Parts from my rolled 03 PSM WRX
Discussion in 'For Sale : Car Parts' started by MNSnoDrifter, Jun 8, 2014.
  1. xodad2
    xodad2 Well-Known Member
    Awesome dude:rolleyes:. Got a bunch of stuff from him today at an awesome price! Good luck with the rest of the part out. Nice looking car btw.
  2. MNSnoDrifter
    Thanks man. ..Nice to meet you... LMK if you need anything else
  3. Scott
    Scott Well-Known Member
    I will take the rear brakes.
  4. MNSnoDrifter
    UPDATE
    • Tail light, has a small crack, and also has a small piece of black plastic that is missing on the bottom..you will see the damage in the 2nd pic - $25/obo
    • carpet, decent shape. could use a washing, and the is a bit of damage where the dead pedal is - $50/obo
    • Manual pedal set (clutch, brake, and gas) - $30/obo
    • 4 PSM doors w/ door cards and glass and speakers - selling whole for now - the RR door window has a bit of damage on it, I have other pieces of glass for that. the RF door is a bit damaged by the side mirror. - price negotiable depending on which door you want ...but around $100
    • Blower unit - $40/obo
    • Front and rear seat...good condition... left side cushion of the driver seat a bit worn cause of my heavy ass getting in and out -$300/obo
    • Wiper arms with rain X wipers on them - $40/obo
    • Wing brake light - $20
    • Driver side Fog lamp - $25
    • PSM trunk lid...some damage on the driver side of it.....make me an offer
    • Ebay DP, not sure if the flex is still good or not - $25/obo SOLD
    • Stock rear sway bar - $25/obo SOLD
    • Stock TMIC w/stock Y-pipe (needs to be cleaned) - $40/obo
    • Cluster (light for the CC is out) says 192k IIRC - $40/obo
    • Stock fuel pump - $50/ob
    • Fuel level sending unit I believe that's what it is - $25/obo
    • Clutch Cylinder and actuator + lines (needs a reservoir) - $50/obo
    • Dome light w/ LED panel from DDM Tuning in it - $15
    • Map lights - $10
    • -Blacked out Ebay headlight (has broken piece) - $20
    • Washer fluid reservoir - $20/obo
    • Coolant overflow - $20/obo
    • Steering column (X2) - $40/obo
    • 2 radiator fans 1 just blades other whole - fan only - $10 full fan - $20
    • Drive shaft for a manual trans - $100/obo PENDING
    • Stock intake manifold - $70/obo
    • Stock TGV's - $75/obo
    • Stock injectors - $100/obo
    • ..................ALL 3 $200.................
    • Stock turbo inlet - $25
    • Stock long block - $400/obo
    • Alternator - $45
    • Perrin crank pulley - $50/obo SOLD
    • AC compressor - $50/obo
    • Stock Td04 - I think 170k ran good when installed it on my car in like Jan. - $75
    • Up pipe - $20 SOLD
    • Front calipers/w pads and brackets - $50
    • Rear calipers /w pads and brackets - $40 PENDING
    • ABS sensors - $20/ea
    • Rear diff (there is a corner of the rear cover that is chipped off, didn't seem like it was leaking - $100
    THERE WILL BE MORE PARTS TO COME .............
  5. thealtaholic
    thealtaholic Well-Known Member
    I'd like a good look at the passenger side doors, any rust on them?
  6. Stuart
    Stuart Well-Known Member
    Interested in the steering rack. Im going to do some digging and see if it swaps into my 05
  7. MNSnoDrifter
    I don't have that..it was a typo and I corrected it...sorry
  8. MNSnoDrifter
  9. MNSnoDrifter
    UPDATE
    • 1 PSM door, RF has a bit damaged by the side mirror. - make an offfer
    • Driver side Fog lamp - $25 PENDING
    • Cluster (light for the CC is out) says 192k IIRC - $40/obo SOLD
    • Stock fuel pump - $50/ob SOLD
    • Map lights - $10
    • Alternator - $45
    • AC compressor - $40/obo
    • Subaru triple gauge pack, does not come with oil temp sensor, but has everything else, ans is plug and play - $60
  10. AndyBoyee
    AndyBoyee Well-Known Member
    Does 02-03 have the cup holder behind the center console/e brake for the rear seaters?
  11. Casey
    Casey Member
    mine does not
  12. MNSnoDrifter
    No, not that I've seen
  13. AndyBoyee
    Damn, I need to replace my broken one in my 05 wrx. But thanks anyways.
  14. MNSnoDrifter
    took most of the motor apart tonight
  15. MNSnoDrifter
    Don't know why the pics came up small
  16. EricS
    EricS Nooberator
    That was a dealer-installed option on those cars. Pretty rare to see it installed from what I've seen. Based on this thread I believe the part # is 66150SA100OE (but double-check it fits your year before buying), you can see if you can find it online or from one Oak Leaf / Slidegood.
    AndyBoyee likes this.
  17. MNSnoDrifter
    Fog Light is sold...thanks Thomas
  18. MNSnoDrifter
    UPDATE
    • Tail light, has a small crack, and also has a small piece of black plastic that is missing on the bottom..you will see the damage in the 2nd pic - $20/obo
    • carpet, decent shape. could use a washing, and the is a bit of damage where the dead pedal is - $40/obo
    • Manual pedal set (clutch, brake, and gas) - $25/obo
    • 1 PSM sedan door, RF has a bit damaged by the side mirror. - make an offfer
    • Blower unit - $30/obo
    • Front and rear seat...good condition... left side cushion of the driver seat a bit worn cause of my heavy ass getting in and out -$300/obo PENDING...but will still have the Pass front seat.
