Possible Upgrades and the current progress:
Discussion in 'Modifications And Maintenance' started by Nater, Dec 27, 2011.
  1. Nater
    Nater Member
    Alright some of you may know I'm having a new short block put into my STi. I'm currently looking at some investments and improvements.
    #1 a new turbo, the current one is stock or I'm assuming its stock.
    What would be the best one to get? I'm seeing ones from 500$ to $2000. I'm thinking of upgrading and would spend around 1000$ but, if its worth spending more I'd like to know what and why.
    #2 replacing the clutch or getting a new one current one looks stock, and maybe could be replaced. But could prob go another 40-50k if I shift well and if I would need one to go to the power I currently would want.
    #3 TGV Delete possibly or other things alike.
    Some goals I'm looking into:
    Hit 400-450 WHP
    The new shortblock im using is the built one from project sonic so I know I should be able to push this no problem.
    Here is some of the progress
    the new short-block
    This happend to the head when the piston broke, should just buff out I hope
    doing some head work while the engine is a apart
    this is what happened to my piston
  2. chris02rex
    chris02rex Well-Known Member
    I had the hta68 on my 2.5 hybrid. I loved the fast spool and it held well at 25 pounds. It's reasonably priced but probably wouldn't hit your goal for hp.
  3. Nater
    Nater Member
  4. russellmn
    russellmn Well-Known Member
    For your turbo, Precision PTE5557. Get the small cover and it'll fit in stock location. Run the biggest top mount (AMR???) you can get and some 1000cc injectors. On pump gas you should see 425whp or so, go to the corn whiskey and you can get up to around 500whp.
    Friend of mine is running this setup on his stock 06 STi longblock (heads have NEVER been off) on e85. 503awhp for the last year.
  5. Nater
    Nater Member
    Got the car running again, all back together and running fine. I went to the cities to get Nuke to retune the beast. found out I need a new Fuel pump.
    Ordered:
    DeatschWerks 300 Series Fuel Pump
    http://www.rallysportdirect.com/DeatschWerks-300lph-Fuel-Pump
    and
    AEM UEGO Wideband Controller AFR Gauge
    http://www.rallysportdirect.com/AEM-UEGO-Wideband-Controller-AFR-Gauge
    Going to convert my fuel pump to the in the engine fuel pump the WRX one. Along with that I'm going to pick up one of these:
    Electronic Boost Control Solenoid 3-Port - Subaru
    http://www.grimmspeed.com/catalog/product_info.php?cPath=60_33_36_154&products_id=145
    whats currently in the process is rebuilding my other struts, the ones I put in are complete trash, and break pads.
  6. 2barsti
    2barsti Well-Known Member
    You should already have a 3port ixizconcept bcs.
  7. Nater
    Nater Member
    Getting one thats better :-p
  8. Nuke
    wait
    you're getting a 3 port electronic boost controller?
    i said manual boost controller....
  9. Nater
    Nater Member
  10. 2barsti
    Still on the vf39?
  11. Nater
    Nater Member
    Yup... Id like to upgrade someday...
  12. russellmn
    Upgrade soon and sell my your -39!
  13. webcrawlr
    webcrawlr Well-Known Member
  14. Medic_538
    Medic_538 Well-Known Member
    That 20 gxt R should do you just fine. My 18gxt is SAID to get 430 crank hp. That's plenty for me. I do understand that more must go into for that goal. Not looking for that goal though.
  15. Medic_538
    Ok, not to thread jack, why spend the extra 300$ for another 10 hp? Are we talking spool and top end speed?
  16. Nuke
    Most solenoid are mac solenoid. No issues tuning if tuner can adjust
