Piston or Valve?
Discussion in 'Modifications And Maintenance' started by k_thaosta, May 15, 2008.
  1. k_thaosta
    k_thaosta Well-Known Member
    I have a tapping noise coming from the passenger side of the engine. Sounds like its coming from the passenger cylinder head, but not sure since it's so dang loud now. If anyone wants to hear it, I can drive it still. I am wondering if it is a bent valve or a piston knock. I'll try and get a clip of it too if possible. This noise goes away at higher rpms over 3k. Oil levels haven't dropped, but people have told me that black smoke comes out of my exhuast. Oil changed regularly, but waiting on this last one since I'm not driving it anymore. Had minor oil leaks, but it has stopped. Has powersteering leak. Water temp does ranges from 210-230 degrees during normal driving, any speeding or downshifting results in going over 230 degrees.
    Specs on mods, stock FXT heads on stock STI block, mod wrx injectors, not running AVCS, stock headers, MRT uppipe, MRT turboback, UTEC, ECUTek ECU, all 02 WRX.
    Any suggestions? Valve or Knock? Any help would be appreciated, thanks.
  2. tbone
    tbone Well-Known Member
    I wouldn't drive it if I were u....pray for the valve or piston rod....
  3. k_thaosta
    I'm hoping it would be the valves, but I'm unsure, just need some help IDing the problem.
  4. WRX1
    Use a long screw driver/extension as a listening enhancer.
    Cue up the "justin's car blowing up at the ice race video". Chux is doing the same thing in that. You hold one end to your ear, and you place the other end on the part of the motor where the noise"may" be coming from. It will help isolate where the noise is.
  5. Shibbs
    Its all because you have Naruto & Sasuke in your avatar.
    Please don't drive it anymore. Did it start and slowly get worse? Did it just happen, and when? How long have you been driving it making this noise?
  6. k_thaosta
    I'll try it and post where the noise may be coming from.
    It started last year and slowly got worse. It just got really bad in the last couple of months. Again, oil is fine, but the noise gets louder when oil drops a little too.
  7. k_thaosta
    Alright, I've looked up some videos on using the screwdriver thingy to listen to where the noise is coming fro,. I haven't done it yet, but how will I know from listening to the screwdriver, vibration, noise, humming?
  8. gc8
    gc8 Well-Known Member
    You'll be able to pinpoint the noise by putting your ear to the screwdriver (plastic end) and putting the tip on the suspected areas. The noise will be clear when you find it.