    • Wiper arms with rain X wipers on them - $30/obo
    • Wing brake light - $15
    • Driver side Fog lamp - $25 SOLD
    • Fuel level sending unit I believe that's what it is - $20/obo
    • Clutch Cylinder and actuator + lines (needs a reservoir) - $40/obo
    • Dome light w/ LED panel from DDM Tuning in it - $10
    • Map lights - $5
    • -Blacked out Ebay headlight (has broken piece) - $15
    • Washer fluid reservoir - $15/obo
    • Coolant overflow - $15/obo
    • Steering column (X2) with keys - $40/obo
    • 2 radiator fans 1 just blades other whole -....... fan only - $10...... full fan - $20
    • Drive shaft for a manual trans - $80/obo
    • Stock intake manifold - $60/obo
    • Stock TGV's - $60/obo
    • Stock injectors - $80/obo
    • ..................ALL 3 $175.................
    • Stock turbo inlet - $20
    • Alternator - $40
    • Stock Td04 - I think 170k ran good when installed it on my car in like Jan. - $50
    • Front calipers/w pads and brackets - $40
    • Rear calipers /w pads and brackets - $30
    • ABS sensors - $15/ea
    • Subaru triple gauge pack, does not come with oil temp sensor, but has everything else, ans is plug and play - $50
  19. s1ngletracker
    s1ngletracker Well-Known Member
    can I see pictures of the passenger side front door? What damage was done by the mirror?
  20. MNSnoDrifter
    yeah, I'll get some tomorrow
    MORE STUFF
    CD holder for a single deck open space - $10
    Pioneer Deck - $20
    Stock 6-disk - $20
  21. Just-someone
    Just-someone Well-Known Member
    How much for the OEM gauge pack? Do you still have the stock intake snorkel?
  22. Casey
    Casey Member
    looks like 50 and 20 dollars
  23. MNSnoDrifter
    I don't have a snorkel right now, but should in a couple weeks. ... And there is 2 people ahead of you on the gauges
  24. EricS
    EricS Nooberator
    Thanks for the shtuff M, nice to meet you! : )
    MNSnoDrifter likes this.
  25. MNSnoDrifter
    UPDATE
    • Carpet, decent shape. could use a washing, and the is a bit of damage where the dead pedal is - $40/obo
    • Manual pedal set (clutch, brake) - $15/obo
    • Map lights - $5
    • Blacked out Ebay headlight (has broken piece) - $15
    • 2 Steering columns, with keys - $40/obo/ea
    • Stock TGV's - $50/obo
    • Stock injectors - $80/obo SOLD
    • Alternator - $40
    • AC compressor - $40/obo SOLD
    • Subaru triple gauge pack, does not come with oil temp sensor, but has everything else, ans is plug and play - $50 SOLD
    • CD holder for a single deck open space - $10
    • Stock 6-disk - $20
    • Pioneer Deck - $20
    New.......
    • Stock catback - $40/obo
  26. MNSnoDrifter
    NP, nice to meet you too!
    EricS likes this.
  27. MNSnoDrifter
  28. MNSnoDrifter
  29. MNSnoDrifter
  30. MNSnoDrifter
    UPDATE
    • Stock TMIC w/stock Y-pipe (needs to be cleaned) - $40/obo SOLD
    • Map lights - $5
    • Stock turbo inlet - $20 SOLD
    • Stock long block - $400/obo SOLD
    • Alternator - $40
    • Stock Td04 - I think 170k ran good when installed it on my car in like Jan. - $50 SOLD
    • Front calipers/w pads and brackets - $40 PENDING
    • Rear calipers /w pads and brackets - $30 PENDING
    New.......
    • 5SP Tranny (unknown miles) - $500/obo
  31. AlphaD
    AlphaD Active Member
    When are you available for some sales Mister?
  32. MNSnoDrifter
  33. LilRed
    LilRed Well-Known Member
    pmed you
  34. MNSnoDrifter
    UPDATE
    • Carpet, decent shape. could use a washing, and the is a bit of damage where the dead pedal was - $40/obo
    • Map lights - $5
    • Alternator - $40 SOLD
    • Front calipers/w pads and brackets - $40 SOLD
    • Rear calipers /w pads and brackets - $30 SOLD
    • ABS sensors - $15/ea SOLD
    • 5SP Tranny x 2 (unknown miles) - $450/ea/obo
  35. DoughtCom
    DoughtCom Well-Known Member
    Did you ever pull the wiring harness? I'm trying to find a full non molested wiring harness. Also what shape was/is the dash beam? If you haven't sold that.
  36. MNSnoDrifter
    I have a full harness from a 02 wrx Wagon. ... And day dash beam? You mean the one that runs behind the dash? Then no I do not have that
  37. MNSnoDrifter
    1 of the 5sp's are sold...still have 1 left
  38. 2.5SubieRS
    2.5SubieRS Well-Known Member
    I'll take the Perrin pulley
  39. 2.5SubieRS
    Never mind apparently I can't read
  40. MNSnoDrifter
    LOL...it's all good..thanks for the bump though :D
  41. tonyM
    Hey mike, I cant read either.
    Do you happen to have the turbo coolant reservoir?
  42. MNSnoDrifter
    I don't think I do
  43. derek draeger
    derek draeger Member
    I'll take the pedal set
  44. xluben
    Do you have any interior trim pieces left? I'm interested in the center vent trim and radio trim.
  45. MNSnoDrifter
    Derek - which set auto or manual
    Been I'll see if I have it
