Popped another motor......
Discussion in 'Modifications And Maintenance' started by KSAL, May 3, 2009.
  1. KSAL
    KSAL Well-Known Member
    I do like going fast but i'd get hurt on a bike so i don't even want to try.... but the thought has crossed my mind quite a few times
  2. Paul Revere
    No! He needs four wheels!
  3. KSAL
    Thanks chet! ;)
  4. subytek
    subytek Well-Known Member
    qft!!!
  5. Paul Revere
    Just care to see ya another day I guess ... don't wanna get all sentimental but yeah you and I need to keep it to 4 wheels on the tarmac ;)
  6. xxtraloud
    xxtraloud New Member
    that sucks big time! I honestly would dump that engine, get out what's still good and get a used USDM engine on ebay from a donor or look into some JDM options, but that would probably require extra wiring work. I don't know I am just throwing ideas around. We don't even have emission around here so you don't even need to worry about not having an obdii.
  7. Paul Revere
    What?
  8. FuJi K
    I guess stock EJ257's can't boost high without oval'ing the walls???
    Time to find a closed deck EJ22T? hahaha
    I DO wonder if having the block closed deck with the CNC Billet piece pressed in will help it. This is just the top, so it might oval in the mid-section of the cylinder.
  9. KSAL
    I was also thinking it might be time for a 22T block as well... It might oval the mid section of the cylinder you are correct. I'm going to try and research maybe a better way to get to 500whp without having to go to 28psi.... There may not be a way but if its out there im going to try and find it. Basically my biggest problem with these motors is not handeling that high of a boost pressure. So if there is a way to get the desired HP without having to run as much boost..... hmmmmm
  10. xxtraloud
    I think it's time to do some reading on nasioc :yumyum:
  11. wall of tvs
    get a bigger turbo then :biggrin:
  12. KSAL
    bigger turbo will get me more HP at lower PSI??
  13. wall of tvs
    yessir
    Fobia made like a zillion echpeez last summer on like 2psi.
  14. Dream
    he's getting a mullet racer car
  15. KSAL
    No i tossed around the idea..... get it straight dreamis
    Probably wont happen
  16. AWDimprezaL
    Gto with some spray, maybe a blower.
  17. KSAL
    No not a GTO
  18. Dream
    Camaro pal!
  19. KSAL
    I bet you would be jealous if i had a sweet camero. Or a fully built sleeved 22T??
  20. ShortytheFirefighter
    Cadillac CTS-V.
    The new one (if you can swing it) will dyno in the high 400whp range stock ;)
  21. Dream
    You cant own one if you cant even spell it. :eek3:
  22. AWDimprezaL
    Fox body mustang with some spray, you could have half a dozen or so 10 second stangs with the money you have put into the sti ;)
  23. KSAL
    Uggg i know :rolleyes: ohh well i dont have that many mustangs becuase then i would probably have 6 times the headaches too...
  24. KSAL
    hahahah oops. dream= spelling skillz
  25. ShortytheFirefighter
    Not true.
    I've met a number of them who couldn't count to twenty if they left their socks on, let alone try to spell Camaro.
  26. AWDimprezaL
    Well you would have 5 others to drive when one starts to act up :laugh:
  27. fobiawrx
    fobiawrx Fabiola
    a twinscroll 40r or s366 will get you there easy. ron was at 400whp at 16psi. i was at 450whp at 23psi. our kits should be able to do it easy but we are in the middle of testing them now.
  28. KSAL
    I know ur kits are sweet.... but right now im faced with fixing a broken car. I think im going to do it right this time and do a sleeved 22t block with pistons, rods, bearings, balanced crank the whole works. then maybe after i pay off all my credit then..... i may get a chimera kit.
  29. Iroc-Z
    Iroc-Z Well-Known Member
    Sell that turd.
    Buy an 03-04 Supercharged Cobra. 2500.00 in bolt ons nets over 500 whp.
  30. Shibbs
    And a mullet.
  31. DISCOPOPE
    DISCOPOPE Well-Known Member
    sorry to hear about the engine man.
  32. Natural2JZ
    Natural2JZ Well-Known Member
    more displacement maybe? 3.3l?
  33. Shibbs
    EG30. Maybe the new EZ36? Hmmmmm....
  34. AWDimprezaL
    No, its EG33 svx
    EZ30 tribeca/obk/3.0R
    EZ36 tribeca/obk/3.6R
  35. Shibbs
    Bah, thank you 3rik. lol
    I'm not usually a fan of the 6-cyl soobarooz.
  36. AWDimprezaL
    You shut your word hole about 6 cyl subarus.
  37. Shibbs
    :eek:
  38. 94foobra
    94foobra New Member
    :kekekaugh:
  39. 94foobra
    94foobra New Member
    You didn't really just say that did you?
  40. Iroc-Z
    I am not following you.
  41. 94foobra
    94foobra New Member
    The subaru/iroc-z owner suggest an 03 cobra? Just would have never expected it thats all.
  42. AWDimprezaL
    Its a fantastic idea.
  43. fobiawrx
    fobiawrx Fabiola
    booooooooooooooo!
  44. KSAL
    After quite a bit of thought, im going to go for a 22t build. No V8 no mustang no camaro. But Im saying right now if this motor blows im selling the car.may look into switching to E85 at this time too. we will see.
  45. Iroc-Z
    Hey if something works something works. Show me another car that can make reliable HP dollar for dollar. Hell a local guy sprays his and makes like 700 whp and never has to fix anything.
