Powdercoat Forged wheels. who has them?
Discussion in 'Modifications And Maintenance' started by idget, Mar 5, 2008.
  1. idget
    falcon heights
    Yes, I've read these threads:
    http://www.iwsti.com/forums/tires-wheels/71687-what-powder-coating.html
    http://forums.nasioc.com/forums/showthread.php?t=1088095
    as well as dozens of others on nasioc, this forum, and elsewhere.
    I'm also in contact with a handful of places around the cities gathering information about their process.
    Wondering who has powdercoated forged aluminum wheels (preferably stock bbs), how the wheels (not color) are holding up, and who did it.
    I think WallofTVs had his ssr's powdercoated. Anyone else?
    Not interested in cast wheel testimonials. Thanks!
  2. Paul Revere
    In the land of ice and snow.
    IIRC Bikerboy has his BBS's on his LGT powder coated
  3. bikerboy
    bikerboy Subie GOD
    on the water looking for the sandbox
    I have PC'd two sets of BBS's and have tracked both the sets of wheels after the process and I am still here to type. :roll:
  4. AspitFire
    MN
    also i think dipp's sti wheels were poweder coated and his are fine
  5. idget
    falcon heights
    Daily driven too I assume?
    also, was this from tcpowdercoating, powder coating technologies, gauthier, custom coaters, etc?
  6. Paul Revere
    There are deals on here for TC.
  7. idget
    falcon heights
    ^talking to Tim at TC right now. They bake for 15-20 minutes at 400. Looking to see if they have a different powder that can cure at a lower temp for less time.
  8. Taras
    Taras BANNED
    Saint Paul, Minnesota
    omgdz, Sheen is asking questions on the forum;) JK. I think those bbs's will look sick powdercoated!
  9. Zombie
    Zombie Well-Known Member
    I am doing some research right now as well. I have to have one of my recently aquired STI BBS's straightened. In order to straighten them they heat the wheel up. I have the same concern.
    My initial thought is that it may weaken them slightly but you will likely never notice. I'll report back what I come up with.
  10. idget
    falcon heights
    Appreciate it.
    I've only come across one PC'd BBS rim that has bent, and that was during a rally-x.
    I've also only spoken to 1 place that PCs (not local) that refuses to do forged aluminum wheels.
    It seems like it's pretty much impossible to know precisely at what temperature and for what duration it takes for the BBS wheels to anneal, but I'd rather err on the side of caution. I'm specifically looking for a powder in deep blue that can be cured at 300F or less for no more than the typical 15 minutes.
  11. idget
    falcon heights
  12. piddster
    Boostonia
    It depends on the alloy used in the wheel. 6061-T6 is precipitation aged at 320 for 6-10hrs. Go over that and it gets weaker. So 400 degrees will over-age the part and it will actually become weaker. If 6061-T6 is welded, at the weld the heat treatment goes back to a T0, meaning less than half the strength of the original heat treatment. Thats why if a structural member is welded the whole piece needs to be heat treated again.
    Same applies to a wheel that was heated to be straigtened. The heat treatment in that area was lost and it will be more prone to bending in that area, unless the whole wheel is heat treated again.
    Again, it all depends on what kind of aluminum and original heat treatment.
  13. idget
    falcon heights
    This is part of the information I'm struggling to confirm... the composition of the BBS wheels and the manufacturing process.
    The 300F value I'm shooting for is based mostly on "lyveWRX's" postings... like post #11 here:
    http://forums.nasioc.com/forums/showthread.php?t=747591&page=2
  14. RichWRX
    RichWRX Well-Known Member
    Orr,Mn
    I had my bbs's on my sti done 3 yrs ago and they are still like new. pd $30 each wheel
  15. idget
    falcon heights
    Where did you have it done?
  16. Zombie
    hah, i wrote a response and see its essentially been repeated... I agree with lyveWRX's response from the NASIOC link. Let me know what you find out about lower temp powdercoats.
    As for straightening my bent wheel…I’m kind of screwed. This is done by annealing the alloy with a torch so that it can be bent back easily. Not too scientific and not much concern of controlling the temp so I can almost guarantee they get above 500+ degrees at different locations of the wheel. Sooo, the repaired wheel will likely bend easier than a factory fresh wheel. In fact, now that I think of it, its likely that the wheel will bend easier than most cast wheels because the design likely relys on the strength of the forged material and the BBS engineers were going for weight reduction.
    I will probably have it repaired and use it as a spare. Anyone have an extra 5x100 BBS wheel?
  17. Zombie
    Oh, and good luck trying to quantify if powdercoating weakens wheels based on people's experiences. That will be impossible! 8) No one will know if they have 30% weaker wheels even if they did or didn't bend them.
  18. mlgez
    mlgez Well-Known Member
    Around
    Had mine done on the group buy here a while back. No problems and the coating has held up very well.
  19. RichWRX
    Orr,Mn
    I had them done in Duluth, cant remember the name right now. But the cost was with sandblasting also
  20. TSTRBOY2004
    was thinking about hitting up my buddy to do mine.. the powdercoat industrial mixing machines like 1 story tall machines... so I will have to see what temps they use and what paint they have... they have a room just as big to sandblast too... so I may get a car done here... woot...
  21. idget
    falcon heights
    lol, for sure. Just trying to see if anyone has had any troubles and if so where and what kind of process they used.
    Nathan, where's yr buddy's place at? I'd definitely feel more comfortable going to a place with large enough ovens that a set of wheels won't tie them up... so long as the ovens bake evenly and they are knowledgeable of course.
  22. flstffxe
    flstffxe Well-Known Member
    Coon Rapids
    ^^ best coat in blaine has an oven big enough to put a full size truck chassis into. their price is reasonable too.
  23. blackozone
    Dirrty Souf
    My God you're picky. You must be Japanese or something.:roll:
  24. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    i got dipp's old wheels now readymixes studded tire wheels, bikerboys and my own done by color technologies. one of my old friends dad owns the place. don't have the connection anymore but you could always see if they can do them for you.
  25. Zombie
    I read yah... At least you can find out if people's wheels are folding over immediately or not right?
    I have a connection at Twin City Powdercoating. They had all kinds of powder vendors. I can see what options they have for low temp powder.
    -Chad
  26. AspitFire
    MN
    forgot to throw my name in the list of peeps who had them :laugh:
  27. driftin240
    driftin240 Well-Known Member
    Out West
    RallySTi has had his BBS's done, and they turned out fine. IIRC, he used Twin City Powdercoating.
  28. TSTRBOY2004
    my buddies place is not a 'powdercoating' business...
    it's called Scott Equipment... they build mixing machines.... the size of an 18 wheeler.. ha ha
  29. idget
    falcon heights
    Here's a start:
    http://www.powdercoatingonline.com/forum/read.asp?id=1376
    I'm still waiting on calls/emails back from local businesses regarding these low bake powders. Trying to find out what brands are being used.
  30. Ryan
    Ryan Sled drifting master
    Bump. Sheen what did you find out about this?
