shoes
  6. AWDimprezaL
    Check you're brake fluid first, then come back with more questions.
  7. JasonoJordan
    while it was lower then i expected it to be it was still above the low line but i toped it off anyway but the light remains.
  8. Threshld1
    Threshld1 Well-Known Member
    Try poking the float, I've had them stick on me though it was on a much older car.
  9. JasonoJordan
    where is the float located? under the filter in the fluid reservoir
  10. JasonoJordan
    ecu must have needed another cycle to clear the light as when i drove it to the club tonight the brake light was off thanks for all the sugjestions
