UPDATE Tail light, has a small crack, and also has a small piece of black plastic that is missing on the bottom..you will see the damage in the 2nd pic - $20/obo Carpet, decent shape. could use a washing, and the is a bit of damage where the dead pedal was - $40/obo Manual pedal set (clutch, brake) - $15/obo 2 PSM sedan door, RF and LR. RF has a bit damaged by the side mirror. and LF has some damage in the middle just below the window - make an offfer Blower unit - $30/obo Front pass and rear seat...good condition... left side cushion of the driver seat a bit worn cause of my heavy ass getting in and out -$150/obo Wiper arms with rain X wipers on them - $30/obo Wing brake light - $15 Driver side Fog lamp - $25 SOLD PSM trunk lid...some damage on the driver side of it.....make me an offer Ebay DP, not sure if the flex is still good or not - $25/obo SOLD Stock rear sway bar - $25/obo SOLD Stock TMIC w/stock Y-pipe (needs to be cleaned) - $40/obo SOLD Cluster (light for the CC is out) says 192k IIRC - $40/obo SOLD Stock fuel pump - $50/ob SOLD Fuel level sending unit I believe that's what it is - $20/obo Clutch Cylinder and actuator + lines (needs a reservoir) - $40/obo Dome light w/ LED panel from DDM Tuning in it - $10 Map lights - $5 Blacked out Ebay headlight (has broken piece) - $15 Washer fluid reservoir - $15/obo Coolant overflow - $15/obo SOLD 2 Steering columns, with keys - $40/obo/ea 2 radiator fans 1 just blades other whole -....... fan only - $10...... full fan - $20 Drive shaft for a manual trans - $80/obo SOLD Stock intake manifold - $60/obo Stock TGV's - $50/obo Stock injectors - $80/obo SOLD Stock turbo inlet - $20 SOLD Stock long block - $400/obo SOLD Alternator - $40 SOLD Perrin crank pulley - $50/obo SOLD AC compressor - $40/obo SOLD Stock Td04 - I think 170k ran good when installed it on my car in like Jan. - $50 SOLD Up pipe - $20 SOLD Front calipers/w pads and brackets - $40 SOLD Rear calipers /w pads and brackets - $30 SOLD ABS sensors - $15/ea SOLD Rear diff (there is a corner of the rear cover that is chipped off, didn't seem like it was leaking - $100 SOLD Subaru triple gauge pack, does not come with oil temp sensor, but has everything else, ans is plug and play - $50 SOLD CD holder for a single deck open space - $10 Stock 6-disk - $20 Pioneer Deck - $20
UPDATE BUMP Tail light, has a small crack, and also has a small piece of black plastic that is missing on the bottom..you will see the damage in the 2nd pic - $15/obo Manual pedal set (clutch, brake) - $15/obo 2 PSM sedan door, RF and LR. RF has a bit damaged by the side mirror. and LF has some damage in the middle just below the window - make an offfer Blower unit - $20/obo Wiper arms with rain X wipers on them - $20/obo Wing brake light - $15 PSM trunk lid...some damage on the driver side of it.....make me an offer Fuel level sending unit I believe that's what it is - $15/obo Clutch Cylinder and actuator + lines (needs a reservoir) - $40/obo Dome light w/ LED panel from DDM Tuning in it - $10 Map lights - $5 Blacked out Ebay headlight (has broken piece) - $10 Washer fluid reservoir - $15/obo 2 Steering columns, with keys - $30/obo/ea 2 radiator fans 1 just blades other whole -....... fan only - $10...... full fan - $15 Stock intake manifold - $50/obo Stock TGV's - $40/obo CD holder for a single deck open space - $10 Stock 6-disk - $20 Pioneer Deck - $20
