Parting out 2002 Subaru Impreza TS
Discussion in 'For Sale : Group Buy/Bulk Lot/Part Outs' started by mlgez, May 27, 2011.
  1. 03Rex
    03Rex Active Member
    Twin Cities
    Do these parts fit a 03 Sedan? If so, I need a door and front bumper for sure.
  2. phi11
    Action Valley
    Do some research, wagon and sedans are different.
    wrc10 likes this.
  3. mlgez
    mlgez Well-Known Member
    Around
    I believe someone took the front bumper skin and the drivers door. I will have to verify that. ph1ll is right, some parts fit and some don't.
  4. LVT
    LVT Well-Known Member
    t3h f4sT
    you wouldn't happen to still that shortblock would you?
  5. mlgez
    Around
    The only thing from the block that is gone is the heads. The timing belt broke on this engine so the valves were bent. I did not see any other damage but you would want to inspect it.
  6. mlgez
    Around
    Double post
  7. LVT
    t3h f4sT
    all i would need is the shortblock itself, none of the heads and etcc... i have plenty of parts to rebuild. i am more interested to see the condition of it. PM me your contacts and good time so we can meet up for me to see that block.
  8. Musashi
    Female
    Clouds
    mlgez - That did the job, I really appreciate your hospitality and kindness. Let me know if I can return the favor someday. Many thanks!!!
  9. mlgez
    Around
    I have the front bumper beam only, front passenger side door, and rear drivers side door.
  10. Tash
    Tash Well-Known Member
    Lino Lakes
    interesed in the pass front door. you have a pm
  11. svxninja
    svxninja Well-Known Member
    Bloomington, MN
    Drivers side door?
  12. mlgez
    Around
    Drivers door gone.
  13. BugIedIzzy
    BugIedIzzy Well-Known Member
    Anoka MN
    You ever find the side markers??
    Sent from my SAMSUNG-SGH-I997 using Tapatalk
  14. svxninja
    Bloomington, MN
    headlights?
  15. codya
    codya Well-Known Member
    Eagan
    You wouldent happen to have any coil packs left would you?
  16. mlgez
    Around
    I will have to look. I came across one of them this weekend while working out there.
  17. mlgez
    Around
    Both headlights went on to my wife's car.
  18. mlgez
    Around
    Yes, I still have the coil pack. As the car was not running at the time I purchased it I can not be completely sure of its status. The fact that the car had a stripped timing belt and bent valves indicates that the ignition was still functional :) .
  19. TMANN02WRX
    TMANN02WRX Member
    cottage grove
    hey where are you located and could you pm me your number i need the passenger side headlight wire and socket
  20. RexNEffect
    Wastelands
    Wondering if you have the trim piece on the dash right at the windshield, where the defrost comes through, and how much if you do?
  21. TMANN02WRX
    TMANN02WRX Member
    cottage grove
    Hey I forgot to ask last time if you had the drive shaft still
  22. Impreza_ej1.8
    Impreza_ej1.8 New Member
    Frazee, Minnesota
    still have the front seats? need them badly mine are ripped up got a 93 base impreza
  23. mlgez
    Around
    I do have that peice. Looks like it is in great shape. Kinda wonder about the VIN plae being on that piece though. $30?
    I do have the drive shafts. I think you would have to have an auto trans for the length to be correct. $75?
    I do still have the seats. I believe there are photos and info above.
  24. silverrs
    silverrs Well-Known Member
    Do you happen to have the starter?
  25. mlgez
    Around
    I do have the starter. $20.
  26. silverrs
    It's a manual transmission right?
  27. Kid Corona
    Kid Corona Member
    Eagan, Minnesota
    Interior dash clock?
  28. bikerboy
    bikerboy Subie GOD
    on the water looking for the sandbox
    Front brake calipers and brackets??
  29. svxninja
    Bloomington, MN
    still looking for a front drivers side door, still available?
  30. xXxWrenchBanger
    xXxWrenchBanger Well-Known Member
    Wyoming
    You still have this parts car around??
    If so, was it equipped with a roof-rack?
    I'm thinking about doing a rack delete and need the black trim pieces
    where my ugly roof-rack rails are....
  31. mlgez
    Around
    Most of the car went for scrap metal a few weeks ago. I still have most of the interior and not a lot else. Rear hatch, 3 doors (drivers is gone and passenger side rear is dented) and a few other items are still around.
    No this was an auto.
    That I should still have.
    Someone took the drivers door.
    This had a roof rack on it so probably does not have the trim piece you need.
  32. mlgez
    Around
    Brakes went with the scrap metal load.
  33. xXxWrenchBanger
    Wyoming
    Oh well, thanks for getting back to me anyhow....
  34. Kid Corona
    Kid Corona Member
    Eagan, Minnesota
    Does it still work? If so how much do you want for the clock
  35. Kid Corona
    Kid Corona Member
    Eagan, Minnesota
    bump
