PITA Hints how to put on a FMIC?
Discussion in 'Modifications And Maintenance' started by tux121, Oct 11, 2008.
  1. tux121
    tux121 Well-Known Member
    Hints? Right now I have everything off except the stupid bumper beam which has welded nuts?
  2. readymix
    Wait, What? Your bumper beam has welded nuts? Maybe you need to go out there and put some more ass into it.
  3. tux121
    my ass is hurting already:ugh:
    needs my azz a grinder
  4. tux121
    It says to take off 4-14mm Nuts, 4-14mm Bolts and 2-12mm bolts. So far I've found the 4-14mm nuts and the 2-12mm bolts but not the 4-14mm bolts...?
  5. readymix
    There should be 4 bolts inside the front of the bumper beam, they will be deep inside some holes. It's been a while, but I really only remember the 4 large 14mm bolts that were inside the bumper beam holes.
  6. tux121
    Got it, got it...thankyou Conez!
  7. tux121
    okay another issue it says I will be reusing the OEM coolant overflow tank & Washer Fluid but where?
  8. manochromatic
    manochromatic Member
    cut the welded nuts off..you dont need them. i promise.
    also the fmic kit we have came with a new bumper beam,coolant res. and the washer resevoir didnt need to be moved at all, only taken out for space during the install.
    i didnt notice but do you have a lightweight or jdm bumper beam? you obviously cant re-use the stock one..its garbage.
    if you need hands on help just let me know and i can figure out a way to help.
    also i hope you have a dremel..for the bumper.
  9. tux121
    Well everything is partially solved, all that's left is me trimming the front bumper to fit and let me say this, I haz no skillz. Update later......
  10. manochromatic
    well like i said i can help..i can cut it for you if you want. i may even still have a template that came with the aps. if theres anything i can do please let me know. and good luck:cool:
  11. tux121
    Well right now I have the car running with the perrin fmic I just need to buy their coolant overflow tank because they didn't provide me with one. Right now I'm using my OEM one but it's not secured. I still have a few leaks I have to fix, the bypass valve gasket and checking the couplers because I still hear this high pitch noise. Driving is pretty bad, afterfires, laggy, only 14psi no I used to do 19psi with the tmic lol. Putting on my turbo soon, OEM STi TMIC for sale.
  12. subynate
    subynate Well-Known Member
    how much you want for the tmic?
  13. tux121
    I'll let you know, I must go take some pictures first XD
  14. Bradimus
    Bradimus New Member
    The FMIC looks good I drove by today and caught a glance of it.
